Questions on landing at a towered airport
Old November 30th 07, 01:30 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Questions on landing at a towered airport
m...
Agreed. First off, the FAA has decided that the failure of ATC to correct
a erroneous read back does not absolve the pilot from disobeying
an ATC clearance.
They have? When?
Old December 1st 07, 01:22 AM posted to rec.aviation.piloting
Tman
"BT" wrote in message
I think you cracked the code.. if in doubt.. clarify..
Welcome Jr Birdman..
kidding aside.. are your local CFIs new to the game? or oldsters that
really have not flown much to other locations?
That is one good thing about the NG... you'll get as many varied responses
as there are options..
Yeah my CFI is kinda funny. He's actually posted to this thread. (F.
Baum - a little lower on this thread ). Kinda high on the street smarts,
but not the academic parts of flying!
T
Old December 4th 07, 11:08 PM posted to rec.aviation.piloting
Rob
Tman wrote:
* Do I really need to plan my descent so that I am TPA when reporting the
3-mile right base? I Really do not want to be. I'd rather be 2000 AGL,
which will give me a comfortable (but a little aggressive) descent with a
squarish pattern to the numbers, but also make much more feasible landing in
the airport environment, if not the numbers, should the engine stop. At
1000 AGL 3 miles out, there is just no hope of making the airport -- I'd
rather not be that low unless I really need to be. Is there any rule that
says I need to be at TPA when reporting to the controller points on the
pattern?
I see lots of good answers to your other questions in this thread but
only one quick "no" regarding this one. Safely gliding to the runway
is a consideration, but note that it's _much_ easier to see traffic
against the sky than against the clutter of the ground. Staying lower
will enable you to better see traffic in the pattern. In the event of
an unexpected power loss, a safe off-airport landing is for the most
part just as positive an outcome as a safe on-airport landing. I go a
little lower than you suggest, usually about 1000 AGL which is often
also TPA, for the good traffic visibility from a few miles out, as
long as I have options (not necessarily the runway) if the unexpected
should happen.
-R
Eastern Long Island Airport questions John Theune Piloting 3 February 6th 07 08:30 PM
Could training at a towered airport have prevented the ADIZ bust airman Piloting 69 May 20th 05 03:53 PM
report runway incursion non-towered airport? Joe Johnson Piloting 95 March 5th 05 10:11 AM
non-towered airport question Snowbird Piloting 48 January 19th 04 01:58 PM
Motorglider and Towered Airport Steve B Soaring 23 January 13th 04 06:06 PM
