Newps wrote:
The aircraft called ground control when he was done with his runup and said he was ready for the clearance. GC read him the clearance and then gave the strip to the data man for the release. Every clearance was as filed. Always. There's nothing to digest if you flight planned properly. You've obviously never flown in the North East then. Unless you've flown the exact route several times, know the traffic patterns currently in use around NYC, and have a spate of good luck, you will usually get a full route clearance. The preferred routes in the ugly green book are not always the ones used either. Except for the relatively rare cleared as filed, you'll have something to digest and a new flight plan to put into the GPS before you are ready to depart. I always call for my clearance before engine start, and almost always get the clearance then as well. On routes that I fly frequently, I often do get the route I filed, but even then they often give it as either a full or partial route clearance. |
![]() Ray Andraka wrote: Newps wrote: The aircraft called ground control when he was done with his runup and said he was ready for the clearance. GC read him the clearance and then gave the strip to the data man for the release. Every clearance was as filed. Always. There's nothing to digest if you flight planned properly. You've obviously never flown in the North East then. Unless you've flown the exact route several times, know the traffic patterns currently in use around NYC, and have a spate of good luck, you will usually get a full route clearance. The preferred routes in the ugly green book are not always the ones used either. Except for the relatively rare cleared as filed, you'll have something to digest and a new flight plan to put into the GPS before you are ready to depart. I always call for my clearance before engine start, and almost always get the clearance then as well. On routes that I fly frequently, I often do get the route I filed, but even then they often give it as either a full or partial route clearance. I said that already. This was North Dakota. There are no airspace issues. At all. |
CAI 302 Utility program confusion | Frank[_1_] | Soaring | 1 | March 30th 07 03:57 AM |
Confusion about when it's my navigation, and when it's ATC | Mxsmanic | Piloting | 258 | January 18th 07 11:52 PM |
Confusion about when it's my navigation, and when it's ATC | Mxsmanic | Instrument Flight Rules | 332 | January 18th 07 11:52 PM |
Confusion Plus | Kevin Berlyn | Home Built | 1 | March 6th 05 06:40 AM |
confusion | G.A. Seguin | Soaring | 0 | July 14th 04 12:08 AM |
