Bonanza (A36) Approach Speeds
Old December 17th 07, 01:35 AM posted to rec.aviation.piloting
Newps
Default Bonanza (A36) Approach Speeds
I have an S35. Eckelbar reccommends 15-16 inches and whatever RPM you
had it at in cruise, 2100-2500. I get 135-140 MPH indicated and fly the
approaches at that speed. At the outer marker/FAF/inbound course
intercept I'll lower the gear. That by itself tips the nose over to
about 500 fpm, and slows you down about 20 mph, just what you need for
the ILS. Fly the rest of the approach at about 110 MPH indicated. No
need for flaps until short final if you want them, otherwise don't
bother. As you pull more power out it slows down nicely.
Any other Bonanza pilots have thoughts on Approach Speeds?
Eckelbar posits 105 knots. I've tried it and it works, but is a
handful to reconfigure and slow down in time for a more reasonable 75
KIAS final approach speed.
Dick Collins recommends flying approaches fast ("the runways are
usually long..")
Thoughts?
Old December 17th 07, 01:43 AM posted to rec.aviation.piloting
Thanks.
That's pretty much what I've been doing to date -- slow to 105 prior
to FAF, drop gear at FAF, re-trim to maintain 105, descend at 550-600
FPM (depending on headwind).
The only I problem I see with this method is that once the runway is
in sight, there's a significant configuration change to slow the
airplane down and still remain on glideslope while getting to a more
appropriate approach speed (The A36 POH only specifies NORMAL LANDING
APPROACH SPEED).
The A36 lands in a very short space at 70 KIAS approach speed (power
is required to arrest the descent at that slow an airspeed). 78 KIAS
is recommended for power off emergency landing, so is probably the
best speed for short final.
I don't agree with the stereotypical Bonanza driver that lands at 100
KIAS and needs 4000 x 150 or greater. This wing will fly at a slow
enough speed to keep the landing roll short -- very short, in fact.
Dan
F-18 Approach and touchdown speeds on runways? Paul Michael Brown Naval Aviation 5 August 25th 04 04:56 PM
Approach speeds for ILS C J Campbell Instrument Flight Rules 73 March 2nd 04 11:20 PM
Approach speeds for ILS C J Campbell Piloting 71 March 2nd 04 11:20 PM
LSA Approach speeds Ace Pilot Home Built 0 February 3rd 04 05:38 PM
Approach speeds for ILS G.R. Patterson III Piloting 0 January 22nd 04 10:13 PM
