61.113 and expense reimbursements
Old November 21st 07, 07:25 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default 61.113 and expense reimbursements
Neil Gould wrote:
Yes, but that usage renders 61.113 (c) meaningless without some
additional parameters. One can calculate many things precisely, even
without the use of a calculator. ;-) That might not guarantee
compliance with the FARs.
Pro Rata means a specific thing. It is well defined in law and common usage.
In 61.113 (c)the regulation is quite clear. A pilot may not pay less that
his pro rata share of the allowable expenses.
Now in the case of a plane rented wet it is easy (Rental price +
airport fees)/pax. If on the other hand I'm in my plane and I know
the cost of flying includes things like overhaul and maintenance
prepaids I have to deduct those before I do the math as the
regulation specifically says that I can only pro rata the fuel, oil,
airport expenditures and rental fee.
The cost of maintenance etc. is typically factored into a rental fee.
But, I think the purpose of 61.113 is to set guidelines for what might
constitute compensation. You and other travel to a work site, they can
share the cost of fuel, oil, airport expenditures and rental fees.
They can't pay you for the use of your plane and have you ferry them
about, so the closer the financing looks like that's what is going
on, the more likely one is to violating the FARs.
The purpose of 61.113 (c) is to set the items than can be shared pro rata
among a private pilot and his passengers. And it does it very well.
I'm curious where you get the 51% rule?
As has been mentioned by others, the 50% figure has been taught and
tossed around for quite a while. I don't know if its origin is
formal, was established by precedence, or just common practice. I
would be happy to find out that my company could pay the entire cost
of a flight without it becoming an issue of compensation, but that
seems a long shot unless someone can show evidence that it is an
acceptable practice. Do you know of any such evidence?
Neil
Not a long shot at all. Just read 61.113 (b). Not only can the company pick
up the tab they can pay you while you are doing it.
Old November 22nd 07, 02:07 AM posted to rec.aviation.piloting
Ron Garret
There's still an ambiguity here. The obvious way to compute the
pro-rata share is to divide the total cost by the number of passengers.
But that is not the only reasonable way to do it. One could, for
example, assign a pro-rata share according to weight, so that heavier
passengers (or passengers with more bags) pay more than lighter ones.
One could likewise use height, on the theory that taller passengers use
more room inside the plane, or some combination of weight and height.
If all the passengers are owners of the company for which business is
being conducted they might choose to assign their pro-rata shares
according to their percentage ownership in the company. None of these
are unreasonable on their face, and none of them are specifically
excluded by the regs. But I wouldn't want to be the one defending any
of these theories against an FAA enforcement action.
rg
Old November 22nd 07, 01:30 PM posted to rec.aviation.piloting
Neil Gould
Recently, Ron Garret posted:
common usage. In 61.113 (c)the regulation is quite clear. A pilot
may not pay less that his pro rata share of the allowable expenses.
passengers. But that is not the only reasonable way to do it. One
could, for example, assign a pro-rata share according to weight, so
that heavier passengers (or passengers with more bags) pay more than
lighter ones. One could likewise use height, on the theory that
taller passengers use more room inside the plane, or some combination
of weight and height. If all the passengers are owners of the company
for which business is being conducted they might choose to assign
their pro-rata shares according to their percentage ownership in the
company. None of these are unreasonable on their face, and none of
them are specifically excluded by the regs. But I wouldn't want to
be the one defending any of these theories against an FAA enforcement
action.
I also saw such ambiguities, based on the dictionary definitions of the
terms rather than their basis in law. However, the explanations by
AirplaneSense in other parts of this thread have cleared up the matter for
me. I now see that Gig 601XL Builder's comments are in agreement with the
interpretations of AirplaneSense, but were a bit terse to be enlightening.
Neil
Is expense of a new sailplane the reason? Nolaminar Soaring 0 January 7th 05 03:40 PM
expense analysis Rosspilot Owning 12 August 25th 03 03:34 AM
