Aluminum composite reportedly stronger, lighter than carbon
Old November 1st 07, 03:32 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
Default Aluminum composite reportedly stronger, lighter than carbon
On Oct 26, 2:04 pm, "Roger (K8RI)" wrote:
On Fri, 26 Oct 2007 09:53:04 -0700, Fred the Red Shirt
Surface Preparation (cleaning) is extremely important as traces
or organics (from handling( will prevent adhesion of the aluminum.
Texereau recommends final cleaning by electron bombardment
in the vacuum chamber.
Which reminded me, my friend uses that plasma for the final cleaning.
Thats a lot of electronic bombardment. :-))
How big is his vacuum chamber?
What sort of vacuum pump(s) does he use?
One large enough for a 17.5" mirror is rather non-trivial. Assuming
a 20" diameter cylindrical chamber, the top and bottom would need
to support over 3000 pounds each, if the work is done at sea level.
FF
Old November 1st 07, 01:53 PM posted to rec.aviation.homebuilt
Mark Hickey
Is it really that hard to build a vacuum chamber? Seems to me that
the most pressure it'll ever experience is about 15psi (1 bar), while
it's trivial to build/buy pressure containers that can handle 10-100x
that much (positive) pressure. Certainly if building a 1 bar vessel
20" in diameter is daunting, building a submarine (or worse, a
deep-sea bathyscaphe, which have reached depths of almost 36,000 feet
below sea level, resisting a pressure of about 1,100 bar) would be
unthinkable.
Or am I missing something?
Mark "under pressure" Hickey
Old November 1st 07, 05:21 PM posted to rec.aviation.homebuilt
Maxwell
"Mark Hickey" wrote in message
unthinkable.
Maybe, maybe not. Round pressure vessels keep their shell walls in tension,
hence the more pressure the better they hold their shape. Vacuum vessels are
just the opposite, and quite often much easier to collapse than one might
naturally assume.
I can say I once built a round vacuum chamber out of rolled 1/4" aluminum.
It was approximately 18" long and 18" in diameter. The bottom was 3/8"
aluminum, and the top was 1" clear plastic. The chamber was successful with
up to an near perfect vacuum, and used many times without failure. At
maximum vacuum, the bottom would dish approximately 1/8 to 3/16" inch, an
the plastic top would dish about 1/2".
I have a chamber I use now for another purpose, but it is only 6" in
diameter. The top for it is just 3/16" tempered glass.
Hope the number might help your estimates.
Max
Old November 1st 07, 10:38 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
unthinkable.
naturally assume.
Max
You know, an ABSOLUTE vacuum is only 15 psi...
Old November 1st 07, 11:07 PM posted to rec.aviation.homebuilt
Maxwell
"cavelamb himself" wrote in message
Correct, one atmosphere, what is your point?
Old November 2nd 07, 01:24 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
Wrong.
Absolute vacuum is 0 psia.
At sea level that will be about -14.7 psig.
Go to Death Valley or underwater and it will be less.
FF
Old November 2nd 07, 05:08 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Thu, 01 Nov 2007 17:38:59 -0500, cavelamb himself
unthinkable.
naturally assume.
Max
But an 18" diameter hemisphere has how many square inches? ( forgot
the formula for the surface area of a sphere) The sides of the
chamber being 18" tall and 18" in diameter would have over 2000 sq
inches X 15 or by my calculator 30,536# Add to that the area of the
half sphere that comprises the top dome and it's quite a bit of
pressure. There's a reason these things are covered with a heavy SS
mesh.
In all my years of working around that kind of equipment I've only
seen one chamber let go, but that was memorable. :-))
Roger (K8RI)
Old November 2nd 07, 06:57 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
unthinkable.
naturally assume.
Max
To estimate the compressive force (imposed by pressure on the
top) on the cylindrical sides of the bell-jar use the cross sectional
area, not the surface area. The lateral component is carried by
the top, only the vertical component is carried to the sides.
The sides of the
mesh.
FF
Old November 2nd 07, 01:31 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
unthinkable.
naturally assume.
Ok so at 18" diameter that clear plastic dish had a surface area
of about 254 square inches, so it saw a force of about 3700 lbs,
less if you were significantly above sea level.
FF
Old November 2nd 07, 04:22 AM posted to rec.aviation.homebuilt
Maxwell
"Fred the Red Shirt" wrote in message
Yes.
Another way to consider it, is that the 18" diameter, 1/4" wall aluminum
tube has to support the approximate weight of a small SUV.
aluminum rib, aluminum spar, holes drilled but screws broken off jls Home Built 13 January 3rd 07 08:06 AM
Lighter than air... Richard Lamb Home Built 12 February 27th 06 11:16 PM
composite using aluminum windowscreen layer Allan Morrison Home Built 4 January 27th 05 01:19 PM
Composite & Carbon Fiber NW_PILOT Home Built 11 September 21st 04 06:21 PM
If I make it stronger Jdandy Home Built 9 August 30th 04 08:22 PM
