Looking for a project
Old October 29th 07, 04:15 PM posted to rec.aviation.homebuilt
Dave[_16_]
Default Looking for a project
Hi all,
I'm taking a break from the corporate world and want to make something.
I'm looking for suggestions that could make your aviation life easier.
Is there a electronic gadget or widget that would make your flying or
airplane experience better?
Something for the panel or a stand alone box or something?
Thanks
Dave
take the "@@" and "_REMOVE_" out
Old October 30th 07, 08:39 AM posted to rec.aviation.homebuilt
RESO / Claude GUTH
Your welcome to join my project :
http://openavionics.sourceforge.net/
"Dave" a écrit dans le message de news:
Hi all,
Thanks
Dave
Old November 6th 07, 03:31 AM posted to rec.aviation.homebuilt
kmh1
Dave
With the good availability of boxes to do flight/engine/nav display, the
last remaining cause of untidyness on the panel is the avionics. At the
compact end of the scale many com radio's have low output and the intercoms
are awful. At the other end of the scale the units are large and heavy.
We need a compact avionics box, to match our other boxes, that incorporates
audio control, intercom, com (with listen on sby frq), and transponder.
Unless there's some technical reason they can't go together?
Regards
Mal
"Dave" wrote in message
Hi all,
Thanks
Dave
Old November 6th 07, 04:48 AM posted to rec.aviation.homebuilt
Morgans[_2_]
intercoms are awful. At the other end of the scale the units are large and
heavy.
incorporates audio control, intercom, com (with listen on sby frq), and
transponder.
I don't know about you, but in choices of home electronics, I have found it
to be a big mistake to get too many units all combined into one box.
When one part of it goes tits up, there is the problem of what to do with
all of the other stuff that still works.
I know with home electronics nowadays, they are not economical to fix, where
with avionics, they usually are worth repairing.
When one part of an "all inclusive avionics box" finally is not economical
to repair, that means you have a bunch of other functioning items that have
suddenly become useless, and will all have to be replaced to get the one
broken item replaced, which means a lot of value gets tossed out, and a lot
of money will have to be spent to get all of the previously working items
replaced.
I'm basically a tightwad, and hate to toss out a bunch of functioning stuff,
just because one part of it is broken. I would rather stick to keeping
items separate.
It _would_ be nice to see an economical package that is compact and light,
and modular in design, so that you could add functions as desired, and
replace items as needed, and still keep it all neat, easy to read, and easy
to replace.
Jim in NC
Old November 7th 07, 01:33 AM posted to rec.aviation.homebuilt
kmh1
I don't disagree with you Jim. I'm a tightwad too, but I like simplicity and
also like to reduce my workload. I was thinking along the lines of the G1000
which I have been enjoying a lot since getting used to it. Don't know what's
behind the integrated displays, whether the components are line replacable
modules or not. But I love the integrated approach.
For example on the G1000 the transponder takes up less than half the size of
a postage stamp and is controlled by soft keys that perform multiple
functions (and it automatically changes mode when you leave the ground, so
on a VFR flight you never have to touch it, don't even have to turn it on).
That type of thing would be so much better for homebuilts where panel space
is limited.
But I agree, such a system would need to be economically repairable.
Mal
"Morgans" wrote in message
and heavy.
transponder.
it to be a big mistake to get too many units all combined into one box.
where with avionics, they usually are worth repairing.
have suddenly become useless, and will all have to be replaced to get the
one broken item replaced, which means a lot of value gets tossed out, and
a lot of money will have to be spent to get all of the previously working
items replaced.
stuff, just because one part of it is broken. I would rather stick to
keeping items separate.
easy to replace.
Jim in NC
looking for a project Dave[_16_] Owning 7 October 30th 07 12:51 AM
Which Project would be best? Tim Hickey Home Built 12 September 17th 06 11:02 PM
Looking for Project to Help With Larry Telford Home Built 1 June 8th 05 08:10 PM
Winter project [email protected] Soaring 10 January 2nd 05 01:11 PM
Update on 172 project Wayne Piloting 3 March 14th 04 03:19 PM
