Duo Dive-brakes ( Polar with spoilers extended?)
Old October 31st 07, 08:16 PM posted to rec.aviation.soaring
Bruce
Default Duo Dive-brakes ( Polar with spoilers extended?)
Hi Chris
Lets think it through then. Here is my very rusty attempt at physics -(I know
there are experts here maybe one will bite)
The bigger gliders tend to have higher aspect ratio wings. This means that, like
the Beetle they have a polar moment challenge. The beetle would roll easily at
speed because of a combination of aerodynamics reducing load on the suspension,
and a high centre of gravity. Add the original swing axles and you have a recipe
for landing on the roof.
In the long wings glider you have the same issue, but symmetrical on both sides,
the centre of mass of the wings is at a further distance from the roll centre of
the aircraft. It thus takes more energy to achieve a specific rate of rotation,
because you need more kinetic energy (Mass * distance** is against you because
the wings are longer AND heavier)
Think of two pendulums of equal mass, but different lengths. Then try it with
the same mass but different mass distribution (Like a metronome)
The frequency is proportional to the polar moment not the mass.
I am sure the aerodynamics experts can tell you about the relative Reynolds
numbers, but that is more a function of chord, and that is not radically
different. The taper ratio is higher in 15m than in 26m, but the tips of a given
generation seem to be of similar chord. This is where the ailerons generate the
rolling force so I assume the airfoil differences are greater than the Reynolds
number effects.
What makes it necessary to stay further ahead of a 20m wingspan glider is
inertia - stored energy. It takes longer, and / or more force to achieve the
same deflection. Then you take into account the total mass that you are trying
to deflect is greater and it gets worse.
On the other hand I understand that 47:1 (Duo x) can get addictive.
problems@gmail wrote:
J a c k wrote:
I think the Duo's airbrakes are better than many people think. The Duo is a
big heavy glider with lots of inertia. It doesn't like to change direction
quickly. That includes its behavior on sudden airbrake deployment. You
don't get a lot of sink right away.
My first reaction was that the airbrakes were weak but a little more
experience showed me that with a little patience, the brakes took effect and
produced a respectable decent rate. The Duo just makes you plan ahead a
little more than with a light single seater.
I don't understand the physics here.
Consider an analogy:
when the VW-beetle came out it had a reputation of 'turning over easily',
based on the false logic that you need less men to 'turn it over' than to
'pick up & turn over a bigger car'. Of course the forces while driving, that
tended to 'turn it over' were less for a VW, but so too were the forces that
resisted 'turn it over'.
A heavy pendulum is 'eqivalent' to a lighter pendulum.
So too for the BIG glider.
What doesn't scale up is the pilots strength.
Or is reynolds number significant ?
== Chris Glur.
Old November 1st 07, 12:29 AM posted to rec.aviation.soaring
Karl Striedieck
The original Duo (can't speak for the new X model with the drag flap)
definitely requires more attention to energy management when landing than
your garden variety 750 pound glider. Any excess coming over the trees won't
go away by diving with full spoilers. This is a consequence of increased
weight and relatively smaller spoilers and is common to all "large" gliders.
The problem can be magnified by improperly adjusted spoilers. It is possible
that owners who have readjusted their wheel brakes have inadvertently
reduced the travel of the spoilers. Also, the Duo spoilers are heavier to
extend than smaller gliders and it takes extra muscle to hold them fully
open during the approach and flare. And as the airspeed decreases they get
heavier because the dynamics of airflow don't help hold them open.
As to the assertion that the DG-1000 has more effective air brakes than the
Duo, this is not so. While flying a DG-1000 I had the opportunity to do a
formation "test dive" comparison with a Duo. We (Tom Knauff in a Duo) got in
tight formation with me on the wing and at 65 knots pushed over while
deploying full spoilers. The two ships stayed exactly even in a descent of
500 plus feet.
Many US pilots I've noticed landing at various contest sites like to stick
the glider on the ground at speeds 20 and 30 knots above stall and then roll
thousands of feet to their trailers. This is poor preparation for the time
precise energy management is needed to get into a small outlanding field. As
the size and weight of the gliders increase the problem of stopping
magnifies, so unless you are flying a Sparrowhawk or 1-26 you should make
every landing a tail dragger touch down at an intended spot.
Karl Striedieck
"Bruce" wrote in message
Hi Chris
know there are experts here maybe one will bite)
that, like the Beetle they have a polar moment challenge. The beetle would
roll easily at speed because of a combination of aerodynamics reducing
load on the suspension, and a high centre of gravity. Add the original
swing axles and you have a recipe for landing on the roof.
sides, the centre of mass of the wings is at a further distance from the
roll centre of the aircraft. It thus takes more energy to achieve a
specific rate of rotation, because you need more kinetic energy (Mass *
distance** is against you because the wings are longer AND heavier)
with the same mass but different mass distribution (Like a metronome)
Reynolds numbers, but that is more a function of chord, and that is not
radically different. The taper ratio is higher in 15m than in 26m, but the
tips of a given generation seem to be of similar chord. This is where the
ailerons generate the rolling force so I assume the airfoil differences
are greater than the Reynolds number effects.
the same deflection. Then you take into account the total mass that you
are trying to deflect is greater and it gets worse.
is a big heavy glider with lots of inertia. It doesn't like to change
direction quickly. That includes its behavior on sudden airbrake
deployment. You don't get a lot of sink right away.
effect and produced a respectable decent rate. The Duo just makes you
plan ahead a little more than with a light single seater.
easily',
that
that
== Chris Glur.
Old November 1st 07, 12:41 AM posted to rec.aviation.soaring
John Smith
I've never compared the two side by side. But fact is that the original
Duo is not certified for aerobatics, according to the SH homepage due to
the poor dive brakes, while the DG1000 is, as well as the new Duo X. So
yes, it seems there is a difference in air brake effectiveness.
Old November 1st 07, 02:13 AM posted to rec.aviation.soaring
Karl Striedieck
John,
Can you refer me to the SH webpage regarding the spoiler/acro issue? All I
can find on the current German version is the Duo X.
My flight manual says acrobatics are not allowed but it doesn't say anything
about "poor dive brakes" being the reason. The manual does say that the max
g loading with the spoilers deployed is reduced to 3.5. This is common for
most gliders because of the concentration of bending loads at the outboard
end of the spoilers, magnified during high g pull-ups.
Although it is purely speculation on my part, I suspect the no-acro
limitation is more a matter of the reality that poorly executed maneuvers
can lead to unintended dives, overspeed and overstress if spoilers are
deployed in a panic. I'd guess S/H is trying to stay ahead of the lawyers
rather than any structural or strength issue compared to DG.
As to your statement that the no-acro limitation means more effective speed
brakes, actual in-flight tests prove otherwise. Tom Knauff will remember our
stand-on-the-pedals dive test at the 2004 Seniors contest. Check with him.
Karl Striedieck
"John Smith" wrote in message
the Duo, this is not so. While flying a DG-1000 I had the opportunity to
do a formation "test dive" comparison with a Duo. We (Tom Knauff in a
Duo) got in
Old November 1st 07, 05:40 AM posted to rec.aviation.soaring
Bruce
Hi Karl
The Duo passed the same JAR - now EASA certification that the DG1000 etc. did.
That means they have to limit the speed to below Vne in a relatively shallow
dive. (30 degrees)
So you are right, they will exhibit very similar performance in a dive test. It
is possible the rearward location on the duo results in the airbrake becoming
less effective in the flare, but I doubt it.
The no aerobatics certification appears to be simply a liability limitation.
Apparently the Duo will loop and spin as well as any other high performance two
seater. Which is to say, what's the point - the glider can do it, but if you
want to do aerobatics, get a different aircraft.
The DG method of shortening the wingspan makes some sense, because it improves
the aerobatic handling. But there are compromises.
Still enjoying your Duo?
Bruce
John,
Karl Striedieck
Duo) got in
Old November 1st 07, 09:23 AM posted to rec.aviation.soaring
John Smith
etc. did.
shallow dive. (30 degrees)
limitation.
No. JAR 22 requires 30 degrees for all liders, but 45 degrees to be
certified for aerobatics and cloud flying.
Old November 2nd 07, 09:27 PM posted to rec.aviation.soaring
Bruce
Thanks John
I have a copy of JAR22, but did not read it well enough obviously. From other
posts it appears that Schempp have now decided to apply for the certification.
Since they have only just started building the first XLs I suppose we will have
to wait a while.
We will see how it flies in June 2008 I guess.
John Smith wrote:
etc. did.
limitation.
Old November 1st 07, 09:25 AM posted to rec.aviation.soaring
John Smith
http://www.schempp-hirth.com/index.php?id=130&L=1
"Duo Discus XL becomes certified for simple aerobatics!
The improved effectiveness of the airbrake system makes it now possible
for us to apply the approval for simple aerobatics including spinning."
Old November 1st 07, 11:50 AM posted to rec.aviation.soaring
Karl Striedieck
John,
Thanks for the steer. I'd appreciate some other information if you have the
time.
Is the 20 meter DG-1000 authorized for acro? If it is I'm curious about the
reason. Both ships were designed to meet JAR standards regarding strength
and dive brake performance.
Although the 20 meter DG-1000 and the original Duo have identical speed
brake (spoiler) affectivity, I would love to have a Duo X when it comes to
off field landings, as it is much better than the other two. With 95% of my
flying being in a contest environment the exposure to "rural visitations,"
as Gren Siebels called them, is high. However, the extra $45K added to the
price tag by the sagging Dollar since I bought mine cancels that dream.
Karl Striedieck
I can find on the current German version is the Duo X.
Old November 1st 07, 01:56 PM posted to rec.aviation.soaring
John Smith
With 20m it's authorized for "basic" acro, which means Loops, Turns and
erect Spins. No rolls and no negative g.
With 18m it's authorized for full aerobatics.
Because the dive brakes are *not* of equal strenght. I've never compared
side by side, but the DG1000 definitely allows for a much more sloppy
approach. (Not that I would advocate sloppy flying!) I've read that you
compared them and think both are the same, I definitely don't share your
opinion.
Fun with trailling edge dive brakes Scott Elhardt Soaring 16 May 9th 14 02:52 AM
Polar with spoilers extended? Tim Taylor Soaring 85 October 29th 07 09:16 AM
High on Final, Summary; was Polar with spoilers extended? Steve Leonard Soaring 4 October 27th 07 07:22 AM
Extended GPX Schema Paul Tomblin Products 0 September 25th 04 02:44 AM
L-13 Spoilers Scott Soaring 2 August 27th 03 06:08 AM
