![]() "Airbus" wrote in message ... In article , says... "Airbus" wrote in message ... In article , says... Hence the reason an aircraft propeller will appear to be revolving slowly backwards at times. Not when being observed directly. That only happens in movies and video due to the interaction between the imaging rate and the rotation rate of the propeller. Wrong again you clueless twit. No, he is right this time. No he isn't. Wellllllllll.............. The world is listening . . . Indeed. |
"Airbus" wrote in message ... In article , says... "Airbus" wrote in message .. . In article , says... Hence the reason an aircraft propeller will appear to be revolving slowly backwards at times. Not when being observed directly. That only happens in movies and video due to the interaction between the imaging rate and the rotation rate of the propeller. Wrong again you clueless twit. No, he is right this time. No he isn't. Wellllllllll.............. The world is listening . . . Indeed. Still listening . . . Simple question, to get you started on your explanation; Have you ever been in a propeller-driven airplane? |
![]() "Airbus" wrote in message ... In article , says... "Airbus" wrote in message ... In article , says... "Airbus" wrote in message . .. In article , says... Hence the reason an aircraft propeller will appear to be revolving slowly backwards at times. Not when being observed directly. That only happens in movies and video due to the interaction between the imaging rate and the rotation rate of the propeller. Wrong again you clueless twit. No, he is right this time. No he isn't. Wellllllllll.............. The world is listening . . . Indeed. Still listening . . . Simple question, to get you started on your explanation; Have you ever been in a propeller-driven airplane? I have been a pilot since 1972. |
In rec.aviation.piloting Airbus wrote:
In article , says... "Airbus" wrote in message ... In article , says... Hence the reason an aircraft propeller will appear to be revolving slowly backwards at times. Not when being observed directly. That only happens in movies and video due to the interaction between the imaging rate and the rotation rate of the propeller. Wrong again you clueless twit. No, he is right this time. No he isn't. Wellllllllll.............. The world is listening . . . When observed directly under artifical light that "flickers", the most obvious being a strobe light, but there are other types of artificial lights that have flicker. -- Jim Pennino Remove .spam.sux to reply. |
Airbus wrote in
: In article , says... When observed directly under artifical light that "flickers", the most obvious being a strobe light, but there are other types of artificial lights that have flicker. -- Fine - but which ones cause you to see the propellers turning in apparent reverse? Do you frequently operate your airplane indoors? Propellers are usually observed in natural light, which does not flicker. At night, on the rare occasions where you actually see the props clearly, it is from the aircraft's own lighting, which is DC. I have nbever seen the props turning backwards on a real plane - see it frequently in movies though. . . At least one exception. If you look at a prop through your own prop arc... Bertie |
In article , says... When observed directly under artifical light that "flickers", the most obvious being a strobe light, but there are other types of artificial lights that have flicker. -- Fine - but which ones cause you to see the propellers turning in apparent reverse? Do you frequently operate your airplane indoors? Propellers are usually observed in natural light, which does not flicker. At night, on the rare occasions where you actually see the props clearly, it is from the aircraft's own lighting, which is DC. I have nbever seen the props turning backwards on a real plane - see it frequently in movies though. . . Any light that flickers at an appropriate rate will cause the prop to appear to turn in reverse. The likelyhood of being somewhere with lights that flicker is irrelevant. The original statement was that it -ONLY- happens in movies and video, and that absolute statement is false as are most of MX's absolute statements. -- Jim Pennino Remove .spam.sux to reply. |
Mxsmanic wrote in
: writes: Any light that flickers at an appropriate rate will cause the prop to appear to turn in reverse. The likelyhood of being somewhere with lights that flicker is irrelevant. It's highly relevant in aviation, where exposure to flickering lights is essentially unknown. Bwawhahwahwhahwhahhwhahwhahwhahhwhahwhahwha! Another gem from the master. Bertie |
Saturday 072807 in Oshkosh Pt 6 - Warbird show pix I forgot to post earlier [10/33] - "Bird Dog.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 10:48 PM |
"British trace missile in copter strike to Iran" | Mike[_7_] | Naval Aviation | 8 | March 10th 07 08:20 PM |
Bird strike(s) | Jay Honeck | Piloting | 45 | November 30th 05 04:39 AM |
Bird strike | Jase Vanover | Piloting | 16 | May 17th 05 11:44 AM |
