#21
On Nov 29, 5:16 pm, (Michel Talon) wrote:
By the way, you can find the other manufacturers at the same place. Thanks for the links. I've also got the Johnson flight tests for both the 19 and the Cirrus, and again there isn't much between the two (afaik Johnson never tested the Pegase). The 19 has a slight edge, or would with equal wing loading. But IMHO handling is a factor in XC speed - the easier and more forgiving a ship is to fly, the more you can concentrate on tactics - and that can't be discerned from polars. Dan |
Dan G wrote:
On Nov 29, 5:16 pm, (Michel Talon) wrote: By the way, you can find the other manufacturers at the same place. Thanks for the links. I've also got the Johnson flight tests for both the 19 and the Cirrus, and again there isn't much between the two (afaik Johnson never tested the Pegase). The 19 has a slight edge, or would with equal wing loading. But IMHO handling is a factor in XC speed - the easier and more forgiving a ship is to fly, the more you can concentrate on tactics - and that can't be discerned from polars. Dan You may have discovered my bias from my previous post, but as much as i liked the ASW15, i disliked the ASW19. For me, it has bad handling, doesn't climb well. I have flewn the Libelle, the Cirrus, the LS1, LS3, LS4 and many others, and liked them, but not the 19. Of course this is very dependant on each individual, because i am sure many people like the 19. Anyways, objectively, the performance difference between the Pegase and the 19 is the same as between the Discus and the Pegase. The handling of the Pegase is "modern", same type as the LS4, etc. and quite different from the handling of old style gliders. This is perhaps the reason why someone characterized it as a truck ... Personnally i like its stability, and it climbs very well. Also the air brakes are very effective. Of course for an american pilot, it is probably not a good choice due to the 3000 hours limit. I think it is a shame that Centrair has handled this issue in such a deplorable way. -- Michel TALON |
Tony Verhulst wrote:
Pegasus is a very good choice. Agreed. It doesn't have any bad habits.. Only one, IMHO. It is a handful in a cross wind take off. And, after having seen 2 other 19's connect with solid objects after veering off to the side in a xwind departure, I suspect that my opinion is shared with others. In my 2 or 3 years as a part owner in a 19, I can't remember a single xwind take off that I really was happy with. OTOH, take offs in my LS6 in similar conditions are "no brainers". The ASW 19 (and the ASW 20) cross wind ability can often be improved by starting the takeoff roll with the spoilers open. This might also work for the Pegasus. If it does help, then it's an easy matter to learn to prevent the occasional heartburn it causes the line crew and the tow pilot when they see the spoilers open at the start of the launch. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Cats wrote:
On Nov 29, 5:17 pm, Martin Gregorie wrote: Cats wrote: On Nov 29, 3:22 am, "Bill" wrote: snip A sleeve can not be added to the elevator connection due to lack of space, but this connection is exposed enough that using a safety pin is not a problem. snip I've just brought one and the elevator is self-connecting - it's a 101a. If you can find one, go for a Pegase 90 - they are later than the 101 models and have automatic hook-ups for all controls. I've got what I've got - I'll get on with flying it! And I'm suspecting I'll never need another glider, unless I manage to break it. Apologies, Cats - that was aimed at the OP, not you! Our club's Peg 90 was my first step into high performance gliders after the Junior and I really enjoyed flying it. I liked its feel and handling very much and found it much more comfortable than a Discus for flights beyond 3 hours or so. FWIW, I agree with you - if I owned a Peg I would not be looking to change it. They climb nicely in weak lift and run well with a bit of water on board. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Nov 29, 10:19 pm, Martin Gregorie
wrote: Cats wrote: On Nov 29, 5:17 pm, Martin Gregorie wrote: Cats wrote: On Nov 29, 3:22 am, "Bill" wrote: snip A sleeve can not be added to the elevator connection due to lack of space, but this connection is exposed enough that using a safety pin is not a problem. snip I've just brought one and the elevator is self-connecting - it's a 101a. If you can find one, go for a Pegase 90 - they are later than the 101 models and have automatic hook-ups for all controls. I've got what I've got - I'll get on with flying it! And I'm suspecting I'll never need another glider, unless I manage to break it. Apologies, Cats - that was aimed at the OP, not you! Our club's Peg 90 was my first step into high performance gliders after the Junior and I really enjoyed flying it. I liked its feel and handling very much and found it much more comfortable than a Discus for flights beyond 3 hours or so. As a fully-paid up member of the short-arse club, the Discus b at my club isn't suitable. By the time I'm sat where I have a fighting chance of getting the wheel back down my head is too near the canopy. It's a pit the gear lever is on the port side - starboard would avoid any possibility of confusing it with the airbrakes - but it's much better. The other good thing about being short is that being well forward in the cockpit improves the readward view - really tall people must suffer in some gliders with the fuselage behind the canopy limiting that view. FWIW, I agree with you - if I owned a Peg I would not be looking to change it. They climb nicely in weak lift and run well with a bit of water on board. Since I fly in Scotland, I hope to fly it in wave pretty soon! |
Eric Greenwell wrote:
The ASW 19 (and the ASW 20) cross wind ability can often be improved by starting the takeoff roll with the spoilers open. This might also work for the Pegasus. I think the Peg is the best of the three on this point. I've never flown a 19, but it you examine a Peg and a 19 side by side, the Peg looks to have bigger ailerons. I mostly winched the Peg, but when I did aero tow it I didn't have any particular wing drop problems. The 20 is easily the worst behaved with its tiny ailerons - even the owners manual says they have so little bite that you should start the takeoff roll in negative flap. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Sorry Martin,
the 20 has full-span ailerons which aren't tiny by any means. Negative flaps on initial ground roll is standard procedure for any flapped ship, and if you do it with the 20, it is pretty difficult to drop a wing. Bert "Martin Gregorie" wrote in message ... The 20 is easily the worst behaved with its tiny ailerons - even the owners manual says they have so little bite that you should start the takeoff roll in negative flap. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#28
In what way do the "modern" glass ships differ from the older ones in
the handling department? Why would that account for someones opinion that the Peg handled like a truck? I would think that a modern ship would handle better than an older one, not worse. My only time in a glass single place is in my ASW 15 and I think the handing is fine. Of course, my comparison gliders are two seaters (L13, 2-33, Grob) . Not exactly nimble ships. Just how different is an LS4/Peg etc. from my 15? Roll rate? Lighter controls? Is it a case of not missing what I've never had? On the control connection issue, the ASW 15 is not automatic and getting those safety pins in was a real pain. I put the safety sleeves on and now its a non-issue. I check the connections at least 3-4 times and ALWAYS do a PCC. Manual hook ups is not a reason for me to cross a ship my list of potential new (to me) gliders. Mike ASW 15 but in the market |
#29
Bert Willing wrote:
Sorry Martin, the 20 has full-span ailerons which aren't tiny by any means. Negative flaps on initial ground roll is standard procedure for any flapped ship, and if you do it with the 20, it is pretty difficult to drop a wing. Yes, I know the flaps deflect half as far as the ailerons, but there's still very little bite below 30-35 kts even with a notch of reflex flap and the ground roll felt very busy at first. I had a wing drop or two among my first flights in my 20 - something I never experienced on the club's Peg - or the Williams Soaring one either. I don't recall much difference in the weather conditions during those launches either - certainly nothing worth commenting on. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#30
Bert Willing wrote: Sorry Martin, the 20 has full-span ailerons which aren't tiny by any means. Negative flaps on initial ground roll is standard procedure for any flapped ship, and if you do it with the 20, it is pretty difficult to drop a wing. Yes, I know the flaps deflect half as far as the ailerons, but there's still very little bite below 30-35 kts even with a notch of reflex flap and the ground roll felt very busy at first. My ASW 20 C had plenty of "bite" by 20 knots - it was only the first 100 feet or so that might have a wing drop. I had a wing drop or two among my first flights in my 20 - something I never experienced on the club's Peg - or the Williams Soaring one either. I don't recall much difference in the weather conditions during those launches either - certainly nothing worth commenting on. Some flapped gliders have a higher angle of attack when sitting on the ground, compared to similar unflapped gliders. This can cause the tip to stall more easily in the "neutral" flap position, but using negative flap improves the situation. It also reduces the effects of crosswinds. Why a higher angle of attack? One reason is to allow a slower touch down speed with main and tail touching at the same time; another is a longer gear extension can provide more pilot protection in an off field landing (more clearance), and more protection in a very hard or crash landing (more room to absorb energy). -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Pegasus fo sale ? | Jean | Soaring | 1 | February 21st 07 03:44 AM |
Pegasus time limit | [email protected] | Soaring | 38 | February 14th 07 08:35 AM |
Pegasus instrument panel | [email protected] | Soaring | 0 | November 1st 06 11:42 PM |
FS: Pegasus | [email protected] | Soaring | 1 | October 4th 05 10:05 PM |
Pegasus AD | [email protected] | Soaring | 9 | August 29th 05 12:03 AM |
