muff528 wrote:
Actually, they were quite simple to work on.....individually! The trick was to get them to play together well. Very touchy adjustments, especially if the carb (or engine for that matter) had any wear at all. Then there was the problem of getting the carbs to do the same thing at the same time, linkage-wise, which was not necessarily just making sure that throttle positions on each carb matched. Their performance was affected greatly by even a little wear. Kinda like the Amal's on a couple of BSA's I had. TP You got that right! Getting them syncd was a real PITA! I found a nice little gadget that helped immensely, and by coincidence happened to run across it about a week ago when looking for something else in the tool chest. Here's a pic: http://www.members.cox.net/drpics/carbtool.jpg Why I'm hanging on to it after 45 years is anyones guess, probably should put it on eBay!! But for watching what 3 SU's were doing simultaneously, it was great! The pistons dropped in place of the damper and would rise/fall with the suction, with the wire pointers lined up. Plus there were another half dozen tricks you could do with it. The one that looks like a weird crank shaft was to adjust the float arms. Beats the hell out of sticking your head in there with a stethoscope listening to the hiss... d:-)) Cheers'n beers.. [_]) Don |
I got good results from a piece of Tygon tubing. Just make sure you placed
the end at the same spot on each carb. "ManhattanMan" wrote in message ... muff528 wrote: Actually, they were quite simple to work on.....individually! The trick was to get them to play together well. Very touchy adjustments, especially if the carb (or engine for that matter) had any wear at all. Then there was the problem of getting the carbs to do the same thing at the same time, linkage-wise, which was not necessarily just making sure that throttle positions on each carb matched. Their performance was affected greatly by even a little wear. Kinda like the Amal's on a couple of BSA's I had. TP You got that right! Getting them syncd was a real PITA! I found a nice little gadget that helped immensely, and by coincidence happened to run across it about a week ago when looking for something else in the tool chest. Here's a pic: http://www.members.cox.net/drpics/carbtool.jpg Why I'm hanging on to it after 45 years is anyones guess, probably should put it on eBay!! But for watching what 3 SU's were doing simultaneously, it was great! The pistons dropped in place of the damper and would rise/fall with the suction, with the wire pointers lined up. Plus there were another half dozen tricks you could do with it. The one that looks like a weird crank shaft was to adjust the float arms. Beats the hell out of sticking your head in there with a stethoscope listening to the hiss... d:-)) Cheers'n beers.. [_]) Don |
"LWG" wrote in
: I got good results from a piece of Tygon tubing. Just make sure you placed the end at the same spot on each carb. Yeah, tha's the best way, really. I've used all the gadgets for them, the wire incatoers put in the dashpots, the gauges, just listening to the whistle in the pipe is probably the best. Bertie |
Mythbusters Episode and FMS | Marco Leon | Piloting | 19 | February 13th 07 05:45 AM |
..and another hour... | hellothere.adelphia.net | Rotorcraft | 7 | October 7th 04 11:26 AM |
Mythbusters and explosive decompression | Casey Wilson | Piloting | 49 | July 15th 04 05:56 PM |
MythBusters | Hilton | Piloting | 7 | February 4th 04 03:30 AM |
Mythbusters Explosive Decompression Experiment | C J Campbell | Piloting | 49 | January 16th 04 07:12 AM |
