I started in 1988 and it was in there then. Nobody knew how bad the 757
was at that time, the crashes were just starting to pile up. They changed the 757 to basically a heavy in the 90's. A Guy Called Tyketto wrote: -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 In rec.aviation.piloting Steven P. McNicoll wrote: Mine would be "don't miss an approach when you don't have enough fuel to fly another one." This reminds me, and perhaps Newps could pitch in on this as well, seeing that you've been controlling for the past 15 - 20something years. When did the Wake Turbulence advisory become standard in the .65? From what I've read (I got into aviation in 2000), it happened shortly after the King Air crash at KSNA that killed the founder of In-N-Out Burger. It was concluded that the King Air had been caught in the UAL B757's wake, rolled into a steep descent and crashed. I don't have any versions of the .65 from back at that time (according to Wikipedia, it was 1993). Do you have any versions of it from that time, and did it address the Wake Turbulence advisory? |
![]() "Newps" wrote in message . .. I started in 1988 and it was in there then. Nobody knew how bad the 757 was at that time, the crashes were just starting to pile up. They changed the 757 to basically a heavy in the 90's. What planes, or how heavy does a plane need to be to get the heavy designation? What do they call the ones just below that, and do they issue wake warnings behind them? Thanks. -- Jim in NC |
![]() Morgans wrote: "Newps" wrote in message . .. I started in 1988 and it was in there then. Nobody knew how bad the 757 was at that time, the crashes were just starting to pile up. They changed the 757 to basically a heavy in the 90's. What planes, or how heavy does a plane need to be to get the heavy designation? Generally speaking a heavy is a plane that has the ability to fly at weights above 255,000 pounds, whether or not they actually are. It used to be 300,000 but they lowered it so it would include the 757 which is now for all intents and purposes now a heavy. What do they call the ones just below that, and do they issue wake warnings behind them? Large. You would issue a warning to all aircraft in the small or small plus weight class. |
Plane crashes into tree | Morgans | Piloting | 81 | January 9th 07 12:24 AM |
Plane crashes near San Carlos airport | rb | Piloting | 0 | June 19th 06 07:42 PM |
How do you get Winpilot aviation database changed? | Birdbones | Soaring | 1 | August 9th 05 04:04 PM |
Plane down - NASCAR team plane crashes... | Chuck | Piloting | 10 | October 28th 04 12:38 AM |
