2cernauta2 wrote:
Wouldn't it be possible to locate the winch outside the airfield's boundary, and launch with a longer rope on a 600m runway? Is this common practice at some glider sites? If geography allows you to retrieve the cable (no bushes, roads, walls, rivers, whatever between start place and winch), if the safety of uninvolved persons is not compromised, if there's no road, house, whatever the cable can fall onto, if you can find an agreement with the farmers whose fields you will cross while retrieveing the cable... and be sure there's no regulation which prohibits cables above a certain height. If you can fulfill all these requirements, then it would certainly be worth to give it a try. |
![]() "John Smith" wrote in message ... 2cernauta2 wrote: Wouldn't it be possible to locate the winch outside the airfield's boundary, and launch with a longer rope on a 600m runway? Is this common practice at some glider sites? If geography allows you to retrieve the cable (no bushes, roads, walls, rivers, whatever between start place and winch), if the safety of uninvolved persons is not compromised, if there's no road, house, whatever the cable can fall onto, if you can find an agreement with the farmers whose fields you will cross while retrieveing the cable... and be sure there's no regulation which prohibits cables above a certain height. If you can fulfill all these requirements, then it would certainly be worth to give it a try. I would speculate that Spectra or Dyneema is a lot more forgiving in this regard. It's possible that sites unsuitable for steel cable would be workable if Spectra or Dyneema is used. Steel cable is heavy and can damage anything it falls on. Because it forms kinks and weak points, is easier to break. It's electrically conductive so power lines are an extreme hazard. Spectra or Dyneema is so light that it 'floats down' more than falls so is unlikely to damage anything unless it is pulled across something under tension or the connecting hardware does the damage. It's also a very poor conductor. Bill Daniels |
On Nov 26, 3:03 pm, John Smith wrote:
2cernauta2 wrote: Wouldn't it be possible to locate the winch outside the airfield's boundary, and launch with a longer rope on a 600m runway? Is this common practice at some glider sites? If geography allows you to retrieve the cable (no bushes, roads, walls, rivers, whatever between start place and winch), if the safety of uninvolved persons is not compromised, if there's no road, house, whatever the cable can fall onto, if you can find an agreement with the farmers whose fields you will cross while retrieveing the cable... and be sure there's no regulation which prohibits cables above a certain height. If you can fulfill all these requirements, then it would certainly be worth to give it a try. And if cable breaks at *all* heights can be safely dealt with... |
How to get maximum height on a winch launch? | Dan G | Soaring | 38 | December 22nd 16 12:29 AM |
Winch launch speed versus height gain | Neil | Soaring | 20 | November 9th 07 12:57 AM |
Record Highs/Record Lows | Jay Honeck | Piloting | 12 | October 12th 06 01:27 AM |
Perlan height record in Argentina | Charles Yeates | Soaring | 3 | September 1st 06 12:59 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
