T-6 accident
Old November 18th 07, 08:22 PM posted to rec.aviation.piloting
Big John
Default T-6 accident
On Sun, 18 Nov 2007 13:51:53 +0000 (UTC), Bertie the Bunyip
WJRFlyBoy wrote in
On Sun, 18 Nov 2007 08:12:31 +0000 (UTC), Bertie the Bunyip wrote:
This is the one I mean to post Dudley. Was having some trouble with
Youtube due to a plug-in I think..
http://www.youtube.com/watch?v=Y7eYhlm9FJ8
Can you assess the problem?
What, with my browser or the accident?
The T-6 passed 90 deg (and even earlier) with his nose below the horizon.
He could have rolled back and saved it at that point, but he continued
around in the now awkward position of having to prevent further altitude
loss with excessive neg G which slowed him considerably and further skewed
the airplane's. The exit half was a classic dish. Everybody does 'em
sometimes.... Trick is to recognise a roll that's going to produce one
early enough to abandon it. This guy didn't.
The You tube extension add-on, I have no idea, but it's made a mess out of
my youtube fun!
Bertie
Bertie
I made some comments on another post on this accident which was before
the video of the accident was posted.
I have looked at the strip probably 50 times and can't come up with
what I believe is a accurate analysis of what all happened and why.
1. Bird was in a shallow dive and picking up airspeed, above cruise,
when strip starts. This is a good entry technique.
2. Bird bottomed out and nose was raised above the horizon before roll
started. Again good technique.
3. After first 90 degrees of roll nose had dropped to at least level
or very slightly nose down.
4. After 180 degrees of roll nose was definitely below the horizon.
Not in a dive but shallow enough that continuing roll rate should have
allowed completion of roll before bird hitting ground.
5. After 270 degrees of roll bird made almost a square corner port
turn and shortly after hit the ground almost flat 90 degrees off line
of flight.
6. It did not look to me like he dished out but I don't know why the
bird made the rapid 90 degree turn off line of flight. My experience
with dish out of roll, in T-6, bird ended up at max 30 degrees off
line of flight.
7. Assuming video strip was real time, the roll was a pretty rapid
slow roll. My slow rolls were about half the roll rate of this bird.
8.Roll was against torque, which would have slowed roll down without
extra aileron.
9.Either you or Dudley talked about G forces slowing bird down. I
didn't see any large angle of attack which would be required to slow
bird down.
10. Looking at bird in video, I didn't see any reduction in airspeed
until about the time it made the 90 degree turn before impact.
Lots of comments but can't give a hard analysis of what happened from
start to finish.
Big John
A Sad Accident RL Anderson Piloting 29 October 20th 07 08:14 PM
F6F accident Larry Cauble Naval Aviation 4 October 14th 05 06:19 PM
C-130 accident Jay Honeck Piloting 28 January 11th 05 06:52 PM
MU2 accident Big John Piloting 16 April 13th 04 03:58 AM
KC-135 accident Big John Piloting 3 November 19th 03 04:36 PM
