Virus Alert!
Old December 15th 07, 08:53 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.student
John Mazor[_2_]
Default Virus Alert! (OT)
"John Mazor" wrote in message news:jwM8j.9980$rZ3.4647@trnddc07...
"Morgans" wrote in message
"Stefan" wrote
Serious virus warnings are *never* distributed by e-mails like the one you posted.
Actually, this e-mail itself can be considered a kind of virus, because it fills
mailboxes, wastes people's time and probably causes some friendly christmas mails to
be deleted unread.
Actually, I would not say never.
Where I work, there are a lot of computers networked together, and a lot of people
bringing things (files and software) from home and sticking into them, and that adds up
to a great chance of something undesirable getting into the system, and spreading if a
warning is not passed.
That is how I got this warning, and admittedly, I did not spend as much time checking
on it, as I would have done if I had been at home.
This may have been bogus but there is some valid history behind these things. Back in
the DOS days any way that you could get the victim's PC to execute just two lines of DOS
commands would have been fatal:
cd C:\
delete *.*
Now that I think about it, all it takes is
del c:\*.*
It's been a while since I had to know DOS commands.
Old December 16th 07, 03:03 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.student
Robert Bonomi
one you posted.
because it fills
christmas mails to
be deleted unread.
lot of people
and spreading if a
much time checking
things. Back in
cd C:\
delete *.*
del c:\*.*
Of course all that either of those command sequences did was delete
the _regular_ files in the top-level directory of the first hard-disk.
Since the top-level directory has a (small) fixed maximum size, people
who 'knew something' would not put _any_ regular files directly in
that directory, the only thing there would be other directories. plus
the 'hidden/system/read-only' system files. For these kinds of people,
a 'del c:\*.*' did absolutely _nothing_, even if you suppressed the 'do
you really want to do this?' prompt. _when_ the extra switches became
available, the _really_ dangerous command was "format c: /q /y"
I used to make a habit of renaming the "format' command to something else
just to ensure that 'something wicked' couldn't do that.
Old December 16th 07, 05:34 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.student
C J Campbell[_1_]
one you posted.
because it fills
christmas mails to
be deleted unread.
lot of people
and spreading if a
much time checking
things. Back in
cd C:\
delete *.*
del c:\*.*
I always thought the most wicked command in DOS was "restore." I fell
victim to it myself, and I know others who made the same mistake. It
does not restore anything.
Waddling Eagle
World Famous Flight Instructor
Old December 16th 07, 09:48 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
victim to it myself, and I know others who made the same mistake. It does
I had never heard of that one. What *does* it do?
Jim in NC
Old December 18th 07, 03:00 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.student
C J Campbell[_1_]
Sorry. I meant RECOVER. It renames all the files on the drive to just a
sequential number and moves them all to the root directory. So you end
up with all the files in the root, no subdirectories left (they were
renamed, too), and all the files have names like 000123.REC,
000124.REC, 000125.REC, etc.
It is intended to recover all the readable files on a drive that has
bad sectors. It should be used with a filename argument, such as
RECOVER [path][filename] and it will recover the usable parts of that
file.
Recover was eventually replaced by SCANDISK, which was somewhat less
dangerous to use.
The DOS RESTORE command restores files from a backup made with the
BACKUP command.
Waddling Eagle
VIRUS WARNING nuke Home Built 0 February 12th 04 12:11 AM
Please read - virus alert (posted by Gordon) Krztalizer Naval Aviation 0 January 28th 04 11:33 PM
Virus Alert: AVflash 8.51a from AVweb John T Instrument Flight Rules 2 September 1st 03 07:48 AM
Virus Alert: AVflash 8.51a from AVweb John T Piloting 2 September 1st 03 07:48 AM
Way O.T.: sobig.f virus Building The Perfect Beast Home Built 0 September 1st 03 02:45 AM
