ELT antenna in composite planes.
Old November 7th 07, 01:43 AM posted to rec.aviation.homebuilt
Default ELT antenna in composite planes.
Cy,
That is assuming the ELT will always work. During a crash the ELT may
be destroyed and/or your personal satellite PLB may not go off if you
are injured. According to APOA, ELT failure rate is about 27% - not
too good, not good for Foster, the man with the satellite signal
watch. The 406's failure rate is about 19% - still not too good ( see
http://www.montanapilots.org/ ). At 1000 AGL with a 12/1 glide ratio
the plane is no more than about two miles from the last point - and
you roughly know the direction. But seldom APRS will not get detected
at 500 AGL. The standard ($1000+) 406 ELT accuracy is about two
miles. A $3000+ 406 will transmit your position to the satellite from
your aircraft gps navigation - assuming that your avionics will work
after the crash. Hmmm... $1000, $3000??? An APRS tracker is only
couple hundred bucks - NO subscription fees.
On Nov 5, 9:59 pm, "Cy Galley" wrote:
One doesn't crash 1000 feet in the air and line of sight is what really
works. That's why they use a satellite which helps immensely when down in
the trees and valleys
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
New address -
Transponder Antenna Ground Planes Ken Kochanski (KK) Soaring 6 April 6th 07 08:13 PM
antenna ground planes [email protected] Home Built 12 November 4th 05 11:30 PM
Metallic paint and composite antenna signal strength firstflight Home Built 23 July 26th 05 09:10 PM
Six-Place Composite? Marco Leon Piloting 24 January 23rd 05 03:18 PM
Composite workshop Marske Flying Wings Restoration 0 January 26th 04 12:03 AM
