resettable fuses - US source?
Old November 9th 07, 10:09 PM posted to rec.aviation.soaring
01-- Zero One
Default resettable fuses - US source?
"raulb" wrote in message
oups.com:
On Nov 8, 4:47 pm, ContestID67 wrote:
- Tefzel wire is absoultely the best way to go.
In a glider why is 149-392 degree F wire "the best way to go"? If
your electronic device has a connection that gets to 65 C (149 F) the
device is going to be burned up anyway.
Raul,
I, and I believe John, was speaking primarily about the power wiring,
especially from batteries to the front panel, fuses, switches, etc. In
those areas, a profound short will cause the wiring to get extremely
hotter almost instantly (if you do not have the system fused properly at
the battery terminals).
Once it heats up, most wire other than Tefzel style wire starts to melt,
smolder, and/or burn with acrid (and many times toxic) smoke and fumes.
Non electrical fires can also occur in gliders, ie, sun reflected in
canopies, etc. Again, if the fire is in a place where the 'low temp'
power wiring is, when it melts, it can short together, adding additional
heating to the fire and possibly causing an additional point of
combustion.
There is _so_ little wire in a glider, even expensive wire is cheap.
Larry "the _real_ cable guy" Goddard
01 "zero one" USA
Bussman Fuses kevmor Piloting 10 May 25th 07 03:25 AM
Bussman Fuses kevmor Piloting 2 May 22nd 07 09:28 PM
Fuses versus Breakers ContestID67 Soaring 14 March 14th 05 01:47 PM
Cortec source KEITH B SHOAPS Home Built 0 August 16th 04 10:51 PM
Source for Bolts Dave Home Built 2 May 20th 04 08:09 PM
