Maintenance
Old November 27th 07, 11:17 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Maintenance
On Nov 27, 12:25 am, "Bert Willing" bw_no_spam_ple...@tango-
whisky.com wrote:
Yes. You don't lubricate cables in the first place.
If you're like me, you remember reading that advice in an old copy of
AC43.13, complete with references to long-obsolete lubricants like
"Par-L-Ketone." From memory, 43.13 said to not oil cables because
lubricants thin enough to get to the cable core will just displace the
factory lubricant and make them more, not less, susceptible to
internal friction and internal corrosion.
However, in the 1998 edition of AC43.13, Chapter 7 seems to have been
revamped, and makes several reasonable recommendations about
inspecting and lubing cables and what to lube them with (MIL-C-16173,
grade 4, or MIL-C-11796, Class I, if you can find them). It also
describes nylon-jacketed cables, which I believe is a newish
development.
My own recommendation would be to avoid thinned oils like tri-flow for
unsheathed cables. As much as I like Tri-Flow as a general lubricant,
it tends to leave a sticky surface, and its solvents might tend to
wash away more of the internal lubricant than it applies. Those waxy
dry lubricants now available for bicycles might be a good bet, since
they tend to leave a dry, tack-free surface that does not attract
abrasive particles. I use that stuff on the cables and pivots of my
climbing gear, and it seems to work a treat.
Thanks, Bob K.
Old November 29th 07, 07:41 PM posted to rec.aviation.soaring
Doug Hoffman
Default Maintenance
The following relates the actual experience an HP-14 owner had
with lubricants and dirt. Source is Wayne Paul's HP web site. It
supports Bob Kuykendall's assertion that careful selection of
lubricant is important, if one chooses to lubricate at all.
"I have had to replace all of the cables, the previous owner had
greased them at the fairleads, and they picked up dirt and got
badly worn very fast. I also replaced the aileron pushrods, as
they also had been greased at the guides, and ended up with wear
marks. "
Regards,
Doug
Posted via a free Usenet account from http://www.teranews.com
Old November 29th 07, 03:08 PM posted to rec.aviation.soaring
Default Maintenance
"Doug Hoffman" wrote in message
marks. "
At the time of cable/push-rod replacement, the HP-14 was 27 years old;
however, only had 167 hours of flight time. I thought I had purchased an
inexpensive sailplane, but in fact I had purchased a cheap sailplane.
(http://www.soaridaho.com/Schreder/HP-14/N990/N990.html)
HP-14 "6F"
SZD55 Maintenance icsonka Soaring 6 October 13th 06 05:13 AM
Maintenance and Insurance AceHyflyer Owning 12 July 27th 06 05:01 AM
What do you do about maintenance? Andrew Gideon Owning 5 July 2nd 06 04:00 PM
Maintenance Personel Charles Talleyrand Naval Aviation 6 August 5th 03 11:35 PM
B-25 Maintenance Randy Military Aviation 1 July 11th 03 03:37 AM
