#29
On Thu, 1 Nov 2007 12:21:03 -0500, "Maxwell"
wrote: "Mark Hickey" wrote in message .. . Fred the Red Shirt wrote: How big is his vacuum chamber? What sort of vacuum pump(s) does he use? One large enough for a 17.5" mirror is rather non-trivial. Assuming a 20" diameter cylindrical chamber, the top and bottom would need to support over 3000 pounds each, if the work is done at sea level. Is it really that hard to build a vacuum chamber? Seems to me that the most pressure it'll ever experience is about 15psi (1 bar), while it's trivial to build/buy pressure containers that can handle 10-100x that much (positive) pressure. Certainly if building a 1 bar vessel 20" in diameter is daunting, building a submarine (or worse, a deep-sea bathyscaphe, which have reached depths of almost 36,000 feet below sea level, resisting a pressure of about 1,100 bar) would be unthinkable. Or am I missing something? Maybe, maybe not. Round pressure vessels keep their shell walls in tension, hence the more pressure the better they hold their shape. Vacuum vessels are just the opposite, and quite often much easier to collapse than one might naturally assume. I can say I once built a round vacuum chamber out of rolled 1/4" aluminum. It was approximately 18" long and 18" in diameter. The bottom was 3/8" aluminum, and the top was 1" clear plastic. The chamber was successful with up to an near perfect vacuum, and used many times without failure. At maximum vacuum, the bottom would dish approximately 1/8 to 3/16" inch, an the plastic top would dish about 1/2". We used to use this on glass plates to grind the corrector for a schmidt casagrain. Warp the glass with the vacuum, grind to a parabola, and then release the vacuum. In this case it took a lot more work than to explain. :-)) Roger (K8RI) I have a chamber I use now for another purpose, but it is only 6" in diameter. The top for it is just 3/16" tempered glass. Hope the number might help your estimates. Max |
aluminum rib, aluminum spar, holes drilled but screws broken off | jls | Home Built | 13 | January 3rd 07 08:06 AM |
Lighter than air... | Richard Lamb | Home Built | 12 | February 27th 06 11:16 PM |
composite using aluminum windowscreen layer | Allan Morrison | Home Built | 4 | January 27th 05 01:19 PM |
Composite & Carbon Fiber | NW_PILOT | Home Built | 11 | September 21st 04 06:21 PM |
If I make it stronger | Jdandy | Home Built | 9 | August 30th 04 08:22 PM |
