Electric Car Conversion Companies: Alternatives To Gas Powered Cars
Old November 29th 07, 07:12 PM posted to rec.aviation.homebuilt
Roger (K8RI)
Default Electric Car Conversion Companies: Alternatives To Gas Powered Cars
On Wed, 28 Nov 2007 13:14:40 GMT, Charles Vincent
Morgans wrote:
"Roger (K8RI)" wrote
Clutch lever? I said that Harley was "Old":-)) Not one of those
modern ones.
OK, I give up.
So old that it didn't have a transmission? g
How did you work the clutch? I'm not familiar with "old as dirt" Harleys.
Foot operated clutch and a tank shifter. I never had a tank shifter,
Yup, Rocker clutch and tank shift 3-speed, with both on the left side.
Not exactly a bike for letting it all hang out while shifting through
the turns:-)) Hand clutch and foot shift was one whale of an
improvement for both convenience and safety.
but did ride a panhead with a jockey shift (hand shift behind the seat).
That I've not seen.
Charles
Roger (K8RI)
Old November 29th 07, 07:44 PM posted to rec.aviation.homebuilt
Maxwell
"Roger (K8RI)" wrote in message
news
modern ones.
OK, I give up.
Harleys.
That I've not seen.
That sounds familuar but I can't recall for sure either.
There was also something like the Cushman or Mustang, that we use to full
throttle with the right twist grip. But after you got in to top gear, you
could reach under the tank with your free left hand and override the
governer on the big end.
Old November 29th 07, 09:04 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Maxwell wrote:
...ride the governer on the big end.
That's what countless Arkansan females said about Bill wasn't it?
Old November 29th 07, 09:43 PM posted to rec.aviation.homebuilt
Maxwell
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
Yeah, and little did they realize at the time, the capacity of their mouths
was (1) US leader.
I know there are electric powered sailplanes but YouHelpBuild.com Soaring 12 November 19th 07 01:57 PM
Solar Electric Powered Aircraft Larry Dighera Piloting 33 November 6th 05 08:37 PM
Solar Electric Powered Aircraft Larry Dighera Soaring 31 November 6th 05 08:37 PM
Is a Turn Coordinator an electric motor or powered by fan? kickinwing Piloting 5 June 11th 05 12:25 PM
