Opposed engines are simple and strong. Inverted engines are much
more complicated. First: The cylinder extends into the crankcase so that oil thrown off the bearings doesn't drain off the case walls and run into the cylinders. Could cause hydraulic lock, certainly would use a lot more oil. Second: That oil can't be stored in the crankcase. There has to be a separate oil tank, usually on the firewall. Third: The oil has to be pumped out of the engine into the tank. My Auster had a Gipsy Major inverted inline, and it had THREE oil pumps: one to pump oil from the tank into the engine's workings for lubrication, and two more to scavenge the case; one pumped oil out of the front, the other out of the back. Because the engine gets tipped up and down so much in an airplane, two outlets are necessary lest oil pile up and start running into the jugs at the low end. One pump can't do them both, or it would be happy to suck air from the high end instead of pulling the oil out of the low end. Fourth: The rockers and valve stems need either pressure lubrication and ANOTHER scavenge pump, or, as with the Gipsy, the covers are taken off occasionally and filled with oil. A pain, that is. In spite of all that, I like the looks of the inverted installation, confirming that, like so much of homebuilding and the rest of general aviation, emotions usually trump common sense. (Just look at the beautiful but huge, ridiculously expensive projects some of us average-income guys start on, and are never able to finish. Emotions over common sense.) Dan |
R172K Approach Configuration | facpi | Instrument Flight Rules | 10 | January 5th 07 03:58 PM |
V-22 Prop Configuration, 3-vs-4 blades | Don McIntyre | Naval Aviation | 23 | April 10th 06 03:23 AM |
T-2C Buckeye nav light configuration. | Mike W. | Naval Aviation | 14 | March 17th 05 07:05 AM |
Question about center-line push-pull engine configuration | Shin Gou | Home Built | 4 | June 7th 04 05:57 PM |
Hyping the Intermeshing Configuration | Dave Jackson | Rotorcraft | 0 | October 31st 03 08:34 PM |
