Cleveland Wheel Shims
Old November 30th 07, 03:05 AM posted to rec.aviation.homebuilt
John[_9_]
Default Cleveland Wheel Shims
On Nov 24, 2:00�pm, Ron Wanttaja wrote:
I need to add some shims to the axles of my Fly Baby to reduce the side-to-side
movement of my wheels (the axles aren't threaded at the end, the wheels are held
on with a cross-bolt through a bushing).
I basically need some thin metal washers with a 1.5" inside diameter. �I'm
suspecting the "Ring-Grease Seal" items on Cleveland 600x6 wheels is what I'm
looking for. �However, there are multiple part numbers for the same item
(153-00300, 153-00400, etc.). �I'm suspecting these are differing
thickness...anybody got a table that shows the thickness by part number?
The 153-xxxxx Ring-Grease Seal is designed to back up the wheel
bearing. In effect it is a cupped washer. It might serve for what you
want if you grind the rubber cup off of the flat washer it is bonded
to. It is not a typical axle spacer though.
John Dupre'
Old November 30th 07, 06:22 AM posted to rec.aviation.homebuilt
I basically need some thin metal washers with a 1.5" inside diameter. ?I'm
looking for. ?However, there are multiple part numbers for the same item
(153-00300, 153-00400, etc.). ?I'm suspecting these are differing
Thanks, John, exactly the kind of info I needed. One of our fellow RAHers has
some shim stock and it cutting me the kind of washers I need.
Cleveland Nat Air Show Woody Aviation Photos 0 September 2nd 07 12:18 AM
Cleveland Air Show.. what if... Dave S Piloting 5 September 3rd 04 01:59 AM
IFR Through Cleveland Bartscher Instrument Flight Rules 2 June 2nd 04 04:22 PM
Wheel pants for 6.00 x 6 wheel/tire Wallace Berry Home Built 2 January 23rd 04 04:22 AM
Decent into Cleveland john cop Instrument Flight Rules 19 October 19th 03 06:09 PM
