I'm writing a few "contest corners" for Soaring magazine to explain
this year's rule changes. The explanation for the new cylinder finish penalty is on my webpage at http://faculty.chicagogsb.edu/john.c...h_cylinder.htm This will be in Feb Soaring, and more will follow. John Cochrane |
Looks like an excellent change to the circle finish procedure.
Sure wish it had been in effect last year! ;) Good work, guys. Kirk 66 |
Same comments as others. I can live with this.
Thanks to John Cochrane for the discussion on his Web page. One question: could a pilot who's low on final glide enter the finish cylinder below the floor, land out just short of the contest site, and receive distance points MINUS a low finish penalty? That seems a bit harsh but is how I interpret John's statement, below. I could be mistaken: "If there isn't even a weak thermal [on a marginal final glide that winds up inside the cylinder but just short of the contest site], the 70 points you will lose on the finish, combined with the new larger distance points, mean that there is less to be lost by landing in that last nice field on this side of the trees." I actually had trouble finding the part in the Rules where it says you have to land back at the contest site to get speed points. You get a finish time just by entering the cylinder without regard to where you land: 10.9.3.3 The Finish Point, radius, and minimum height define a three- dimensional Finish Cylinder. A finish occurs when a sailplane enters the Finish Cylinder; at least one fix must lie within the cylinder. The finish time is taken as the interpolated time the sailplane first entered the Finish Cylinder. But a later paragraph finally says you have to land back to complete the task: 11.2.2.4 Task completion - If all turnpoints are valid, yield a scored distance (Rule 11.2.3) not less than the Standard Minimum Task Distance and the pilot obtained a scored start time, a finish time prior to finish closing and landed at the contest site, then the pilot has completed the task. Otherwise the task is incomplete. OK, flying is over for me until next spring. I just don't want to be worrying about this low on final glide next year. ![]() Chip Bearden ASW 24 "JB" U.S.A. |
On Dec 18, 12:00 pm, Chip Bearden wrote:
Same comments as others. I can live with this. Thanks to John Cochrane for the discussion on his Web page. One question: could a pilot who's low on final glide enter the finish cylinder below the floor, land out just short of the contest site, and receive distance points MINUS a low finish penalty? That seems a bit harsh but is how I interpret John's statement, below. I could be mistaken: "If there isn't even a weak thermal [on a marginal final glide that winds up inside the cylinder but just short of the contest site], the 70 points you will lose on the finish, combined with the new larger distance points, mean that there is less to be lost by landing in that last nice field on this side of the trees." I actually had trouble finding the part in the Rules where it says you have to land back at the contest site to get speed points. You get a finish time just by entering the cylinder without regard to where you land: 10.9.3.3 The Finish Point, radius, and minimum height define a three- dimensional Finish Cylinder. A finish occurs when a sailplane enters the Finish Cylinder; at least one fix must lie within the cylinder. The finish time is taken as the interpolated time the sailplane first entered the Finish Cylinder. But a later paragraph finally says you have to land back to complete the task: 11.2.2.4 Task completion - If all turnpoints are valid, yield a scored distance (Rule 11.2.3) not less than the Standard Minimum Task Distance and the pilot obtained a scored start time, a finish time prior to finish closing and landed at the contest site, then the pilot has completed the task. Otherwise the task is incomplete. OK, flying is over for me until next spring. I just don't want to be worrying about this low on final glide next year. ![]() Chip Bearden ASW 24 "JB" U.S.A. Chip, this could get interesting! What is the definition of "the contest site"? Out west, you could find an old WW2 airfield and almost have the one mile finish circle within the airport boundaries. Do you have to land on a designated runway? What about Ionia, where landing on the infield (between paved runway and taxiway) is allowed? Or landing on a ramp/taxiway/clear area after floating across the fence? Still a good start. Come on spring! Good stuff for discussion around the virtual fireplace, while consuming a non-virtual adult beverage... Kirk 66 |
On Dec 18, 1:00 pm, Chip Bearden wrote:
Same comments as others. I can live with this. Thanks to John Cochrane for the discussion on his Web page. One question: could a pilot who's low on final glide enter the finish cylinder below the floor, land out just short of the contest site, and receive distance points MINUS a low finish penalty? That seems a bit harsh but is how I interpret John's statement, below. I could be mistaken: "If there isn't even a weak thermal [on a marginal final glide that winds up inside the cylinder but just short of the contest site], the 70 points you will lose on the finish, combined with the new larger distance points, mean that there is less to be lost by landing in that last nice field on this side of the trees." I actually had trouble finding the part in the Rules where it says you have to land back at the contest site to get speed points. You get a finish time just by entering the cylinder without regard to where you land: 10.9.3.3 The Finish Point, radius, and minimum height define a three- dimensional Finish Cylinder. A finish occurs when a sailplane enters the Finish Cylinder; at least one fix must lie within the cylinder. The finish time is taken as the interpolated time the sailplane first entered the Finish Cylinder. But a later paragraph finally says you have to land back to complete the task: 11.2.2.4 Task completion - If all turnpoints are valid, yield a scored distance (Rule 11.2.3) not less than the Standard Minimum Task Distance and the pilot obtained a scored start time, a finish time prior to finish closing and landed at the contest site, then the pilot has completed the task. Otherwise the task is incomplete. OK, flying is over for me until next spring. I just don't want to be worrying about this low on final glide next year. ![]() Chip Bearden ASW 24 "JB" U.S.A. If you don't land on the contest site as defined by the CD, you get disatnce points. You get speed points by: Finishing in the cylinder with plenty of energy like a "good boy:. Or landing on the contest site after missing the bottom of the cylinder and getting speed points less the penalty fopr missing the bottom. The good news is that if you miss there is no reason to rush the landing or do something stupid, you just land safely. This is the essence of the change John suggested. UH |
Come on, guys, play along. What I was "griping" about was the prospect
of arriving back really low, hitting the new finish cylinder just above the trees and then dumping it into the last field before the barbed wire fence around the airport. BB implies (well, he goes further than that; you be the judge) that you would get distance points only AND get banged with a low finish penalty. Depending on how the new rule is implemented, you've scored a finish time because if you'd floated across the fence, you would have completed the task. But since you're sitting in the dirt staring up at the real finishers, the rules say you haven't finished the task. So...distance points for the non-completion minus a penalty for the low finish; in other words, significantly fewer points that the guy who landed in the field behind you who didn't get to the cylinder? I'm not making this up; read below from BB's article (emphasis added). ![]() "...the 70 points you will lose on the finish, COMBINED WITH the new larger distance points, mean that there is less to be lost by landing in that last nice field on this side of the trees." Chip Bearden ASW 24 "JB" U.S.A. |
On Dec 18, 4:28 pm, Chip Bearden wrote:
Come on, guys, play along. What I was "griping" about was the prospect of arriving back really low, hitting the new finish cylinder just above the trees and then dumping it into the last field before the barbed wire fence around the airport. BB implies (well, he goes further than that; you be the judge) that you would get distance points only AND get banged with a low finish penalty. Depending on how the new rule is implemented, you've scored a finish time because if you'd floated across the fence, you would have completed the task. But since you're sitting in the dirt staring up at the real finishers, the rules say you haven't finished the task. So...distance points for the non-completion minus a penalty for the low finish; in other words, significantly fewer points that the guy who landed in the field behind you who didn't get to the cylinder? I'm not making this up; read below from BB's article (emphasis added). ![]() "...the 70 points you will lose on the finish, COMBINED WITH the new larger distance points, mean that there is less to be lost by landing in that last nice field on this side of the trees." Chip Bearden ASW 24 "JB" U.S.A. It's in the sentance structure- He's really comparing the score of a 1 ft short finish to a missed cylinder speed finish. The spread is less than before. If you don't get the finish, you don't get the low finish penalty. John's "social engineering" is intended to take away scoring incentives for marginal finishes. Winter must be upon us. UH |
![]() Winter must be upon us. UH Look out the window Hank, winter is here in force. Todd Smith 3S |
ft short finish to a missed cylinder speed finish. The spread is less than before. If you don't get the finish, you don't get the low finish penalty. John's "social engineering" is intended to take away scoring incentives for marginal finishes. Winter must be upon us. UH- Thanks. I feel much better. ![]() But just in case, I'm going to print out this thread and take it with me to next year's contests to avoid a situation like we had at Fairfield where everyone agreed the intent of the rules was almost certainly X but the letter of the rules was Y. JB |
Chip,
Do I detect a rather large tongue in a small cheek, here? I don't see any way you could be given a finish circle penalty, if you were scored as a land-out. Why don't you ask Uncle Hank if us poor standard class guys will be given the 2% reward, if we are forced to fly with those big bad 15 meter pukes in a small regionals? JJ But just in case, I'm going to print out this thread and take it with me to next year's contests to avoid a situation like we had at Fairfield where everyone agreed the intent of the rules was almost certainly X but the letter of the rules was Y. JB |
US SSA/SRA Contest Rules Poll | Ken Sorenson | Soaring | 18 | November 4th 07 05:59 PM |
2005 SSA Rules Committee Meeting Minutes Posted | Ken Kochanski (KK) | Soaring | 1 | December 20th 05 05:38 PM |
2005 SSA Contest Rules Poll and Election | [email protected] | Soaring | 0 | September 27th 05 01:47 PM |
New SRA Site - New 2003 Rules Minutes and 2004 Rules Summary | Ken Kochanski | Soaring | 0 | December 17th 03 03:38 AM |
