Confusion
Old November 27th 07, 07:33 PM posted to rec.aviation.ifr
Patrick
Default Confusion
Jon,
The turn should have started at 400 agl, right?
On Nov 27, 1:14 pm, "Jon Woellhaf" wrote:
I recently filed IFR and received a clearance from Ground. As part of the
clearance, I was told, "... after departure turn left heading 300 ..." I
taxied to the active, did my run-up, called Tower and said I was ready for
departure. I was soon cleared for takeoff.
At about 1000 AGL, I began the left turn to 3000.
About a minute later, when I hadn't yet been told to contact departure, I
asked Tower if they wanted me to contact departure. That's when the
confusion began. The controller said, "I didn't know you wanted to go to
departure, but, yeah, you can contact departure. Good day." "Well, I'm IFR,"
I replied. After a brief pause, Tower said, "Roger. Do me a favor, squawk
1200. I can't give you departure. You didn't tell me you were IFR. I didn't
get you a release."
I said I'd proceed on course VFR and asked if they'd get me a clearance.
They soon got it and handed me off to departure.
Guess I'll remember to remind Tower that I'm IFR from now on, although I
didn't think that was necessary. At least in this case, it was.
Jon
Old November 27th 07, 09:14 PM posted to rec.aviation.ifr
Jon Woellhaf
Default Confusion
"Patrick" wrote in message
Jon,
I normally turn at 400 to 500 AGL, but in this case a turn at that altitude
would have put me into the path of a 172 that had departed from the parallel
runway. Tower had called the traffic, although he said the traffic was going
to make a right crosswind turn, when he meant left.
And BTW, I was told to turn left heading 300, not 3000. (That's the hard way
to get to 120. g)
Old November 30th 07, 10:51 AM posted to rec.aviation.ifr
Sam Spade
Default Confusion
Patrick wrote:
Jon,
When the weather is less than VFR, yes. If it is VFR your first
responsbility is to exactly what he did because of the conflicting VFR
traffic.
CAI 302 Utility program confusion Frank[_1_] Soaring 1 March 30th 07 03:57 AM
Confusion about when it's my navigation, and when it's ATC Mxsmanic Piloting 258 January 18th 07 11:52 PM
Confusion about when it's my navigation, and when it's ATC Mxsmanic Instrument Flight Rules 332 January 18th 07 11:52 PM
Confusion Plus Kevin Berlyn Home Built 1 March 6th 05 06:40 AM
confusion G.A. Seguin Soaring 0 July 14th 04 12:08 AM
