On Nov 14, 2:55 pm, soaringpilot2 wrote:
I've got what may be a dumb question (since I suspect the answer is obvious), but here it goes: If I am looking at buying an experimental homebuilt with a retractable conventional gear; BUT under 200hp and a fixed pitch prop, do I need a complex endorsement to legally fly, or is that just with regards to aircraft with standard airworthiness certificates (factory built)? I'm having an argument on FAR trivia, and was curious what people thought. Cheers! Ryan in Madison Which airplane are you talking about? There was some discussion around this topic regarding the Europa, which has a partially retracting monowheel. Some argued it was complex, some said no. It turned out that the insurance companies insisted that it was a complex aircraft, so whether or not it was really complex under FAA rules became a moot point (unless you are self-insured). |
Europa - partially retracting gear, flaps? and a feathering prop? sounds
complex to me. BT "Andrew Sarangan" wrote in message ... On Nov 14, 2:55 pm, soaringpilot2 wrote: I've got what may be a dumb question (since I suspect the answer is obvious), but here it goes: If I am looking at buying an experimental homebuilt with a retractable conventional gear; BUT under 200hp and a fixed pitch prop, do I need a complex endorsement to legally fly, or is that just with regards to aircraft with standard airworthiness certificates (factory built)? I'm having an argument on FAR trivia, and was curious what people thought. Cheers! Ryan in Madison Which airplane are you talking about? There was some discussion around this topic regarding the Europa, which has a partially retracting monowheel. Some argued it was complex, some said no. It turned out that the insurance companies insisted that it was a complex aircraft, so whether or not it was really complex under FAA rules became a moot point (unless you are self-insured). |
this topic regarding the Europa, which has a partially retracting monowheel. Some argued it was complex, some said no. I'm talking about the Cvjetkovich CA-65 Sky Fly (there's one on barnstormers right now). http://www.cvjetkovic-aircraft.com/ -Ryan in Madison |
FADEC = complex | Bob Gardner | Piloting | 237 | November 29th 06 01:55 AM |
Is this a Complex Plane? | [email protected] | Piloting | 12 | December 7th 05 03:19 AM |
Engine with Complex History | Mike Granby | Owning | 4 | August 30th 04 02:48 AM |
The "Complex" TAS calculation | Arnold Pieper | Soaring | 2 | December 14th 03 12:22 PM |
Complex aircraft question | Robert M. Gary | Piloting | 5 | October 17th 03 12:25 PM |
