![]() U.S. TV is 60 fields/second, European is 50/second. And it takes two interlaced fields to make a frame, therefore US broadcast TV standard (NTSC) is actually only 30 frames per second. Europe's PAL and SECAM standards are both 50 interlaced fields per second, yielding 25 actual frames per second. |
Mxsmanic wrote in
: writes: And it takes two interlaced fields to make a frame, therefore US broadcast TV standard (NTSC) is actually only 30 frames per second. 30 images, 60 frames You're an idiot Berie |
Mxsmanic wrote:
writes: And it takes two interlaced fields to make a frame, therefore US broadcast TV standard (NTSC) is actually only 30 frames per second. 30 images, 60 frames Wrong, exactly backwards wrong. Rutger was correct. |
Gig 601XL Builder writes:
Wrong, exactly backwards wrong. Rutger was correct. The frame is a painted raster. The image is the complete set of visual data for simultaneous assimilation. |
Mxsmanic wrote:
Gig 601XL Builder writes: Wrong, exactly backwards wrong. Rutger was correct. The frame is a painted raster. The image is the complete set of visual data for simultaneous assimilation. Shut the **** up, MX. |
Shut the **** up, MX. Or else what? |
Mxsmanic wrote:
Gig 601XL Builder writes: Shut the **** up, MX. Or else what? Or else I won't Like You any nore. |
Saturday 072807 in Oshkosh Pt 6 - Warbird show pix I forgot to post earlier [10/33] - "Bird Dog.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 10:48 PM |
"British trace missile in copter strike to Iran" | Mike[_7_] | Naval Aviation | 8 | March 10th 07 08:20 PM |
Bird strike(s) | Jay Honeck | Piloting | 45 | November 30th 05 04:39 AM |
Bird strike | Jase Vanover | Piloting | 16 | May 17th 05 11:44 AM |
