Kirk,
Could you summarize for me _how_ you used the AOA indicator in those aircraft, which aircraft and under what conditions ? I am curious to the actual use(s). Thanks Todd Smith 3S Sure. I used AOA in T-38s (a little - not much flight time in those) and in F-4s (about 2000 hours in those). In my current job, I fly a variety of F-15 simulators (the real thing, not PC games) and use AOA all the time. Have also a few flight in F-16s and a lot of time in F-16 simulators, which use AOA in the approach and landing configuration. In a nutshell, AOA is used anytime optimum performance is required from the wing - be it turning, flying an approach, flying for max range, recovering from a dive, etc. Since fighters can vary weight a lot due to fuel burn and store (weapons) configuration, it's impractical to try to use airspeed other than as a general guide to your energy state - your airspeed tells you how much instantaneous energy you have to maneuver, then you fly at the AOA that matches the type of turn you want - less AOA is conserves energy, more AOA turns faster, etc. If you are flying for max range or max endurance, again there is a recommended AOA to fly at - it will stay the same while the actual airspeed changes based on gross weight, configuration, and altitude. Finally, in the pattern, you figure out the approximate airspeed and AOA based on fuel and stores remaining, then crosscheck the two - if they agree, it's easier to fly AOA on most jets (F-4 especially, F-15 less so). Now, compared to gliders, these are all extremely low aspect ratio, and that will exaggerate AOA effects. But the aerodynamic priciples are the same. Finally, someone questioned about whether it's better to thermal efficiently or in the best part of the themal. The answer, IMHO, is that you should strive to do both. Right now we have wonderful instruments to help us find the best lift. But we still use a crude instrument to fly efficiently. Well, actually, most people probably thermal more by feel and attitude than by staring at the airspeed indicator. End of war story. Cheers, Kirk |
On 20 Dec, 14:42, "kirk.stant" wrote:
Ian, we appear to be comparing apples and oranges - you are talking about not stalling on final, while I am talking about being able to accurately thermal, and incidentally have a better instrument for flying accurate approaches. I wonder how much "flying at Clmax" matters in good thermalling compared with "being in the right bit of the thermal"? Obviously, my opinion is colored by having actually flown airplanes with excellent AOA systems, and by my wish to optimise my soaring for XC and racing. I really think that within a few years someone will come up with a simple, low drag, accurate AOA system that will be adopted by the same group of pilots who eagerly adopted radios, TE, audio varios, glide computers, GPS, PDA moving maps, transponders, ELTs, traffic detection devices - all those "unecessary" gadgets that clutter up our cockpits but, in my opinion, make soaring safer, more efficient, and more fun. If it does these things I'll be all for it. If it costs less than twenty quid I may even buy one. As a matter of interest, how do you define "efficient" here? Ian |
Ian wrote:
On 20 Dec, 14:42, "kirk.stant" wrote: Ian, we appear to be comparing apples and oranges - you are talking about not stalling on final, while I am talking about being able to accurately thermal, and incidentally have a better instrument for flying accurate approaches. I wonder how much "flying at Clmax" matters in good thermalling compared with "being in the right bit of the thermal"? Minor correction: you should be thermaling at min.sink, which is the point at which Cl^3/Cd^2 is maximized. This is not in general the same as Cl max. Min.sink is usually at a slightly lower AOA than CL max because Cd is rising steeply with increasing AOA in the Cl max region. As a result, by the time you've slowed to Cl max you've passed min.sink and your sinking speed has started to increase. Since the polar is usually flatter on the faster side of min.sink I think you're better off thermaling somewhere between the min.sink and best glide speeds, preferably nearer the former. Best glide is the speed where Cl/Cd is a maximum. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
kirk.stant wrote:
In my experience, light power planes not really more susceptible to approach stalls than gliders, By approach stalls, so you mean stall on final approach? I thought that was a rare accident gliders, and that most stalls during landing occurred in the turns. but there are more distractions - including that noisy thing in the front just waiting to quit! Yet they mandate stall warnings. I don't know the reason that it's mandated, but that noisy thing up front does change things significantly. For example, under power in my motorglider, the nose attitude at 50 knots can vary from below the horizon to above the horizon; the attitude while gliding at 50 knots is constant and consistent. So, I suggest determining a safe AOA is harder in powered aircraft, and this makes a stall warning more valuable. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
John Smith wrote:
The solution is simple: Just don't get slow on your turn to final. Thank you, John. Go to the head of the class. Now, what is "slow"? Jack |
On 20 Dec, 01:55, J a c k wrote:
John Smith wrote: The solution is simple: Just don't get slow on your turn to final. Thank you, John. Go to the head of the class. Now, what is "slow"? That depends on the day. If wind shear is likely it will be significantly higher than on a calm day. Which means, of course, that on a windy day the safe AoA for the final turn will be significantly lower than on a calm day ... Ian |
On Thu, 20 Dec 2007 01:55:25 GMT, J a c k
wrote: Now, what is "slow"? The simple fact that you arre still able to write this proves that you know what "slow" is... ![]() Bye Andreas |
"Andreas Maurer" wrote in message
: Now, what is "slow"? The simple fact that you arre still able to write this proves that you know what "slow" is... ![]() Or he is lucky! Larry |
01-- Zero One wrote:
"Andreas Maurer" wrote in message : Now, what is "slow"? The simple fact that you arre still able to write this proves that you know what "slow" is... ![]() Or he is lucky! Oh, I am--very lucky--and have been for a long time. Jack |
On 24 Dec, 07:26, J a c k wrote:
Oh, I am--very lucky--and have been for a long time. As Arnold Palmer is reported to have said: "It's a funny thing, but the more I practice, the luckier I get." Ian |
