![]() "Clark" wrote in message ... No. Why don't you look at it and tell me how wide that "very nice corridor is"? Because you obviously don't believe me. I would rather wrestle with a pig than continue intercourse with your obtuse behavior. I suggest you learn how to look at photos produced through telephoto lenses. In other words, you have no idea how wide that "very nice corridor is". |
Steven P. McNicoll wrote:
No. Why don't you look at it and tell me how wide that "very nice corridor is"? [quoted text clipped - 4 lines] I suggest you learn how to look at photos produced through telephoto lenses. In other words, you have no idea how wide that "very nice corridor is". I was there. I saw it from a high vantage point. It appeared to be more than 500 - 800' or so. It is the same every year. Historically, vessel operators are pretty cooperative from my observations of being on the water during these events. The CG, FD and others enforce limits when necessary. -- Message posted via http://www.aviationkb.com |
![]() "Kloudy via AviationKB.com" u33403@uwe wrote in message news:7cfbe3564cb76@uwe... I was there. I saw it from a high vantage point. It appeared to be more than 500 - 800' or so. It is the same every year. Historically, vessel operators are pretty cooperative from my observations of being on the water during these events. The CG, FD and others enforce limits when necessary. Thank you. That's consistent with the estimate I made based on the number of vertical cables and distance between them. 500 - 800' wide means they were less than 500' from persons, vessels, and structure. |
On Dec 20, 2:23 pm, "Steven P. McNicoll"
wrote: "Kloudy via AviationKB.com" u33403@uwe wrote in messagenews:7cfbe3564cb76@uwe... I was there. I saw it from a high vantage point. It appeared to be more than 500 - 800' or so. It is the same every year. Historically, vessel operators are pretty cooperative from my observations of being on the water during these events. The CG, FD and others enforce limits when necessary. Thank you. That's consistent with the estimate I made based on the number of vertical cables and distance between them. 500 - 800' wide means they were less than 500' from persons, vessels, and structure. The 500' rule only applies to you Steve, and for good reason. |
I was there. I saw it from a high vantage point. It appeared to be more than [quoted text clipped - 4 lines] being on the water during these events. The CG, FD and others enforce limits when necessary. Thank you. That's consistent with the estimate I made based on the number of vertical cables and distance between them. 500 - 800' wide means they were less than 500' from persons, vessels, and structure. Maybe so. Just for grins, I contacted the Blue's PR dept. to see what is established for these performances. Now I'm really curious to see how close my visual estimations were. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200712/1 |
![]() "Clark" wrote in message ... In other words, you have no idea how wide that "very nice corridor is". Mr. McNicoll, you do not speak for me. Do try to remember that. Nobody is speaking for you, your messages make it clear you have no idea how wide that corridor is. As I said before, I suggest you learn how to look at photos produced through telephoto lenses. Your messages also make it clear there is no benefit in following your suggestions. |
Is your IFR GPS still legal for use? | john smith[_2_] | Piloting | 36 | May 29th 07 09:23 PM |
Legal or not? | Jim Macklin | Instrument Flight Rules | 42 | October 5th 06 12:02 AM |
Was The Idiot Legal? | RST Engineering | Piloting | 10 | August 4th 06 03:12 AM |
Legal Links | [email protected] | Piloting | 0 | May 13th 06 05:04 PM |
Is Flying AGL Legal? | ContestID67 | Soaring | 11 | March 19th 06 07:33 PM |
