MMU 5 DP lost comm question
Old November 13th 07, 11:10 PM posted to rec.aviation.ifr
Peter Clark
Default MMU 5 DP lost comm question
On Tue, 13 Nov 2007 17:04:39 -0600, "Steven P. McNicoll"
"Peter Clark" wrote in message
I'd probably decline the clearance or ask for vectors SBJ instead
since I can't do the direct part, but if forced to attempt this I'd
likely fly last given heading until getting onto an intercept for SBJ
R-237 or R067, then turn towards BIGGY.
What's the direct part?
"Expect radar vectors BIGGY" then losing comms while on a vector?
Old November 13th 07, 11:19 PM posted to rec.aviation.ifr
Steven P. McNicoll
Old November 14th 07, 02:45 AM posted to rec.aviation.ifr
J.Kahn
Steven P. McNicoll wrote:
"pgbnh" wrote in message
Ummm. I think :in this day and age anyone who flies IFR in IMC WITH a GPS
handheld, which would enable you to fly direct BIGGY, is just plain
illegal.
Oh? What law would flying IFR in IMC WITH a handheld GPS violate?
Not RAIM or WAAS?
Old November 14th 07, 02:48 AM posted to rec.aviation.ifr
Steven P. McNicoll
"J.Kahn" wrote in message
Not RAIM or WAAS?
So what?
Old November 14th 07, 02:59 AM posted to rec.aviation.ifr
Ray Andraka
GPS handheld, which would enable you to fly direct BIGGY, is just
plain illegal.
Not RAIM or WAAS?
Nothing wrong with using a handheld GPS in IFR. It can't be your
primary means of navigation, meaning you should be referring to your
panel mounted nav instruments for primary. However, having a GPS adds
considerably to situational awareness, and can save your bacon in an
emergency. It is even legal to navigate using one for primary
navigation if in radar coverage and given a "vector" to the waypoint.
You tell ATC what heading you need and they give you that as a vector.
Old November 14th 07, 03:04 AM posted to rec.aviation.ifr
J.Kahn
Andrey Serbinenko wrote:
I would wait until 10 min to climb to 4000, and climb initially only to
I have two doubts about that:
First, it seems to contradict item iii of the following reg:
FAR Sec. 91.185 - IFR operations: Two-way radio communications failure.
(2) Altitude. At the highest of the following altitudes or flight levels for the route segment being flown:
(i) The altitude or flight level assigned in the last ATC clearance received;
(ii) The minimum altitude (converted, if appropriate, to minimum flight level as prescribed in .91.121(c)) for IFR operations; or
(iii) The altitude or flight level ATC has advised may be expected in a further clearance.
It lists "expected" along with everything else, and doesn't mention anywhere
that you should wait for the EFC time to pass before using it.
Secondly, while being radar-vectored I have never had to wait for ten minutes:
three-four minutes maximum, which makes me think that staying low for that
long may not in fact be desirable. In particular, staying at 2000 feet while
maneuvering in southerly direction for too long can put me in close proximity
to TEB ILS rw 6 approach path.
I should mention that I am in Canada and the IFR regs are more or less
the same, but in the Canadian AIM there is an explicit statement in
reference to altitude in a comm failure situation: "the altitude or FL
that ATC has advised may be expected in a further clearance (the pilot
shall commence climb to this altitude/FL at the time/point specified by
ATC to expect further clearance/altitude change)."
The way you quoted the FAR above it certainly implies that you should
start climbing right away. This is a significant difference in the
lost comm procedures between Can/US.
John
Old November 14th 07, 04:08 AM posted to rec.aviation.ifr
Steven P. McNicoll
"Ray Andraka" wrote in message
Nothing wrong with using a handheld GPS in IFR. It can't be your primary
means of navigation, meaning you should be referring to your panel mounted
nav instruments for primary. However, having a GPS adds considerably to
situational awareness, and can save your bacon in an emergency. It is
even legal to navigate using one for primary navigation if in radar
coverage and given a "vector" to the waypoint. You tell ATC what heading
It is even legal to navigate using a handheld GPS for primary navigation in
a radar environment without a "vector" to anywhere.
Old November 14th 07, 04:48 PM posted to rec.aviation.ifr
Wrong..
On Tue, 13 Nov 2007 08:41:19 -0500, "pgbnh"
handheld, which would enable you to fly direct BIGGY, is just plain illegal.
There are reasons that IFR certified GPS systems are certified
news
In this day and age, anyone who flies IFR in IMC withut a GPS
foolish...
On 12 Nov 2007 04:10:11 GMT, Andrey Serbinenko
A question to IR pilots.
Suppose we have the following situation: a flight departing from
MMU rw 23, cleared as follows: "Morristown 5 dep, vectors to BIGGY,
then V3, MAZIE, etc... 2000 feet, expect 4000 10 minutes after
departure, dep freq, squawk etc..."
Now, during climb-out via heading 210 we lose communication. It is IMC.
Standard question: what altitudes and routing you'd fly? The
aircraft we're flying is /U, so we can't navigate direct BIGGY.
First question: would you keep flying the DP, i.e. left turn 160?
If so, for how long would you fly heading 160 after you turn? Lost
comm instructions in the DP do not apply to us since we're southbound.
In order to get onto V3 you'd probably need to fly direct SBJ, and
proceed from there, but SBJ is not part of your clearance?
Second question -- the altitude: OROCA in the quadrant is 2900. MSA
provided by Jepp for CAT is 2000 in this sector. Would you climb
to 4000 right away, or you'd wait for 10 mins? MEAs of the airways
in that vicinity are 2300 and 3000 feet.
Andrey
Old November 14th 07, 05:31 PM posted to rec.aviation.ifr
pgbnh
"Illegal" is the wrong word. Navigating by a handheld GPS as the primary
source of navigation (as was suggested in the prior posting) is not
permitted. As an adjunct to some other, primary navigation device, certainly
GPS makes good sense.
The prior poster suggested just using the handheld to go direct BIGGY.
illegal.
Old November 14th 07, 05:34 PM posted to rec.aviation.ifr
pgbnh
See earlier post. "Illegal" was the wrong word. But, doing what you
advocated - navigating direct BIGGY using the handheld (AS THE PRIMARY NAV
SOURCE) is not permitted. The OP already indicated he could not navigate
direct BIGGY because he was not properly equipped.
Wrong..
illegal.
news
foolish...
Andrey
Lost Comm route? [email protected] Instrument Flight Rules 8 June 22nd 07 02:28 PM
Lost comm in Mexico Michael Piloting 3 January 27th 06 12:17 AM
Lost comm -- what would you do? Roy Smith Instrument Flight Rules 19 December 1st 05 03:57 PM
Lost comm procedures Ron Garret Instrument Flight Rules 12 March 8th 05 09:42 AM
Lost comm altitude? Roy Smith Instrument Flight Rules 12 January 11th 04 12:29 AM
