On Nov 26, 11:31 pm, Stefan wrote:
george schrieb: Point out to me where I am wrong... Your mistake is, that the quantity of gas which can be solved in water is proportional to pressure. So you mustn't think in absolute quantities, but in relative. Going from a short exposure of low pressure to a longer period of exposure to a higher presure will have no effect on soluble gases in the bloos stream. The only time that becomes a factor is if the subject has been SCUBA diving and using decompression time. Example: At flightlevel 360 (give or take a few) the atmospheric pressure has dropped to roughly a quarter. So, solutionwise, climbing from sea level to FL360 has roughly the same effect as a diver which climbs from a water depth of 100ft to the surface (at sea level). Now if you're saturated at 100ft (and we are saturated!), and then suddenly go up to the surface, you *will* encounter serious decompression disease. I would expect the same in a sudden pressure loss at FL360. The pressure at 100 feet (to use your figures) is approx 4 atmospheres = 56 psi The barometric pressure at sea level is 14.7 psi. A change of pressure of 44 psi. or about 4048 mb Decompression at altitude is covered in the Regs that specify the longest permitted time before descent has to be initiated. The pressure difference between Fl30 and Fl10 is about 30 mb. Of course the two situations are not exactly the same, because in aviation there is a much smaller quantity of gas involved. (Besides that the cabin pressure is usually not equal to sea level but to something like 7000ft.) I would expect some air forces to have seriously studied this, and plenty of literature to be available, because the climb rate of fighter jets allow for such critical pressure changes. But frankly, I don't know anything about it, except that your reasoning was wrong. But then, at the climb rate my glider gives me, I guess that I needn't to worry anyway, even in strong wave. The Diamond height is yet to come eh :-) |
george writes:
Going from a short exposure of low pressure to a longer period of exposure to a higher presure will have no effect on soluble gases in the bloos stream. It will, however, add a bit more gas in solution to the blood and body tissues. |
Mxsmanic wrote in
: george writes: Going from a short exposure of low pressure to a longer period of exposure to a higher presure will have no effect on soluble gases in the bloos stream. It will, however, add a bit more gas in solution to the blood and body tissues. nope Bertie |
Sorry, Bertie: exposure to higher ambient pressures does in fact drive
gasses into solution in our blood and tissue. See Strong's Physical Chemistry text (God, I'm dating myself -- that might have been published in the 60s!). Sco Bertie 2,531 Mx 1 On Nov 27, 1:41 am, Bertie the Bunyip wrote: Mxsmanic wrote : Going from a short exposure of low pressure to a longer period of exposure to a higher presure will have no effect on soluble gases in the bloos stream. It will, however, add a bit more gas in solution to the blood and body tissues. nope Bertie |
Tina wrote in
: Sorry, Bertie: exposure to higher ambient pressures does in fact drive gasses into solution in our blood and tissue. See Strong's Physical Chemistry text (God, I'm dating myself -- that might have been published in the 60s!). I know, we had to do that in piloty school He's still worng. Bertie Sco Bertie 2,531 Mx 1 On Nov 27, 1:41 am, Bertie the Bunyip wrote: Mxsmanic wrote : Going from a short exposure of low pressure to a longer period of exposure to a higher presure will have no effect on soluble gases in the bloos stream. It will, however, add a bit more gas in solution to the blood and body tissues. nope Bertie |
I understand mx being wrong even when he happens to be correct. It's
the principle of the thing. I will retract and correct the scoring, based on that. On Nov 27, 11:32 am, Bertie the Bunyip wrote: Tina wrote : Sorry, Bertie: exposure to higher ambient pressures does in fact drive gasses into solution in our blood and tissue. See Strong's Physical Chemistry text (God, I'm dating myself -- that might have been published in the 60s!). I know, we had to do that in piloty school He's still worng. Bertie Sco Bertie 2,531 Mx 1 On Nov 27, 1:41 am, Bertie the Bunyip wrote: Mxsmanic wrote : Going from a short exposure of low pressure to a longer period of exposure to a higher presure will have no effect on soluble gases in the bloos stream. It will, however, add a bit more gas in solution to the blood and body tissues. nope Bertie- Hide quoted text - - Show quoted text - |
Tina wrote in
: I understand mx being wrong even when he happens to be correct. It's the principle of the thing. Xachery. I will retract and correct the scoring, based on that. Thenk yew. At least it;s one bit of history that will be accurate. Bertie |
On Tue, 27 Nov 2007 08:00:25 -0800 (PST), Tina wrote:
Sorry, Bertie: exposure to higher ambient pressures does in fact drive gasses into solution in our blood and tissue. See Strong's Physical Chemistry text (God, I'm dating myself -- that might have been published in the 60s!). Jeez, I still have the text on my shelf ![]() -- Remove numbers for gmail and for God's sake it ain't "gee" either! |
Well, it IS a good reference and reminder, isn't it?
On Nov 28, 2:18 am, WJRFlyBoy wrote: On Tue, 27 Nov 2007 08:00:25 -0800 (PST), Tina wrote: Sorry, Bertie: exposure to higher ambient pressures does in fact drive gasses into solution in our blood and tissue. See Strong's Physical Chemistry text (God, I'm dating myself -- that might have been published in the 60s!). Jeez, I still have the text on my shelf ![]() -- Remove numbers for gmail and for God's sake it ain't "gee" either! |
No doubt, still use it, feeling older by the nanosecond now.
On Wed, 28 Nov 2007 03:40:31 -0800 (PST), Tina wrote: Well, it IS a good reference and reminder, isn't it? On Nov 28, 2:18 am, WJRFlyBoy wrote: On Tue, 27 Nov 2007 08:00:25 -0800 (PST), Tina wrote: Sorry, Bertie: exposure to higher ambient pressures does in fact drive gasses into solution in our blood and tissue. See Strong's Physical Chemistry text (God, I'm dating myself -- that might have been published in the 60s!). Jeez, I still have the text on my shelf ![]() -- Remove numbers for gmail and for God's sake it ain't "gee" either! -- Remove numbers for gmail and for God's sake it ain't "gee" either! |
airbus - Latest Plane From Airbus.jpg | [email protected] | Aviation Photos | 14 | June 26th 07 09:41 AM |
Which is easier: Boeing to Airbus, or Airbus to Boeing? | Mxsmanic | Piloting | 9 | February 21st 07 01:58 AM |
What a week.. | Capt.Doug | Piloting | 11 | February 20th 07 03:25 AM |
No NYC Fleet Week TFR? | Marco Leon | Piloting | 8 | June 1st 06 10:59 PM |
This week | DHeitm8612 | General Aviation | 0 | January 21st 05 01:19 AM |
