When to descend II
Old October 31st 07, 11:16 PM posted to rec.aviation.ifr
Default When to descend II
Bee wrote:
I didn't say "future approach clearance." I said the present clearance
did not make the visual applicable until a future point in space.
I still don't understand what it means for the approach clearance to
not be applicable. You can be given instructions with a clearance for
the visual, but that doesn't mean that you are not navigating visually
to the airport.
Such as, at OAK they frequently say "cross 6 DME at or above 2000
feet" and at SBA they tell folks to "remain off shore until turning
base." Those instructions don't delay the applicability of the
clearance for the visual approach, whatever that would mean.
If the controller doesn't intend on a visual to be "applicable" then
why would he issue the clearance? And if it weren't "applicable" then
would the OP still have been getting vectors until such time as the
clearance became "applicable"? I don't think so.
Old November 1st 07, 01:19 AM posted to rec.aviation.ifr
Bee[_2_]
to the airport.
He was cleared to ROYCE with an altitude.
So, is that a visual prior to ROYCE? If you choose to view it that way,
fine just so long as you cross exactly at ROYCE at, or above, 2,000.
If, at OAK, you can cross anywhere along the 6 DME at or above 2,000,
that indeed is a visual approach without a route restiction.
SBA example is pure visual with a noise abatement restriction.
Old November 1st 07, 02:50 AM posted to rec.aviation.ifr
Yes, but without a route. He was on vectors, and as he clarified
since the first post, he was on a "right base" somewhere outside of
ROYCE when he got the clearance. So how was he to get to ROYCE?
Would it have been totally different had the controller said "turn
final 7 miles out, cross 7 DME at or above 2000, cleared for the
visual runway 12R"?
Yes this is how I see it (except that nothing is exact). I don't know
if this is a "proper" clearance or not, but I can't see what else you
would do given that the controller stopped giving vectors. You are on
your own in getting to ROYCE, by GPS direct, by 90 degree intercept of
the localizer and then flying to ROYCE or by flying towards Texas
Southern University and then turning final and descending. The pilot
has to make something up and not crash into anything. That's a visual
approach with an inconvenient restriction.
Yes I know these aren't exactly the same, I was merely giving examples
of restrictions that don't cause the visual approach to be "not yet
applicable" as you stated before. I still think the "not applicable"
idea is wrong.
Old November 9th 07, 02:20 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Bee" wrote in message ...
Nothing on the OP's message required the aircraft to cross ROYCE.
Old November 9th 07, 09:31 PM posted to rec.aviation.ifr
John Clonts
On Nov 9, 8:20 am, "Steven P. McNicoll"
"Bee" wrote in ...
So do you think it was a malformed clearance, or the OP misheard it?
What would you do and/or say if you got exactly that clearance?
("Cessna '1GS,cross ROYCE at or above 2 thousand, cleared visual
approach runwy 12R. Contact the tower on 118.7." )
Thanks!
John Clonts
Temple, Texas
Old November 9th 07, 09:49 PM posted to rec.aviation.ifr
Steven P. McNicoll
"John Clonts" wrote in message
Could be either, but it's definitely one of them.
I'd respond, "Unable". You can't pin an aircraft down to a specific route
on a visual approach, he's got to remain clear of clouds so you've got to
allow him to maneuver as needed. If the controller needed the aircraft over
ROYCE he should stick to the ILS approach. Why the controller issued the
altitude restriction is a mystery.
Old November 13th 07, 06:07 PM posted to rec.aviation.ifr
Dan Luke[_2_]
I think I have probably mis-remembered it.
Upon reflection, I believe I was most likely already on the localizer, not SW
of ROYCE.
However, my memory is clear about being given the visual with the crossing
restriction, then being immediately cleared to land.
Dan
T-182T at BFM
Old November 13th 07, 10:26 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Dan Luke" wrote in message
SW of ROYCE.
The clearance issued doesn't make sense. If the controller really needs you
over ROYCE he shouldn't issue a visual approach clearance. On a visual
approach you must remain clear of clouds and maneuvering to avoid them could
take you away from ROYCE. A visual doesn't save time when it's issued to an
aircraft on the localizer and may take longer than the IAP if cloud
avoidance is needed. The altitude restriction doesn't make any sense at
all. Terrain/obstacle avoidance is the pilot's responsibility on a visual
so it can't be for that and there isn't enough room below at 2000 MSL for
any other traffic so it can't be for separation.
When to descend Dan Luke[_2_] Instrument Flight Rules 44 October 14th 07 09:12 AM
