Barf bags don't work in zero G's
Old November 29th 07, 02:59 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default Barf bags don't work in zero G's
Aviv Hod wrote:
Fellow pilots, let's be nicer to our passengers than this pilot
apparently is. If anyone in the plane has a bag at the ready, it's not
a good time to pull zero G maneuvers!!
http://www.break.com/index/barf-bags...k-at-0-gs.html
This is pretty funny though :-)
-Aviv
In my opinion this pilot would not end up on my list of people I would
recommend.
This "stunt" is unwise as a general rule, especially in aircraft like
this one; especially loaded with passengers; especially with baggage in
the baggage compartment; especially with that baggage not tied down and
secured; and most importantly, especially at the high rate of forward
pressure this pilot was obviously using to "create the effect".
It's very possible to take these airplanes right on through 0 g and into
negative g if this is done fast enough and these airplanes are not
designed for that. Carried to the extreme, this "stunt" could cause real
structural problems.
And all this doesn't even address the fact that at least one passenger
on this flight was taken from the role of passenger and made a victim by
this totally inappropriate, unprofessional, and unnecessary act of
stupidity by this pilot.
Demonstrating things like this in a loaded airplane is not the way to
impress the ladies.
I hope I've made my point on this perfectly clear.
Dudley Henriques
Old November 29th 07, 03:57 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Dudley Henriques wrote in news:zO-
-Aviv
recommend.
impress the ladies.
Waht was that first part again?
Bertie
Old November 29th 07, 04:06 PM posted to rec.aviation.piloting
-Aviv
recommend.
impress the ladies.
Bertie
Bad JuJu :-)
Dudley Henriques
Old November 29th 07, 04:24 PM posted to rec.aviation.piloting
not a good time to pull zero G maneuvers!!
-Aviv
would recommend.
like this one; especially loaded with passengers; especially with
baggage in the baggage compartment; especially with that baggage not
tied down and secured; and most importantly, especially at the high
rate of forward pressure this pilot was obviously using to "create
the effect". It's very possible to take these airplanes right on
through 0 g and into negative g if this is done fast enough and
these airplanes are not designed for that. Carried to the extreme,
this "stunt" could cause real structural problems.
passenger on this flight was taken from the role of passenger and
made a victim by this totally inappropriate, unprofessional, and
unnecessary act of stupidity by this pilot.
to impress the ladies.
Bertie
Bad JuJu :-)
Yep. What an asshole!
When I used to give aerobatic rides in the Stearmans, we had our share
of casualties. We always briefed a signal if the passenger was getting
uncomfortable. Sometimes it caught up on them, though and if you saw a
head going over the cockpit side your foot went down on the same side
quick-ish so you didn't get a faceful yourself. A couple of people just
put their head 'twxth their knees, but fortunately, the Stearman had a
removable pan beneath the cockpits you could release with a few dzus and
a quick hosing our was all that was needed.
Now there's a well thought out airplane.
Bertie
Old November 29th 07, 04:41 PM posted to rec.aviation.piloting
-Aviv
would recommend.
Bertie
Bad JuJu :-)
Bertie
I've tried that rudder trick myself in a Great Lakes....with mixed
results :-))
The Stearman is a great airplane. We had a 450 on the field I flew once
in a while with the owner. Don't know if you ever had the chance to fly
the 450. It was a whole new airplane. I remember laughing to myself on
my first takeoff. I didn't have the power in before I broke ground. The
nose visuals were about the same as the Mustang.....non-existent :-))
Dudley Henriques
Old November 29th 07, 06:22 PM posted to rec.aviation.piloting
it's not a good time to pull zero G maneuvers!!
-Aviv
would recommend.
not tied down and secured; and most importantly, especially at the
high rate of forward pressure this pilot was obviously using to
"create the effect". It's very possible to take these airplanes
right on through 0 g and into negative g if this is done fast
enough and these airplanes are not designed for that. Carried to
the extreme, this "stunt" could cause real structural problems.
Bertie
Bad JuJu :-)
share of casualties. We always briefed a signal if the passenger was
getting uncomfortable. Sometimes it caught up on them, though and if
you saw a head going over the cockpit side your foot went down on the
same side quick-ish so you didn't get a faceful yourself. A couple of
people just put their head 'twxth their knees, but fortunately, the
Stearman had a removable pan beneath the cockpits you could release
with a few dzus and a quick hosing our was all that was needed.
Bertie
results :-))
once in a while with the owner. Don't know if you ever had the chance
to fly the 450. It was a whole new airplane. I remember laughing to
myself on my first takeoff. I didn't have the power in before I broke
ground. The nose visuals were about the same as the
Most of my time is in Lyc and Contineal powered ones. The only 450 I
flew was a duster and it weighed so much it went about the same as the
stock ones!
Bertie
Old November 29th 07, 06:28 PM posted to rec.aviation.piloting
-Aviv
would recommend.
Bertie
Bad JuJu :-)
Bertie
results :-))
stock ones!
Bertie
I had the same feeling. Better nose vis in the standard and the 450 was
heavy as hell in the glide. Great airplanes though and a whole lot of
fun. Flying open is a special experience :-)
Dudley Henriques
Old November 29th 07, 04:48 PM posted to rec.aviation.piloting
-Aviv
recommend.
impress the ladies.
Bertie
Kind of like reading "Sale of Two Titties".....wait....that's "Tale of
two Cities I think.
Begins with
"It was a day like any other day"....ends with..
"Twas a far better thing I have done that I ever did before"
The rest is just the middle part :-))
Dudley Henriques
-Aviv
would recommend.
Bertie
two Cities I think.
Begins with
Just pulling yur chain,,
Bertie
Old November 29th 07, 11:39 PM posted to rec.aviation.piloting
Gatt
recommend.
No kidding. Not only is it a bad idea to pull partial G's when one of your
pax is already holding the yak bag, that's gotta be the fastest way to spend
a Friday night alone on the couch wishing the two hotties in the back of
your airplane didn't think you were a total jackass.
However, I confess I took a girl through the maneuvers back in
college...while she was holding an open Dr. Pepper and wearing a new white
coat.
-c
NEED BALLAST BAGS [email protected] Soaring 3 June 12th 06 05:04 AM
ASW-24 water bags Sam Fly Soaring 0 May 27th 05 11:08 PM
Pub Bags and Kneeboards Pilot3400 Military Aviation 0 July 21st 04 03:35 PM
Triumphant Tea Bags Frank Van Haste Military Aviation 0 June 30th 03 09:14 PM
