Bad Week for Airbus
Old November 25th 07, 05:28 AM posted to rec.aviation.piloting
Phil
Default Bad Week for Airbus
On Nov 24, 9:04 pm, Judah wrote:
Phil wrote :
On top of last week's A340 incident, now an A330 experienced a sudden
depressurization on a shakedown flight. Among the injuries to
What exactly is a shakedown flight? Is that when a bunch of guys in white
suits with crooked noses make sure they get their vig of the flight time?
If they don't get their vig, they decompress the plane!
Old November 25th 07, 05:52 AM posted to rec.aviation.piloting
Darkwing
"Mxsmanic" wrote in message
news
Phil writes:
Amazing. I never would have guessed that you could get a spinal
injury from the decompression itself.
Bubbles in the CNS after sudden decompression can cause serious
neurological
symptoms and persistent sequelae, but it's a very rare complication.
Is there anything you aren't an expert on??
Old November 25th 07, 05:53 AM posted to rec.aviation.piloting
Darkwing
"Phil" wrote in message
Oh at least break the landing gear struts.
Old November 25th 07, 05:57 AM posted to rec.aviation.piloting
Darkwing
Phil wrote in
On Nov 24, 2:07 pm, Bertie the Bunyip wrote:
No, you really can;'t abruptly do anything in an Airbus in the flight
mode he would have been in at cruise.
The computer won't let you? What if you need to maneuver abruptly to
avoid a collision?
That's right. It won't let you manuever more thna a given acceleration for
the flight mode you are in,particulaly at high alt due to mahc manuevering
considerations. Can't give you numbers because I'm not flying one at the
moment.
I know basically zero about high altitude flying, what are the
considerations? Does it have a lot to due with being close to the envelope
between flying and stalling in the thin air?
Old November 25th 07, 07:55 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
"Darkwing" theducksmailATyahoo.com wrote in
Phil wrote in
news:dc605aa6-d47d-4121-bcdd-
flight mode he would have been in at cruise.
to avoid a collision?
acceleration for the flight mode you are in,particulaly at high alt
due to mahc manuevering considerations. Can't give you numbers
because I'm not flying one at the moment.
envelope between flying and stalling in the thin air?
Not exactly. Indicated stall speed remains constant with altitude. What
does come into play is mach buffet. On the high end of the speed
envelope , obviously, you have the air accelerating around the airplane
and over the top of the wing and that gives you a buffet which destroys
lift. But if you slow the airplane down you have to increase alpha to
maintain your line of flight and the increased alpha will accelerate the
air over the top of the wing to supersonic even though the airplane is
going slower than it was in cruise.
Anything that increases the angle of attack, such as putting more weight
in the airplane will bring the minimum and maximum speed closer to your
cruise speed reducing yuor buffet margins. This means higher weights
bring the max altitude down. Loading the wing up with G either by
manuevering or an encounter with turbulence and even a forward CG will
bring the buffet on sooner, which is why some airplanes pump fuel into
the tail after takeoff once the autopilot is engaged. .
The one that comes into play here is the G consideration. They were
light, so they actually had quite a lot of G available to manuever, but
still, if you screw up at either end of the envelope, you have a big
problem. By the way, some airplanes operate with a margin of as little
as 1.25G. To give this some perspective, a thirty deg bank is 1.15 G.
These would be mostly medium long haul operators doing it to save fuel.
The margins depend on type.. most are more like 1.4 G.
If the airplane falls over, there's a good chance you'll end up through
the high end of envelope (too fast) and if that happens three things
happen to conspire to screw you. One, the center of pressure shifts back
on the wing bringing the nose down, which tends to increase speed, which
exacerbates the problem. Two, the center section of the wing is affected
more because of Area rule. the fuselage has already accelerated the air
when it meets the wing, so the center of the wing is affected more thsan
the tips, and since the center of the wing is mostly ahead of the CG the
loss of lift there brings the nose down and increases sped which
exacerbates the problem. This is mach tuck and though it isn't directly
caused by pulling excessive G it is the likely end result of an upset at
altitude.
The third factor in mach tuck is the stab. As you try pulling the nose
up as it's coming down, the increased camber of the stab (wrong way
round, f course) will accelerate the air to supersonic levels and buffet
the stab. Presto, no elevator control and you're dead.
Whatever it was that started that Egyptair airplane down over the
Atlantic, what finished them off was Mach tuck. If it develops past a
certain point there is almost nothing you can do.
So, Airbus have, for better or worse, decided to allow the airplane
itself to monitor these inflight parameters and not to allow it to do
anything too funky G wise. In reality, it hasn't worked so well. They
seem to have just as many upsets as any other aircraft.
BTW, a Cessna 172 would have these same problems if you were to get it
high enough! There are some high performance homebuilts with blowers
that need mach meters, but if you get any airplane up high enough you
have mach issues. The airplane they're planning on sending to Mars fits
into this category. It's going to be cruising at the equivelant of
somthing like a 150,000 even though it's near the surface. I thing
they're planning on a 250 knot TAS for it and that will be very tight at
those sorts of pressures.
Or maybe we should ask Anthony to check it out on his new version of
X-plane!
Version 9 is out now Anthony! Better get your order in! I'm sure the
outpouring of wisdom will wash us away like the great flood.
Bertie
TheSmokingGnu
Or run the engines up and then loosen the chocks (!)
TheSmokingGnu
Mxsmanic wrote in
news
Phil writes:
neurological symptoms and persistent sequelae, but it's a very rare
complication.
Get the newest computer edition of "operation" did you?
Bertie
  #28
Old November 25th 07, 08:08 AM posted to rec.aviation.piloting
Bob Fry wrote in :
"BB" == Bertie the Bunyip writes:
BB An explosive decompression can do a lot of damage to the
BB body. Sinuses, ears lungs..
"Explosive decompression (ED) refers to a sudden marked drop in the
pressure of a system that occurs in less than 0.1 seconds, associated
with explosive violence. Generally it results from some sort of
material fatigue or engineering failure, causing a contained system to
suddenly vent into the external atmosphere."
http://en.wikipedia.org/wiki/Explosive_decompression
Not a chance the Airbus experienced *explosive* decompression.
Sure there is. Cargo door opening. Structural tear pulling a panel off.
Happens.
Bertie
  #29
Old November 25th 07, 08:31 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Phil writes:
Actually the flight attendant says it in every pre-flight emergency
briefing. You are right that it is a simple concept, and I don't know
anyone who is too stupid to understand it.
Then why do flight attendants point it out on every flight?
Because they've considered that you might be on the flight.
Oh wait. that can't be it either. You don't fly.
Bertie
  #30
Old November 25th 07, 08:36 AM posted to rec.aviation.piloting
Mxsmanic wrote in
nobody writes:
It's really a pretty simple concept, but I've never had it explained
on an airline. I don't understand how someone could draw a conclusion
that parents are too 'stupid' to understand.
If they aren't stupid, they'll figure out for themselves why they
should put on their own masks first.
Bwawahhwhahwhahwhahwhhahwhahwhhawhahwhahwhahwhahwh hahwhahwhahwhhawhhahwhahw
hahwhhahwhahwhahwhahwhhawhhawhhahwhahwhahwhahwhahw hahwhahwhahwhahwh!
Yeah, nost natural thing in the world, being thrust into a world where the
air is so thin the molecule have RFD postboxes.
Moron.
Bertie
airbus - Latest Plane From Airbus.jpg [email protected] Aviation Photos 14 June 26th 07 09:41 AM
Which is easier: Boeing to Airbus, or Airbus to Boeing? Mxsmanic Piloting 9 February 21st 07 01:58 AM
What a week.. Capt.Doug Piloting 11 February 20th 07 03:25 AM
No NYC Fleet Week TFR? Marco Leon Piloting 8 June 1st 06 10:59 PM
This week DHeitm8612 General Aviation 0 January 21st 05 01:19 AM
