Who has priority on a taxiway?
Old November 29th 07, 04:46 PM posted to rec.aviation.piloting
Default Who has priority on a taxiway?
I'm not certain of who actually would have the *legal* right of way...
but personally I think I'd prefer to yield right of way to whoever has
the biggest spinning meatgrinder on their flying machine.
Old November 29th 07, 06:42 PM posted to rec.aviation.piloting
C J Campbell[_1_]
On 2007-11-28 18:54:54 -0800, "Vaughn Simon"
said:
I landed at a very quiet uncontrolled field a few weeks ago. As I taxied
back on the taxiway for my departure, I kept hearing a helicopter calling out
pattern legs for a place called "tango".
The same right of way rules apply to a taxiway as anywhere else for
aviation. If the aircraft are "converging," then whoever is on the
right has the right of way. Airplanes do not have the right of way over
rotorcraft. Landing aircraft have right of way over aircraft whether
they are in flight or maneuvering on the ground.
Aircraft on the water follow the same rules as any other watercraft.
Even the morons on jet skis are supposed to follow those rules,
although for some reason they seem to be completely unaware of them --
to their peril.
§Â*91.113Â*Â*Â*Right-of-way rules: Except water operations.
(a) Inapplicability. This section does not apply to the operation of an
aircraft on water.
(b) General. When weather conditions permit, regardless of whether an
operation is conducted under instrument flight rules or visual flight
rules, vigilance shall be maintained by each person operating an
aircraft so as to see and avoid other aircraft. When a rule of this
section gives another aircraft the right-of-way, the pilot shall give
way to that aircraft and may not pass over, under, or ahead of it
unless well clear.
(c) In distress. An aircraft in distress has the right-of-way over all
other air traffic.
(d) Converging. When aircraft of the same category are converging at
approximately the same altitude (except head-on, or nearly so), the
aircraft to the other's right has the right-of-way. If the aircraft are
of different categories—
(1) A balloon has the right-of-way over any other category of aircraft;
(2) A glider has the right-of-way over an airship, powered parachute,
weight-shift-control aircraft, airplane, or rotorcraft.
(3) An airship has the right-of-way over a powered parachute,
However, an aircraft towing or refueling other aircraft has the
right-of-way over all other engine-driven aircraft.
(e) Approaching head-on. When aircraft are approaching each other
head-on, or nearly so, each pilot of each aircraft shall alter course
to the right.
(f) Overtaking. Each aircraft that is being overtaken has the
right-of-way and each pilot of an overtaking aircraft shall alter
course to the right to pass well clear.
(g) Landing. Aircraft, while on final approach to land or while
landing, have the right-of-way over other aircraft in flight or
operating on the surface, except that they shall not take advantage of
this rule to force an aircraft off the runway surface which has already
landed and is attempting to make way for an aircraft on final approach.
When two or more aircraft are approaching an airport for the purpose of
landing, the aircraft at the lower altitude has the right-of-way, but
it shall not take advantage of this rule to cut in front of another
which is on final approach to land or to overtake that aircraft.
[Doc. No. 18334, 54 FR 34294, Aug. 18, 1989, as amended by Amdt.
91-282, 69 FR 44880, July 27, 2004]
Waddling Eagle
World Famous Flight Instructor
Old November 30th 07, 12:02 AM posted to rec.aviation.piloting
Vaughn Simon
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
stuck-wing have the right-of-way over the helicopter just about everywhere.
Whoa guy! Right-of Way is assigned in 91.113, and there is nothing there
that gives airplanes right-of-way over helicopters. (Yes, I know about 91.126
(2), but that is more of a general thing.)
Also, as a glider pilot, I have learned that one lives longer if you do not
expect to automatically receive the right-of-way just because the regs say it
should be yours.
Vaughn
Old November 30th 07, 12:47 AM posted to rec.aviation.piloting
Robert M. Gary
On Nov 29, 4:02 pm, "Vaughn Simon"
should be yours.
I'm not sure that is what this thread is about. I don't think the OP's
objective was to ram the helo if it was determined the OP was in the
right-of-way. I thiink he was interested in what guidance the FARs or
even AIM may provide.
-Robert
Old November 30th 07, 01:16 AM posted to rec.aviation.piloting
Don Tuite
On Thu, 29 Nov 2007 07:47:23 -0500, Ron Natalie
Steven P. McNicoll wrote:
I don't believe I've ever seen or heard anything either way, I don't think
it needs to be. It's called a "taxiway" for a reason.
We've got a few airports around that have the designated helipad marked
out on the taxiway. If you saw they guy attempting to land you should
give way. Otherwise, he needs to similarly deal with people taxiing.
The operative rule is don't run into anybody.
Don't blow anybody over would be another good one.
Don
Old November 30th 07, 01:55 AM posted to rec.aviation.piloting
should be yours.
There is a classic cartoon that shows two guys in a dinky sailboat
with an aircraft carrier bearing down on them.
One guy says to the other: Don't worry about it. We have the right-of-way.
Jim Pennino
Remove .spam.sux to reply.
Old November 30th 07, 03:42 AM posted to rec.aviation.piloting
Doesn't the ordering here imply it (at the least)?
Does anyone disagree that the general idea here is the less
maneuverability options an aircraft has, the more right of way it has?
Maybe it's not fair for gyrocopters, but helicopters can go up, down,
sideways, and backwards -- or hover. They got more options than
everybody else.
Speaking of helicopters, on my checkride one kept popping up and down
next to the runway I was using for all the landing assessments. There
was lots of corn growing, so when he was on the ground you couldn't
see him. I took off on a x-wind takeoff and he suddenly popped up at
the far end, where I was heading. He hovered there practicing not
drifting onto my runway. It was a little disconcerting because from
1500 feet away he looked awful close to my centerline.
Old November 30th 07, 04:09 AM posted to rec.aviation.piloting
Dave[_5_]
However, at our field the choppers have been told they WILL use the
runway for all takeoff and landing movements and then hover taxi to
their hangar - NO direct takeoff from taxiways and ramps, period!
Even the police and ambulance choppers obey the rule...
denny
I happen to think that is a dumb idea - especially the "hover taxi"
part. Helicopters should have separate parking/tiedown areas, and
avoid conflicting with fixed wing traffic. Once I was working on my
plane with the cowling removed when along came some military types in
a chopper - hovering down the taxiway, which was right in front of me.
They sent my cowling tumbling - which I did not appreciate at all.. I
gave 'em an extended one-finger salute.
The airport near my office makes many visiting choppers park on the
grass - and take off and land there directly, using non-conflicting
directions. Those folks based at this airport who have helicopters
with skids are obliged to use trailers for ground movement The
arrangement seems to work well.
David Johnson
Old November 30th 07, 05:23 AM posted to rec.aviation.piloting
Dave[_5_]
Roger all of that.... How about this: Once I decided to fly to a
quiet, uncontrolled airport that happens to have a good restaurant
within walking distance. While on final a helicopter comes in from the
side, and proceeds to hover over the far end of the runway. What he
was doing I have no idea. Since the runway was quite long, I decided
that there was no hazard, and continued my landing. I taxied to
parking (at the far end), and he landed the chopper nearby on the ramp
- and came over. Turns out he is a Sheriff's Deputy (on duty), and is
irritated about what happened. I assured him that I had seen him and
percieved no conflict - thus went ahead with my landing. He didn't
pursue the matter.
So who is right and who is wrong in that situation? I made an entirely
normal approach and landing - whereas he operated his helicopter in a
manner that unnecessarily conflicted with the flow of fixed-wing
traffic. He could just as easily have come in from the side and landed
immediately on the ramp. Since nothing came of it I just chalked it up
to experience. If I could have my druthers, I'd prefer not to have
helicopters around airplanes at all.
David Johnson
Old November 30th 07, 05:54 AM posted to rec.aviation.piloting
C J Campbell[_1_]
pursue the matter.
David Johnson
Obviously, he did not yield the right of way to landing traffic. Once
he lands he is supposed to get off the runway.
There is no requirement that other traffic clear the runway before you
land as long as there is no undue hazard to persons or property on the
ground.
Waddling Eagle
A Different Kind of Taxiway J.F. Aviation Photos 16 October 14th 07 10:37 AM
Steering on the taxiway Mxsmanic Piloting 127 November 29th 06 12:12 AM
Oshkosh Taxiway Incident M Home Built 0 July 31st 06 04:25 AM
Add on's jumping on taxiway in FS9 Dudley Henriques Simulators 2 February 28th 04 04:10 PM
Taxiway Signs Dennis Wyman Simulators 4 January 1st 04 09:56 PM
