Interested in soaring safety? Read this
Old December 16th 07, 04:52 PM posted to rec.aviation.soaring
309
Default Interested in soaring safety? Read this
On Dec 16, 7:08 am, jcarlyle wrote:
Pete, what does the mnenomic TWA stand for?
-John
On Dec 16, 3:44 am, 309 wrote:
Keep the mnemonics (USTALL, TWA, GUMP) as safety nets.
TWA = Traffic, Wind, Altimeter (or Altitude)
GUMP = Gas, Undercarriage, Mixture, Prop (obviously for Power)
USTALL = Undercarriage, Speed, Trim, Airbrakes, Lookout, Land
see http://www.soaringsafety.org/images/ustall.jpg for a USTALL poster
I find myself using GUMP even in my 1-26...obviously completing that
checklist is very quick...and it prompts me to remember the other
two...which are similarly quick (Trim on a 1-26 is of marginal utility
on approach).
Nevertheless, they get me set up for safe landings...whatever I'm
flying!
-Pete
Old December 16th 07, 06:08 PM posted to rec.aviation.soaring
jcarlyle
Thanks, Pete. I use USTALL on every approach set-up, and have heard
GUMPS, although as a non-power pilot I've never used it. But I've
never run across TWA, and I wonder why - it seems very, very important
for any landing! Thanks for educating me, and giving me a checklist
I'll be doing on all future approach set-ups.
-John
seehttp://www.soaringsafety.org/images/ustall.jpgfor a USTALL poster
Old December 16th 07, 06:13 PM posted to rec.aviation.soaring
Great discussion so far.
A couple points...
In soaring we DO have crew particularly in the staging, take-off, and
tow phase. We sometimes have crew during landing as well if there is
a ground crew with radio. So, crew resource management has great
value in soaring operations and should be utilized.
One of the jobs crew can perform is making sure pilots complete their
checklists; Critical Assembly Checks, Positive Control Checks, and, if
done out-loud, pre take-off checklist. Teach your ground crew not to
hook-up a towline until they hear the pilot complete the checklist.
In-cockpit checklists for glider ops should be done from memory (pre
take-off, landing, off-airport landing) WUFSTALL can be completed
easily in 20 seconds if done from memory and at the approapriate time
during the approach.
CBSIFTCB plus WET (wind, emergency procedures, traffic) takes less
than a half a minute to SAY OUT LOUD and verify or touch each item. I
teach to say "Emergency below 200 ft lower the nose land ahead, above
200 lower the nose, land ahead or behind". Anything more is either
too much, takes too long, or just simply too confusing for the reptile
brain that will be trying to accomplish it during a real emergency.
On the last item, Traffic, make eye contact with the ground crew who
should now be patiently waiting at your wing tip and say TRAFFIC and
look around to remind them to look around for you. This is crew
resource management. It takes no extra time and gets everyone
watching each others back. There is no excuse for taking-off with
canopys unlatched, controls not hooked-up.
Look for other ways in which CRM can be utilized in soaring operations
and share them with others here.
Matt Michael
Old December 16th 07, 09:41 PM posted to rec.aviation.soaring
Ian
One club I fly with has a column in the launch log for "positive
control checks completed" and won't launch you until this has been
done (once per day) at the launch point. I think that's a jolly good
idea.
I teach to say "Emergency below 200 ft lower the nose land ahead, above
How accurate are your altimeters during a winch launch?
Ian
Old December 16th 07, 10:01 PM posted to rec.aviation.soaring
Good point Ian. This is specific to aero tow launch which I did not
specify. Most are taught to call out 200 ft on aerotow to mark that
critical alt. It is a general benchmark.
My limited experience with ground tow launch which I haven't done in
some years, reminds me that the tow failure response is different.
IIRC it's more along the lines of, Lower the nose, confirm airspeed,
decide where to go (which is often site specific) pull release, and
maneuver to land.
Ian
Old December 17th 07, 09:07 AM posted to rec.aviation.soaring
309
Ian
My recollection of winch training suggests that the trained response
to a cable break is to lower the nose. Once that is done and the
glider moves 32.8 feet (10 meters), the altimeter should be as
accurate as anywhere else in the envelope. And as other posters have
pointed out, that's where the decision time begins.
Good food for thought.
-Pete
Old December 17th 07, 09:18 AM posted to rec.aviation.soaring
309
Matt Michael
My first Glider Instructor taught me a simple pre-takeoff checklist:
A
B
C
C
C
D
I added another D.
Another instructor implored me to add E
A-Altimeter
B-Belts
C-Canopy
C-Controls
C-Cable (in that order!)
D-Direction of Wind
D-Dive Brakes (spoilers to some)
D-Dummies In The Patter (my way of categorizing "traffic")
E-Emergency Procedures and Plans.
The good Big Iron drivers BRIEF every takeoff (heading, speeds, what
to do in an emergency).
The great Big Iron Test Pilots pre-Brief every takeoff, and who's to
do what when (not if) something goes wrong...even for a normal non-
test takeoff. Taking an unfamiliar FAA Test Pilot with us once, the
captain briefed the FAA pilot "If something goes wrong, YOU fly the
airplane, and I'll deal with the emergency, since I'm more familiar
with the aircraft/systems/etc." We can do this with our ground crews,
too, as Matt has suggested.
Some of us treat our checklists like we treat our parachutes: like a
talisman. If we take care of them, have them and know how to use
them, they will perform the function of a good luck charm, and ward
off emergencies, ramp checks and embarrassing appearances on the five
o'clock news.
-Pete
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 [email protected] Soaring 0 November 8th 07 11:15 PM
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA [email protected] Soaring 0 September 11th 06 03:48 AM
Read and Post for Air Safety ManfromZetar Piloting 2 July 30th 05 04:48 PM
Off topic, Gore and the internet (don't read if not interested) Corky Scott Home Built 42 June 18th 05 04:06 AM
Toronto Pilots own web board address (don't read unless interested) FOOTANDMOUTH Piloting 0 July 23rd 03 01:10 AM
