Matt W. Barrow wrote:
"Jim Macklin" wrote in message ... They tried, in one previous show, to duplicate the old cartoon shotgun barrel blow up with the barrel unwinding. They tried to use modern shotguns which are made from solid tubular steel. Shotguns made before about 1920 were generally made by wrapping steel wire around a mandrel and using the old blacksmith welding with a hammer and anvil. Those barrels would have flaws and weak spots. More like 1880 than 1920. "Damascus" barrels were not really produced after the 1880's or so, long before the introduction of smokeless powder around 1900. Smokeless powder would easily destroy such a barrel. Actually it's not the barrels but the chamber that couldn't take the higher pressure. I know one gunsmith that has somewhat permanently (red loctite) installed 20 and 28 gage adapters in 12 gage Damascus steel barrels. The adapter takes the load from firing the cartridge and the rest of the barrels are strong enough for the rest. This makes for a heavy low powered shotgun but it also makes a wall-hanger into a useful piece. Tony |
![]() "Anthony W" wrote in message news:AGd8j.22555$Bg7.20727@trndny07... Matt W. Barrow wrote: "Jim Macklin" wrote in message ... They tried, in one previous show, to duplicate the old cartoon shotgun barrel blow up with the barrel unwinding. They tried to use modern shotguns which are made from solid tubular steel. Shotguns made before about 1920 were generally made by wrapping steel wire around a mandrel and using the old blacksmith welding with a hammer and anvil. Those barrels would have flaws and weak spots. More like 1880 than 1920. "Damascus" barrels were not really produced after the 1880's or so, long before the introduction of smokeless powder around 1900. Smokeless powder would easily destroy such a barrel. Actually it's not the barrels but the chamber that couldn't take the higher pressure. I know one gunsmith that has somewhat permanently (red loctite) installed 20 and 28 gage adapters in 12 gage Damascus steel barrels. The adapter takes the load from firing the cartridge and the rest of the barrels are strong enough for the rest. This makes for a heavy low powered shotgun but it also makes a wall-hanger into a useful piece. After the load leaves the chamber, the barrel does...what (with the internal pressure)? |
In rec.aviation.piloting Matt W. Barrow wrote:
"Anthony W" wrote in message news:AGd8j.22555$Bg7.20727@trndny07... Matt W. Barrow wrote: "Jim Macklin" wrote in message ... They tried, in one previous show, to duplicate the old cartoon shotgun barrel blow up with the barrel unwinding. They tried to use modern shotguns which are made from solid tubular steel. Shotguns made before about 1920 were generally made by wrapping steel wire around a mandrel and using the old blacksmith welding with a hammer and anvil. Those barrels would have flaws and weak spots. More like 1880 than 1920. "Damascus" barrels were not really produced after the 1880's or so, long before the introduction of smokeless powder around 1900. Smokeless powder would easily destroy such a barrel. Actually it's not the barrels but the chamber that couldn't take the higher pressure. I know one gunsmith that has somewhat permanently (red loctite) installed 20 and 28 gage adapters in 12 gage Damascus steel barrels. The adapter takes the load from firing the cartridge and the rest of the barrels are strong enough for the rest. This makes for a heavy low powered shotgun but it also makes a wall-hanger into a useful piece. After the load leaves the chamber, the barrel does...what (with the internal pressure)? While one could put in a chamber only sub-caliber adapter in a shotgun, the pattern would be crap. What is usually put in is called a "tube" and is a full length barrel. -- Jim Pennino Remove .spam.sux to reply. |
Mythbusters Episode and FMS | Marco Leon | Piloting | 19 | February 13th 07 05:45 AM |
..and another hour... | hellothere.adelphia.net | Rotorcraft | 7 | October 7th 04 11:26 AM |
Mythbusters and explosive decompression | Casey Wilson | Piloting | 49 | July 15th 04 05:56 PM |
MythBusters | Hilton | Piloting | 7 | February 4th 04 03:30 AM |
Mythbusters Explosive Decompression Experiment | C J Campbell | Piloting | 49 | January 16th 04 07:12 AM |
