Interested in soaring safety? Read this
Old December 16th 07, 08:44 AM posted to rec.aviation.soaring
309
Default Interested in soaring safety? Read this
On Dec 16, 12:12 am, Ramy wrote:
Yeah, but my point is, how can you make sure you will follow the
checklist
T-R-A-I-N-I-N-G. P-R-A-C-T-I-C-E.
As Henry says: "Take the tow."
As Pete says: "Take the CFIG." At least once a year.
Practice your emergency procedures (no flap landings, no spoiler
landings). What do you think the military pilots do most of the
time? What do commercial pilots expect when they take their simulator
rides (at least once a year, sometimes twice a year)?
Make your own checklist. I've gotten in the habit of doing that for
each airplane (and each glider) I fly. As a Flight Test Guy, this
saves lives, saves money and makes the difference between success and
failure. The sun is setting on these items, but how many diamonds
would have been ACHIEVED if the checklist (the usually non-existent
checklist) had included the following two items:
1.) Wind barograph.
2.) Load film in camera, wind camera.
How many lives (and gliders) would have been saved if these had been
on the checklist?
A.) Positive Control Check - Elevator
B.) Positive Control Check - Rudder
C.) Positive Control Check - Aileron Left
D.) Positive Control Check - Aileron Right
E.) Positive Control Check - Spoiler Right
F.) Positive Control Check - Spoiler Left
Yup, I've been a dummy: took off once with the static ports still
taped over. Knew what to do: turned it into a pattern tow and a
practice "emergency" landing. Untaped the statics, did a (more
thorough) complete walk-around (preflight), got in line and took the
relight for a damn fine flight. And statics got added to the
preflight checklist!!! BTW, that's not the only time I've been a
dummy -- those that know me ...
A checklist is no substitute for airmanship. RAS posting is no
substitute for getting current AND competent in your machine. It
seems that too many of us get one or two flights in at the beginning
of the season, and then go striking out hunting diamonds (yeah, me
too). We should spend more time locally, with or without the Constant
Flight Interruptor aboard. We should practice more landings, short/
soft field with obstacle landings...simulated landing out landings.
After you use a checklist for a while, you'll find that they're
terrific security blankets, and help you relax more during the
flight. Keep the mnemonics (USTALL, TWA, GUMP) as safety nets. When
you forget your checklist, and feel brave enough to fly without it,
make sure you touch and say every item within your reach (spoilers,
release, flaps, gear, relief tube...).
The pros fly with checklists. The FAA condones the discipline. Many
accident investigation reports cite, as one of the causes, the crew's
failure to follow the appropriate checklist.
It's at least as important as your parachute. Hopefully, you'll use
the checklist more often.
-Pete
#309
Old December 16th 07, 09:39 AM posted to rec.aviation.soaring
Ian
taped over. ... And statics got added to the
flight.
Security blankets are not necessarily a Good Thing. After all, it
seems you may have missed your taped over static ports because they
weren't on your check list ... what's going to be next? Not that I'm
knocking the whole idea, you understand - I have a nice laminated list
of rigging and derigging stuff.
The pros are flying vastly more complicated aircraft and have vastly
more time available to read checklists.
Ian
Old December 16th 07, 11:28 AM posted to rec.aviation.soaring
J a c k[_2_]
Ian wrote:
The pros are flying vastly more complicated aircraft...
True, though the pilot/aircraft interface gets simpler all the
time--until you get to the programming part.
...and have vastly more time available to read checklists.
False. Though we may have a crew to share the load, it takes more time
to work with a crew. The time available to provide a solution is often
inversely related to the size of the problem.
In single-seat aircraft you are generally going very fast, have even
more complexity, and often feel that you don't have enough hands to do
all the things that need to be done in the time available, which can be
so short as to seem virtually non-existent. That's why there are
ejection seats--wonderful "zero/zero" rocket-powered seats.
If the above sounds to some like an argument against reliance on
checklists, in fact my position is that checklists must be first and
foremost practical--short, sufficient, and sometimes memorized--but they
should always be used.
Checklists work, and AOA works. Though the use of each must be adapted
to the ship, the mission, and the circumstances, I suspect those who
avoid or deride either one do so for their own emotional reasons and not
out of a real understanding of their value.
Jack
Old December 16th 07, 12:03 PM posted to rec.aviation.soaring
Ian
The pros flying commercial jets /do/ have more time to deal with check
lists because (a) the person flying the aircraft doesn't necessarily
have to have anything to do with the checklisting (b) they have
autopilots and (c) they don't need to look out.
I'm basing this on a few jump seat trips (in the Good Old Days), but I
have never had time in a glider to take my hands off the controls,
focus wholly on the inside of the cockpit and go through a seventeen
point check list...
Incidentally, you say that "checklists ... should alway be used". Do
you have a checklist for joining thermals? For thermal centring? For
stall recovery? For dolphin flying?
Ian
Old December 16th 07, 07:19 PM posted to rec.aviation.soaring
J a c k[_2_]
Those are all very nice things to have--some of them are even true. Of
course there are checklists, and then there are checklists--and many
different kinds of problems to be encountered. We do in fact make an
effort to slow things down and create more time to do checklists, both
written and mental, when possible. The study of crew coordination, and
use of all the crew's resources, has become a science--and a new respect
for the art of cockpit resource management permeates the industry. It
appears you believe the foregoing is somehow an argument against using
checklists in other types of aircraft. I think it should, for those with
open minds, describe the importance to professionals of defining the
proper use of check lists and training oneself and others in using
checklists appropriately.
(a) The removal of the flying pilot from the checklist loop is not a
smart idea, though he cannot give full attention to it. He must be aware
of what is happening with regard to the problem-solving process and
participate in it to an appropriate extent, without ever being
distracted from aircraft control. Doing the checklist is the easy part.
(b) The autopilots usually work--but not always. There was no checklist,
as I remember it (retired now for five years), for loss of all autopilot
function. What do you suppose we would do then--possibly refer to a
mental "checklist" of things which must be approached in a different
manner in order to insure a successful outcome?
(c) There are times when less visual clearing is necessary than at other
times. You may have seen a crew paying less attention to what's going on
outside periodically during the high altitude cruise portion of a
flight. That too is human nature, but there are very few times when it
is appropriate to ignore what's happening outside for more than a few
seconds. There are some quite infamous examples where that has been
disastrously demonstrated.
The best glider pilots I have flown with do use checklists appropriate
to gliders and use them in a manner which enhances the safety and
efficiency of glider operations. And I base my evaluation of their
abilities on far more than their use of checklists, by the way--in case
you perceive me as some sort of anal procedural-minded robot. I doubt
that those I have flown with would agree with such a perception.
Though it has been decades since I last flew a military fighter (the
F-100) it is my understanding that military pilot training has adapted
in similar fashion and parallels airline training with regard to use of
checklists and resource management. These principles are not new
however, only the system's acknowledgment that the scientific approach
to resource management is superior to the old model is new (relative to
the mindset of a half-century ago).
When there is only one crew member, no autopilot, and very little that
can possibly go wrong with the ship, what is different but the number of
checklists and their length? Do the principles change? I think not.
point check list.
Of course, I don't have the advantage of a perspective on these matters
gained from a few jump seat trips. I've spent far too many hours in
jump-seats, though perhaps just the right amount of hours in right- and
left- and only-seats. And it is possible I've encountered a
seventeen-point checklist along the way, but I don't remember any. I do
remember very well the efforts to shorten the checklists, as well as to
reduce the number of items which must be committed to memory. That was,
and is, a good thing.
If you have never had occasion to remove your hands from the flight
controls in a glider, perhaps you should try to relax more. The ship
sometimes does better on its own, at least for me.
I think one could answer, "Yes", to your question, but only in the most
pedantic sense. You will, upon rereading, perhaps note that I did not
say that there should be a checklist for every action--nor every
consideration--that a pilot undertakes. I do have both mental and
written checklists for certain phases of flight. The written ones are
very few, and very short. The challenge is to use them, always, because
it is my nature, as with most humans, to think in the moment that I
don't need them. Flying a glider is, I'm sure you will agree, a very
simple sort of flying. It can be deceptively so. One needs only to
forget a single item to ruin ones day.
If a checklist is defined for a given phase of your operation, then use
it--or not, since we are unlikely ever to fly together, or even in the
same area. If I was instructing and/or giving check-rides in gliders I
would require the use of a written checklist for certain aspects of
pre-flight, in-flight, and post-flight operations. You would likely not
be pleased to be in the other seat, but I can live with that.
Jack
Old December 16th 07, 09:37 PM posted to rec.aviation.soaring
Ian
We are in complete agreement, you know. I don't think either of us
would substitute "indiscriminately" for "appropriately", would we?
How would you define "best glider pilots" there? I have flown a few
times with a world champion, and he did not ask for any more than the
usual two BGA mnemonics.
That's perhaps a little evasive, since the number and length may
change drastically in such circumstances. But yes, the principal of
"use checklists when appropriate" holds good!
We agree there as well.
I'm a bit worried by this "if there is a checklist, use it" approach.
Now that I've told you about the NARSTI checklist for winch cable
breaks, will you always use it?
Please don't get me wrong. I'm not agin' the things - but I am agin'
unquestioning acceptance of anything while flying. Except spin
recovery!
Ian
Old December 17th 07, 02:57 AM posted to rec.aviation.soaring
J a c k[_2_]
They were better than the other glider pilots I've flown with.
I have flown a few times with a world champion, and he did not
ask for any more than the usual two BGA mnemonics.
Sounds appropriate to me. I don't advocate papering the cockpit with
checklists.
Undoubtedly not. I've not seen a cable launch and don't expect to see
one. I'd certainly use the checklist recommended by my CFI, until I
developed my own.
recovery!
Unquestioning acceptance not spoken here.
Jack
Old December 17th 07, 09:04 AM posted to rec.aviation.soaring
309
Okay, Ian, I'll fess up: that static port episode was before I
religiously used checklists in anything that weighed less than 4,000
pounds. It became one of those pivotal (thankfully non-fatal and
inexpensive) events that convinced me that it doesn't matter how
simple the aircraft is. As Max Stanley is quoted: "The Piper Cub is
the safest aircraft in the world -- it can just barely kill you."
Religious use of a checklist doesn't necessarily mean plastering the
sides of your cockpit, and spending more time looking at the paper
than the scenery: Reviewing a checklist prior to the flight (even the
night before) can re-etch the memory of how to do it right, and
quickly. And frequently, you go through the motions (using cranial or
muscle memory) and then REVIEW the checklist -- and sometimes catch
the item that was forgotten.
P.S.: The mere act of WRITING a checklist helps you truly understand
the aircraft systems (simple or not), the proper operating procedures
(and perhaps a better "flow" of the steps than the manufacturer
originally suggested). The benefit of this remains -- although less
so -- even if you never use the list again. Look at pilots &
instructors who fly multiple types of aircraft: They use checklists
(sometimes very short ones that are referred to as "cheat sheets") so
they refresh their mind that this aircraft has a best L/D speed of y
and a min sink speed of x (or for power, Vx, Vy, Vglide, VLE, VLO,
Vfe, Vmc, Va, Vne, Vno). The "best" instructors share their cheat
sheets with their students, but implore (or force) their students to
fabricate their own.
P.P.S.: Jack is right: Big Iron Crews do NOT necessarily have more
time. Especially in Flight Test, I have witnessed where pre-briefing
a checklist made the difference between incident (safe return) and
disaster. During most normal operations they do have more time -- in
part thanks to orderly and well arranged checklists!
P.P.P.S: Yes, there's a checklist for thermalling: Somebody's
already in thermal: follow his direction of turn. Nobody else? Try
my luck to the left...
Last note: I haven't seen it quite so much with the major airlines
(except for basic aviation skills), but in the military there are
Emergency Procedures and there are BOLD FACE EMERGENCY PROCEDURES:
All pilots flying a given type are required to memorize Bold Face
procedures!
Okay, final note: If you look in all of the manuals, there is never
any additional procedures or writing after the word EJECT.
-Pete
#309
Old December 17th 07, 11:48 AM posted to rec.aviation.soaring
Ian
I wrote my rigging and derigging instructions on the basis that
someone someday might have to take my glider apart while I was
elsewhere (in hospital? under arrest? dead?). It was quite instructive
to commit to writing all the wrinkles I had developed myself.
I had the pleasure of working with Anne Welch some years ago. When she
was in the Air Transport Auxiliary during the Second Big
Unpleasantness she wrote many of the single sheet briefing notes
designed to let a (good) pilot do a basic delivery flight in a new
type safely. They make fascinating reading - who operating manuals
stripped to the absolute minimum. Undercarriage up with three pulls on
this lever, down with five pumps on that. Take off vacuum and rpm so,
cruise so, landing so.
All BGA gliders have a placard giving Vne, Vwinch, Vaerotow and
Vroughair, and I make it my policy /always/ to reread that before /
every/ launch. Good grief, I'm a checklist user!
Ian
Old December 16th 07, 03:08 PM posted to rec.aviation.soaring
jcarlyle
Pete, what does the mnenomic TWA stand for?
-John
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 [email protected] Soaring 0 November 8th 07 11:15 PM
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA [email protected] Soaring 0 September 11th 06 03:48 AM
Read and Post for Air Safety ManfromZetar Piloting 2 July 30th 05 04:48 PM
Off topic, Gore and the internet (don't read if not interested) Corky Scott Home Built 42 June 18th 05 04:06 AM
Toronto Pilots own web board address (don't read unless interested) FOOTANDMOUTH Piloting 0 July 23rd 03 01:10 AM
