![]() Bee wrote: I didn't say "future approach clearance." I said the present clearance did not make the visual applicable until a future point in space. I still don't understand what it means for the approach clearance to not be applicable. You can be given instructions with a clearance for the visual, but that doesn't mean that you are not navigating visually to the airport. Such as, at OAK they frequently say "cross 6 DME at or above 2000 feet" and at SBA they tell folks to "remain off shore until turning base." Those instructions don't delay the applicability of the clearance for the visual approach, whatever that would mean. If the controller doesn't intend on a visual to be "applicable" then why would he issue the clearance? And if it weren't "applicable" then would the OP still have been getting vectors until such time as the clearance became "applicable"? I don't think so. |
![]() Bee wrote: He was cleared to ROYCE with an altitude. Yes, but without a route. He was on vectors, and as he clarified since the first post, he was on a "right base" somewhere outside of ROYCE when he got the clearance. So how was he to get to ROYCE? Would it have been totally different had the controller said "turn final 7 miles out, cross 7 DME at or above 2000, cleared for the visual runway 12R"? So, is that a visual prior to ROYCE? If you choose to view it that way, fine just so long as you cross exactly at ROYCE at, or above, 2,000. Yes this is how I see it (except that nothing is exact). I don't know if this is a "proper" clearance or not, but I can't see what else you would do given that the controller stopped giving vectors. You are on your own in getting to ROYCE, by GPS direct, by 90 degree intercept of the localizer and then flying to ROYCE or by flying towards Texas Southern University and then turning final and descending. The pilot has to make something up and not crash into anything. That's a visual approach with an inconvenient restriction. If, at OAK, you can cross anywhere along the 6 DME at or above 2,000, that indeed is a visual approach without a route restiction. SBA example is pure visual with a noise abatement restriction. Yes I know these aren't exactly the same, I was merely giving examples of restrictions that don't cause the visual approach to be "not yet applicable" as you stated before. I still think the "not applicable" idea is wrong. |
![]() "Bee" wrote in message ... He was cleared to ROYCE with an altitude. Nothing on the OP's message required the aircraft to cross ROYCE. |
On Nov 9, 8:20 am, "Steven P. McNicoll"
wrote: "Bee" wrote in ... He was cleared to ROYCE with an altitude. Nothing on the OP's message required the aircraft to cross ROYCE. So do you think it was a malformed clearance, or the OP misheard it? What would you do and/or say if you got exactly that clearance? ("Cessna '1GS,cross ROYCE at or above 2 thousand, cleared visual approach runwy 12R. Contact the tower on 118.7." ) Thanks! John Clonts Temple, Texas |
![]() "John Clonts" wrote in message ups.com... So do you think it was a malformed clearance, or the OP misheard it? Could be either, but it's definitely one of them. What would you do and/or say if you got exactly that clearance? ("Cessna '1GS,cross ROYCE at or above 2 thousand, cleared visual approach runwy 12R. Contact the tower on 118.7." ) I'd respond, "Unable". You can't pin an aircraft down to a specific route on a visual approach, he's got to remain clear of clouds so you've got to allow him to maneuver as needed. If the controller needed the aircraft over ROYCE he should stick to the ILS approach. Why the controller issued the altitude restriction is a mystery. |
![]() "Steven P. McNicoll" wrote: So do you think it was a malformed clearance, or the OP misheard it? Could be either, but it's definitely one of them. I think I have probably mis-remembered it. Upon reflection, I believe I was most likely already on the localizer, not SW of ROYCE. However, my memory is clear about being given the visual with the crossing restriction, then being immediately cleared to land. -- Dan T-182T at BFM |
![]() "Bee" wrote in message ... What the OP stated, Approach says "Cessna '1GS,cross ROYCE at or above 2 thousand, cleared visual approach runwy 12R. Contact the tower on 118.7." I didn't say "future approach clearance." I said the present clearance did not make the visual applicable until a future point in space. And you're wrong each time you say it. |
When to descend | Dan Luke[_2_] | Instrument Flight Rules | 44 | October 14th 07 09:12 AM |
