Hangar construction question - Level Hangars?
Old December 17th 07, 07:46 PM posted to rec.aviation.owning
Al G[_1_]
Default Hangar construction question - Level Hangars?
"Gig601XLBuilder" wrote in message
On Dec 17, 10:19 am, "Al G" wrote:
Our City Council recently had some t-hangars built at KRBG. They
were
built on a slope, I think 1.5%. The doors open real easily one way, and
need
help going the other way. The floors aren't level, the walls aren't
vertical, albeit not by very much.
My question is: Doesn't this cause some structural problems? If a
snow
load is put on these hangars, doesn't that put a lateral load on the
vertical columns? I don't ever remember a building being built where the
walls weren't vertical.
Al G
Hard to believe they passed a building inspection, or received a CO.
Ben
It all kind of depends on how they were offset from vertical.
_______
Is going to be stronger than...
_____________
Of course, if you have this...
___________
You're screwed.
Yep, the last one. I've been inside, and saw no special diagonal
bracing. The interior is supported by a large steel "T"'s running East/West,
with the posts landing in the middle wall. The hangars open East & West, and
the slope is North/South. It appears that only the hangar skin is supporting
any load diagonally, and that has the doors cut in it.
In addition, the distance from doors to the middle wall is shorter than
the distance from the middle wall to the back of the hangar. A Bonanza, 210,
or Warrior all stick out of the door. I guess something like a T-Craft or
Cub would fit.
These are brand new $200/month T-Hangars, fingers are being pointed, and
the airport manager just quit. I don't know if it matters, but keep in mind,
this is a city building. They have not needed to comply with the buried
drainage ditches like all the other builders. One of their drainage gutters
came out 9" above the hangar line it was to protect. An Audit is underway.
Al G
Old December 17th 07, 08:50 PM posted to rec.aviation.owning
Jay Honeck
If this was anything but an airport issue, I'd recommend calling the
local newspaper.
Unfortunately, they'd probably twist this whole screwed-up mess into
an anti-airport article -- so perhaps working inside the city
(guaranteed to be frustrating and maybe damned-near impossible) to get
this fixed is best.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 18th 07, 12:42 AM posted to rec.aviation.owning
were
need
snow
Al G
Ben
_______
_____________
___________
You're screwed.
Cub would fit.
Al G- Hide quoted text -
- Show quoted text -
A Warrior can't fit ???? Geez, That is a BIG screw
up. !!!!!!!!!!!!!!!!!!!!!!!!
Ben
www.haaspowerair.com Home of the "beast"
My first 500 hours were in my own Warrior, N4341X.. I loved that
plane.....
Old December 18th 07, 12:48 AM posted to rec.aviation.owning
Kyle Boatright
were
and
need
a
snow
Al G
Ben
_______
_____________
___________
You're screwed.
East/West,
and
supporting
than
210,
Cub would fit.
and
mind,
gutters
underway.
Not necessarily. My home field is installing 3 different sizes of T and Box
hangars sized for different types of aircraft. Some are sized for twins up
to MU-2 sized, others are for singles and small twins, and others will fit
smaller aircraft such as AA-1's, RV's, and ultralights.
I'm not saying this is a great solution, but in my airport's situation, it
did result in the best use of the available land.
Ben
plane.....
Blood Oxygen level question. Udo Soaring 12 January 27th 07 12:34 PM
question KR-2 or KR-2s construction BA Home Built 11 September 6th 06 11:32 PM
Horsepower required for level flight question... BllFs6 Home Built 17 March 30th 04 12:18 AM
post vs stick hangar construction Joa Home Built 25 November 1st 03 01:03 PM
post vs stick hangar construction Joa Owning 24 November 1st 03 01:03 PM
