On Sun, 25 Nov 2007 07:55:05 +0000 (UTC), Bertie the Bunyip
wrote: "Darkwing" theducksmailATyahoo.com wrote in m: "Bertie the Bunyip" wrote in message .. . Phil wrote in news:dc605aa6-d47d-4121-bcdd- : On Nov 24, 2:07 pm, Bertie the Bunyip wrote: No, you really can;'t abruptly do anything in an Airbus in the flight mode he would have been in at cruise. The computer won't let you? What if you need to maneuver abruptly to avoid a collision? That's right. It won't let you manuever more thna a given acceleration for the flight mode you are in,particulaly at high alt due to mahc manuevering considerations. Can't give you numbers because I'm not flying one at the moment. I know basically zero about high altitude flying, what are the considerations? Does it have a lot to due with being close to the envelope between flying and stalling in the thin air? Not exactly. Indicated stall speed remains constant with altitude. What does come into play is mach buffet. On the high end of the speed envelope , obviously, you have the air accelerating around the airplane and over the top of the wing and that gives you a buffet which destroys lift. But if you slow the airplane down you have to increase alpha to maintain your line of flight and the increased alpha will accelerate the air over the top of the wing to supersonic even though the airplane is going slower than it was in cruise. Anything that increases the angle of attack, such as putting more weight in the airplane will bring the minimum and maximum speed closer to your cruise speed reducing yuor buffet margins. This means higher weights bring the max altitude down. Loading the wing up with G either by manuevering or an encounter with turbulence and even a forward CG will bring the buffet on sooner, which is why some airplanes pump fuel into the tail after takeoff once the autopilot is engaged. . The one that comes into play here is the G consideration. They were light, so they actually had quite a lot of G available to manuever, but still, if you screw up at either end of the envelope, you have a big problem. By the way, some airplanes operate with a margin of as little as 1.25G. To give this some perspective, a thirty deg bank is 1.15 G. These would be mostly medium long haul operators doing it to save fuel. The margins depend on type.. most are more like 1.4 G. If the airplane falls over, there's a good chance you'll end up through the high end of envelope (too fast) and if that happens three things happen to conspire to screw you. One, the center of pressure shifts back on the wing bringing the nose down, which tends to increase speed, which exacerbates the problem. Two, the center section of the wing is affected more because of Area rule. the fuselage has already accelerated the air when it meets the wing, so the center of the wing is affected more thsan the tips, and since the center of the wing is mostly ahead of the CG the loss of lift there brings the nose down and increases sped which exacerbates the problem. This is mach tuck and though it isn't directly caused by pulling excessive G it is the likely end result of an upset at altitude. The third factor in mach tuck is the stab. As you try pulling the nose up as it's coming down, the increased camber of the stab (wrong way round, f course) will accelerate the air to supersonic levels and buffet the stab. Presto, no elevator control and you're dead. Whatever it was that started that Egyptair airplane down over the Atlantic, what finished them off was Mach tuck. If it develops past a certain point there is almost nothing you can do. So, Airbus have, for better or worse, decided to allow the airplane itself to monitor these inflight parameters and not to allow it to do anything too funky G wise. In reality, it hasn't worked so well. They seem to have just as many upsets as any other aircraft. BTW, a Cessna 172 would have these same problems if you were to get it high enough! There are some high performance homebuilts with blowers that need mach meters, but if you get any airplane up high enough you have mach issues. The airplane they're planning on sending to Mars fits into this category. It's going to be cruising at the equivelant of somthing like a 150,000 even though it's near the surface. I thing they're planning on a 250 knot TAS for it and that will be very tight at those sorts of pressures. Or maybe we should ask Anthony to check it out on his new version of X-plane! Version 9 is out now Anthony! Better get your order in! I'm sure the outpouring of wisdom will wash us away like the great flood. Bertie Bertie and all To add some to your data. The B-47 had what was called the "coffen corner". At high altitude the airspeed was just above the stall and if you increased your airspeed you were into Mach. This required very close attention by B-47 drivers. Big John |
Big John wrote in
: The B-47 had what was called the "coffen corner". At high altitude the airspeed was just above the stall and if you increased your airspeed you were into Mach. This required very close attention by B-47 drivers. Yeah, it's petty much the same with any transonic aircraft. Technically, though, what you had at the low end wasn't a stall, though it's commonly referred to as such. The end result was the same (plummeting to earth) but the biggest difference was that it happened well above indicated stall speed and well below crit Alpha. But even the FAA call it a stall in their advisory material. http://rgl.faa.gov/Regulatory_and_Gu...Circular.nsf/0 /e04e9b9732ba93fd86256caa005ca97e/$FILE/AC61-107A.pdf You probably flew looser margins than we do, in fact. I've flown with about ten knots either direction to buffet, but it's a non-event with us in coffin corner because of the more sophisticated autopilots and autothrottles. In the U2 they flew with a +/- 2 knot margin! The autopiot did th ework and they let the altitude do what it wanted in deference to speedkeeping. Bertie |
airbus - Latest Plane From Airbus.jpg | [email protected] | Aviation Photos | 14 | June 26th 07 09:41 AM |
Which is easier: Boeing to Airbus, or Airbus to Boeing? | Mxsmanic | Piloting | 9 | February 21st 07 01:58 AM |
What a week.. | Capt.Doug | Piloting | 11 | February 20th 07 03:25 AM |
No NYC Fleet Week TFR? | Marco Leon | Piloting | 8 | June 1st 06 10:59 PM |
This week | DHeitm8612 | General Aviation | 0 | January 21st 05 01:19 AM |
