Confusion
Old November 27th 07, 09:56 PM posted to rec.aviation.ifr
Default Confusion
Whenever you are cleared for takeoff and do not get some kind of
instruction from tower (fly runway heading, turn left xxx., etc), be
suspicious.
On Tue, 27 Nov 2007 11:14:36 -0700, "Jon Woellhaf"
I recently filed IFR and received a clearance from Ground. As part of the
clearance, I was told, "... after departure turn left heading 300 ..." I
taxied to the active, did my run-up, called Tower and said I was ready for
departure. I was soon cleared for takeoff.
At about 1000 AGL, I began the left turn to 3000.
About a minute later, when I hadn't yet been told to contact departure, I
asked Tower if they wanted me to contact departure. That's when the
confusion began. The controller said, "I didn't know you wanted to go to
departure, but, yeah, you can contact departure. Good day." "Well, I'm IFR,"
I replied. After a brief pause, Tower said, "Roger. Do me a favor, squawk
1200. I can't give you departure. You didn't tell me you were IFR. I didn't
get you a release."
I said I'd proceed on course VFR and asked if they'd get me a clearance.
They soon got it and handed me off to departure.
Guess I'll remember to remind Tower that I'm IFR from now on, although I
didn't think that was necessary. At least in this case, it was.
Jon
Old November 28th 07, 11:03 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
Default Confusion
suspicious.
"... after departure turn left heading 300 ..." was part of the
clearance.
Old November 30th 07, 01:00 PM posted to rec.aviation.ifr
Default Confusion
Part of the takeoff clearance?
On Wed, 28 Nov 2007 15:03:04 -0800 (PST), "Steven P. McNicoll"
suspicious.
clearance.
Old November 30th 07, 01:24 PM posted to rec.aviation.ifr
Steven P. McNicoll
Default Confusion
Part of the IFR clearance.
Old December 1st 07, 04:22 AM posted to rec.aviation.ifr
Default Confusion
I was speaking of the takeoff clearance, to wit:
"Whenever you are cleared for takeoff and do not get some kind of
suspicious."
On Fri, 30 Nov 2007 07:24:48 -0600, "Steven P. McNicoll"
Old December 1st 07, 10:30 AM posted to rec.aviation.ifr
Steven P. McNicoll
Default Confusion
suspicious."
That wasn't the case here. The OP had an instruction like that from the
tower, it was issued by ground control as part of the IFR clearance. No
reason to be suspicious.
Old December 1st 07, 12:04 PM posted to rec.aviation.ifr
Default Confusion
When I am IFR, and the tower does not issue some heading instruction
on takeoff, I get suspicious, and I double check. More often than
not (not always), I have found the situation to be as described - the
tower didn't get the word. So the risk/reward has been favorable.
Your experience may be different.
On Sat, 1 Dec 2007 04:30:37 -0600, "Steven P. McNicoll"
suspicious."
Old November 29th 07, 12:06 AM posted to rec.aviation.ifr
Robert M. Gary
Default Confusion
suspicious.
Have you ever not been given such instructions when VFR?? I've never
gotten a VFR takeoff clearance that didn't include some instruction on
what heading (or at least direction) to fly until leaving the class D.
-Robert
Old November 29th 07, 12:39 PM posted to rec.aviation.ifr
Ron Natalie
Default Confusion
suspicious.
From class B's and certain class C's it was given to me prior to
taxi. The Dulles standard VFR departure is:
Cleared into the class B via fly runway heading maintain vfr at
or below 1500 departure frqeuency 126.1 squawk 0423
Very unusual at class D towers to be given any restriction after
takeoff.
CAI 302 Utility program confusion Frank[_1_] Soaring 1 March 30th 07 03:57 AM
Confusion about when it's my navigation, and when it's ATC Mxsmanic Piloting 258 January 18th 07 11:52 PM
Confusion about when it's my navigation, and when it's ATC Mxsmanic Instrument Flight Rules 332 January 18th 07 11:52 PM
Confusion Plus Kevin Berlyn Home Built 1 March 6th 05 06:40 AM
confusion G.A. Seguin Soaring 0 July 14th 04 12:08 AM
