On Nov 19, 7:40 pm, fred wrote:
...I would like to have a stick vibrator, ( maybe that is off the shelf)... Ask the kids where mommy keeps her pink flashlight. They probably don't know what it's for, but they might know where she hides it. So far I've built three gear warning systems from Electron Hut parts. Typically, it's a 6-volt pezio buzzer, two microswitches, and a 9-volt battery and holder. But that's pretty much what everybody does. A couple random points: * These days I'd look into replacing the buzzer with a box that plays a recorded verbal warning, maybe from a pre-recorded .wav file. Or maybe I'd just get a Yak Bak 2 toy (http://en.wikipedia.org/wiki/ Yak_Bak) and wire Play into the pair of microswitches. * I always use an independent battery for the gear warning. I don't want its function dependent on the main battery. * I mount the system parts so that I can deactivate the gear warning if it accidently gets stuck on. I can either pull the battery or disconnect its wire or break one of the switches. * I either mount the system parts so that I can test its function during pre-takeoff, or I add a test switch to do so. * I never run the buzzer longer than necessary to test its function. I don't want to become inured to it. Thanks, Bob K. |
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 13th 07 01:50 PM |
GPS396 terrain warnings near airports | xyzzy | Owning | 5 | January 4th 06 07:02 PM |
GPS 396 audio terrain warnings | Dave Butler | Owning | 18 | December 17th 05 02:21 AM |
"Brake failures of Hornet prompt military warnings" | [email protected] | Naval Aviation | 0 | August 5th 05 04:07 PM |
Aviation Conspiracy: FAA Ignored 911 Attack Warnings!!! | TGM | General Aviation | 1 | February 16th 05 11:31 AM |
