#71
On Tue, 18 Dec 2007 10:14:05 -0700, "Bill Daniels"
bildan@comcast-dot-net wrote: But, there are problems with the very basic KISS principle. If you ask the winch driver to control the glider's airspeed, you have to give him a way to to judge how well he does that. Yup. Here in Germany we call this training. ![]() A new winch driver needs 100 winch launches on 10 different days (read: different weather situations) to acquire his winch driver license. Any winch driver student is able to drive the winch safely after a dozen launches using his feeling, an RPM meter and a look at the cable sag. Driving a winch is pretty simple if you ask me. ![]() If you ask the winch driver to control tension instead of airspeed, he has several things to help him do that - things like cable sag (if using steel) throttle setting and the sound and feel of the winch. It's even simpler for him if there is a tensiometer. It's still better if you can link the instantaneous cable tension to a throttle control loop so the winch does it automatically. Nice to have... but we use a much simpler way: We have an RPM meter. Winch driver accelerates to a certain RPM (depending on glider type). This RPM is modified according to the wind condition. Once the glider goes through 45 degrees "winch driver head up", RPM is slowly decreased. Works like a charm 99.99 percent of the time. The critical point is that neither the pilot or winch driver can control both airspeed AND tension at the same time. If you tell the pilot to just "go along for the ride" and task the winch driver with controling both, you are giving the winch driver an impossible task. I think you are wrong here. The fact alone that nearly all winches in Europe operate the way I described above means that this task is easy to handle, don't you agree? If the winch driver controls only tension, the pilot now has to step up and control his own airspeed. Once I realized I could do this, launches assumed a high level of smoothness and consistency. This REALLY works SWEET. The math shows it works right up to the cable tension that would break the weak link so winch engine potential power or torque has nothing to do with it. Who cares? I can assure you that with the KISS principle we reach the same altitudes as you do. ![]() However, this is a hard concept to teach someone who has been trained otherwise. I've had people who were jumping up and down with indignation since they "knew" that pulling harder would make the glider speed up. "Show me", I said. They lost the bet - every time. LOL... here comes the urban legend "pilot controls airspeed" again... I'm sure this is what is confusing glider pilots on a winch. As the nose rises during the rotation, the glider is still accelerating and, since the airspeed doesn't drop when they pull, they assume pulling on the stick makes the glider speed up - or at least that they have no control over airspeed. I don't think so. Being able to control the airspeed safely by pulling on the stick has been an urban legend for ages. We sometimes talk about it, have a good laugh, and return to the standard technique. There are things that make this hard to see. For one thing, the airspeed response is not instantaneous - it takes a little time for a pitch input to result in an airspeed change. For another, if the glider is loaded with the CG at or even beyond the forward limit, you will likely not have enough up elevator authority to slow the glider. This is a W&B problem - not a winch problem. It's is the "two 200+ pounders in a glider with a 380 pound maximum cockpit load" problem. I can ssure you - even a very tail-heavy DG-505 (the glider that can break *any* weak-link) is unable to slow a winch with halfways sufficient power down, although its elevator authority is sufficient to stall it in any phase of the winch launch. Fly one if you get the chance - it's interesting to see the loss of aileron authority when you approach the stall during the winch launch... So, is this approach unnecessarily complicated? I don't think so. All I am saying is to give the winch driver the ability to control tension extremely accurately no matter what. Any driver, any wind, any glider or pilot and the tension is always exactly right. What's not to like about that? The complexity. The fact that extremely few winch operators feel the need to build a winch according to yxour ideas points out that there might be other priorities. All you ask of the pilot is to control airspeed with pitch exactly like it is done in all other flight situations. In other words, "Just fly the glider". What's complicated about that? It's not how it's done. Taking the example of the 505 - if I tried to reduce airspeed by pulling at more than 115 kph, I'd break the strongest weak link *any time*. An AOA indicator helps the pilot because his wings are loaded to the equivalent of 3.5 G's so the "loaded stall airspeed" is much higher than in 1G flight. Glider's have stalled while on the wire with disastrous results. A safe AOA indication is an absolute guarantee that you won't stall - no ASI indication gives that level of assurance. I disagree completely. ![]() Take a closer look at causes for winch accidents: Most accidents happen due to ground loops (just look at the video that started this thread if you want to see some close cases) and badly executed rope-break procedures. There's hardly any case (I know of none) where the glider stalled at an altitude of more than 200 ft. Nearly all stall related accidents happen due to a too-sudden transition into full climb, followed by an immediate highspeed stall and cartwheel or spin. It's extremely simple to avoid this kind of accident: Keep the stick in the recommended position for their first 150 ft of the winch launch before pulling back smooooothly to enter the full climb angle. Usually such a stall occurs extremely quickly - it's nearly impossible to recover before impact. These pilots were not able to hold the stick halfways in the correct position, nor were they able to detect the very sudden transition into a steep nose-up attitude. Nor, obvously, were they able to perform the very simple corrective measu Push the stick forward immediately. I strongly doubt that these pilots had been able to watch, interpret and act according to an AoA meter. Bye Andreas |
#72
Even better, buy a Skylaunch 2 Winch with adjustable
throttle stops for glider type and wind direction. It isn't even fitted with a RPM meter, because it doesn't need one. We had one demonstrated at Lasham recently, and it was very easy to drive and gave great launches: See the following video: http://www.youtube.com/watch?v=0qc3U_7_4FY I wrote a report on the demo day for our club newsgroup, which I reproduce below:- Hi, Mike Groves and the Skylaunch team brought along one of their latest main winches for a demonstration day at Lasham on 12th December to coincide with the 'Winter Wednesdays' flying group, which is a very active and pro-active instructional team, so there was plenty of launching to be done. It was a beautiful Winter's day, with lots of sunshine and a very light South-Easterly wind. We set up on the Easterly run (semi-crosswind) with our normal retrieve winch in action, as the grass was rather too wet, soft and slippery for too much vehicle retrieving after a period of prolonged rain. This was the first time I had seen a Skylaunch with the trim tab throttle setting system, although I have flown many launches at the Long Mynd on their original prototype winch, which is not so fitted. With this system there are two setting tabs, one for glider typerunning from A+ for DG1000s down to F for vintage gliders, and a headwind component tab (which we set to 5 knots). In the cab was a booklet with most glider types listed with the appropriate settings After watching a few launches, I was allowed to drive this winch under the supervision of their pro winch driver. Compared with our Tosts it was ridiculously simple, without all the fiddly bits. The controls are a drum selection lever on the left, a gearbox drive selector, a console with the throttle lever and tabs, and just one instrument (interestingly no rev counter) plus a few warning lights, and a brake lever on the right. To launch you select the drum, engage 'drive', and select the appropriate throttle tab setting for the type of glider being launched (you have to be informed by radio what it is, particularly as we were launching over a hump so couldn't quite see the launch point). Then a little touch on the throttle lever for 'take up slack' and then push the lever up to the preset and hold it there for the first 2/3rds of the launch (no need to back off during rotation),after which you have to start backing off a bit as normal. You can overide the preset if you consider this necessary. As the glider gets nearly overhead, you reduce the throttle to indicate that the launch is over, and as soon as the glider releases apply a short burst of power to pull the cable straight. After that select neutral and allow the retrieve winch to pull the cable back to the launch point. There is a automatic tow-out brake, controlled by gas struts, so no need to wrestle with the handbrake levers as with the Tost. You just rest your hand on the brake lever and apply a litle bit of brake as the cable(s) slows down as the other end reaches the launch point to prevent the drum over-running. My first launch was a 'Baby Grob' G102, which we launched on the Grob Astir setting. This produced a bit of initial tail wagging (signal for too fast) so I had to back the power off a touch, after which the rest of the launch went smoothly. Peter the winch driver said he had never launched one of these before, and suspected that it was a bit slower and lighter than the Astir (which it is) and that we should have used the next lowest setting down. This probably shows how accurate the system is! Then I launched a heavy Grob 2 seater and then a K13 which seemed to be having a very good launch until the instructor pulled a simulated cable break on his student. No problem, I just closed the throttle and let the cable drop and waited until the glider landed. Then after liasing with the retrieve winch by radio I pulled a little bit of cable in to straighten things up, and then the cable was retrieved as normal. I did a couple more launches which went smoothly with no signalling from the glider. Although I am not a current winch driver, I found this winch very little more difficult to drive than our retrieve winch. It was just winch driving by numbers. Mike pointed out that this winch is designed specifically to be driven by ordinary gliding club members, as opposed to skilled professional drivers. Compared with the Tost, it is very quiet,comfortable and user friendly Later on I a tried a solo launch in a K21 on this winch. The ground run acceleration was a little bit faster than we normally get and the glider rotated into an ideal 65 knots climb. I tried pulling back a bit harder and it slowed down to 60 knots and then eased forward and it speeded up to 70 knots. So with this system you can control the speed. Despite this messing around I still got a 1400ft launch off a short run (1080 metres) in a crosswind using steel cables, which is about 100ft or so higher than I would have expected on the Tost. Members generally reported 1300-1400ft launches. A few interesting points. Mike Groves said that some clubs with shorter runs are using rope rather than dyneema, which is a fraction of the cost, but still much lighter than steel cables, although somewhat thicker so you can't get so much onto a drum. No good for really long runs. He will also re-engineer old Tost winches to modern standards, which includes turning the axle over so it is the right way up and properly lubricated, throwing away the small diameter drums and level wind gear and fitting Skylaunch narrow large diameter bottom feeding drums. If you have an old Tost with a decent engine and gearbox, this could be very cost effective and will reduce maintenance requirements. Derek Copeland At 01:06 19 December 2007, Andreas Maurer wrote: On Tue, 18 Dec 2007 10:14:05 -0700, 'Bill Daniels' wrote: But, there are problems with the very basic KISS principle. If you ask the winch driver to control the glider's airspeed, you have to give him a way to to judge how well he does that. Yup. Here in Germany we call this training. ![]() A new winch driver needs 100 winch launches on 10 different days (read: different weather situations) to acquire his winch driver license. Any winch driver student is able to drive the winch safely after a dozen launches using his feeling, an RPM meter and a look at the cable sag. Driving a winch is pretty simple if you ask me. ![]() If you ask the winch driver to control tension instead of airspeed, he has several things to help him do that - things like cable sag (if using steel) throttle setting and the sound and feel of the winch. It's even simpler for him if there is a tensiometer. It's still better if you can link the instantaneous cable tension to a throttle control loop so the winch does it automatically. Nice to have... but we use a much simpler way: We have an RPM meter. Winch driver accelerates to a certain RPM (depending on glider type). This RPM is modified according to the wind condition. Once the glider goes through 45 degrees 'winch driver head up', RPM is slowly decreased. Works like a charm 99.99 percent of the time. The critical point is that neither the pilot or winch driver can control both airspeed AND tension at the same time. If you tell the pilot to just 'go along for the ride' and task the winch driver with controling both, you are giving the winch driver an impossible task. I think you are wrong here. The fact alone that nearly all winches in Europe operate the way I described above means that this task is easy to handle, don't you agree? If the winch driver controls only tension, the pilot now has to step up and control his own airspeed. Once I realized I could do this, launches assumed a high level of smoothness and consistency. This REALLY works SWEET. The math shows it works right up to the cable tension that would break the weak link so winch engine potential power or torque has nothing to do with it. Who cares? I can assure you that with the KISS principle we reach the same altitudes as you do. ![]() However, this is a hard concept to teach someone who has been trained otherwise. I've had people who were jumping up and down with indignation since they 'knew' that pulling harder would make the glider speed up. 'Show me', I said. They lost the bet - every time. LOL... here comes the urban legend 'pilot controls airspeed' again... I'm sure this is what is confusing glider pilots on a winch. As the nose rises during the rotation, the glider is still accelerating and, since the airspeed doesn't drop when they pull, they assume pulling on the stick makes the glider speed up - or at least that they have no control over airspeed. I don't think so. Being able to control the airspeed safely by pulling on the stick has been an urban legend for ages. We sometimes talk about it, have a good laugh, and return to the standard technique. There are things that make this hard to see. For one thing, the airspeed response is not instantaneous - it takes a little time for a pitch input to result in an airspeed change. For another, if the glider is loaded with the CG at or even beyond the forward limit, you will likely not have enough up elevator authority to slow the glider. This is a W&B problem - not a winch problem. It's is the 'two 200+ pounders in a glider with a 380 pound maximum cockpit load' problem. I can ssure you - even a very tail-heavy DG-505 (the glider that can break *any* weak-link) is unable to slow a winch with halfways sufficient power down, although its elevator authority is sufficient to stall it in any phase of the winch launch. Fly one if you get the chance - it's interesting to see the loss of aileron authority when you approach the stall during the winch launch... So, is this approach unnecessarily complicated? I don't think so. All I am saying is to give the winch driver the ability to control tension extremely accurately no matter what. Any driver, any wind, any glider or pilot and the tension is always exactly right. What's not to like about that? The complexity. The fact that extremely few winch operators feel the need to build a winch according to yxour ideas points out that there might be other priorities. All you ask of the pilot is to control airspeed with pitch exactly like it is done in all other flight situations. In other words, 'Just fly the glider'. What's complicated about that? It's not how it's done. Taking the example of the 505 - if I tried to reduce airspeed by pulling at more than 115 kph, I'd break the strongest weak link *any time*. An AOA indicator helps the pilot because his wings are loaded to the equivalent of 3.5 G's so the 'loaded stall airspeed' is much higher than in 1G flight. Glider's have stalled while on the wire with disastrous results. A safe AOA indication is an absolute guarantee that you won't stall - no ASI indication gives that level of assurance. I disagree completely. ![]() Take a closer look at causes for winch accidents: Most accidents happen due to ground loops (just look at the video that started this thread if you want to see some close cases) and badly executed rope-break procedures. There's hardly any case (I know of none) where the glider stalled at an altitude of more than 200 ft. Nearly all stall related accidents happen due to a too-sudden transition into full climb, followed by an immediate highspeed stall and cartwheel or spin. It's extremely simple to avoid this kind of accident: Keep the stick in the recommended position for their first 150 ft of the winch launch before pulling back smooooothly to enter the full climb angle. Usually such a stall occurs extremely quickly - it's nearly impossible to recover before impact. These pilots were not able to hold the stick halfways in the correct position, nor were they able to detect the very sudden transition into a steep nose-up attitude. Nor, obvously, were they able to perform the very simple corrective measu Push the stick forward immediately. I strongly doubt that these pilots had been able to watch, interpret and act according to an AoA meter. Bye Andreas |
#73
On 19 Dec 2007 22:04:13 GMT, Del C
wrote: Even better, buy a Skylaunch 2 Winch with adjustable throttle stops for glider type and wind direction. Hi Derek, sound pretty good - and as close to the KISS principle as it gets. ![]() Just one annotation: I regard 70 kts for an ASK-21 as a little on the too-fast side (it will break the weak link if you pull back too much at this speed) - do you always tow that fast? Bye Andreas |
#74
I agree with Andreas Maurer that 70 knots is a bit
too fast for winch launching a K21. However flying a normal launch profile, where the stick is just back from centre for the full climb,gave a perfect 65 knots launch on the Skylaunch. I tried pulling back harder and then easing forward just to see what would happen, as some people in the winching world seem to believe that the airspeed should be controlled by the pilot changing the pitch angle. I found you could vary the speed by about 5 knots either way, but I can't really see the point of doing this, as it only gives you poorer launches than flying at the optimum speed! BTW, everyone I have spoken to has been very impressed by the Skylaunch 2 Winch. Del Copeland At 23:42 19 December 2007, Andreas Maurer wrote: On 19 Dec 2007 22:04:13 GMT, Del C wrote: Even better, buy a Skylaunch 2 Winch with adjustable throttle stops for glider type and wind direction. Hi Derek, sound pretty good - and as close to the KISS principle as it gets. ![]() Just one annotation: I regard 70 kts for an ASK-21 as a little on the too-fast side (it will break the weak link if you pull back too much at this speed) - do you always tow that fast? Bye Andreas |
#75
On Dec 20, 1:32 pm, Del C
wrote: I tried pulling back harder and then easing forward just to see what would happen, as some people in the winching world seem to believe that the airspeed should be controlled by the pilot changing the pitch angle. I found you could vary the speed by about 5 knots either way Just out of interest - when pulling back was the 5 knot change one of increasing or decreasing speed? Dan |
#76
Dan
Can I refer you back to my report on this winch! For the record, pulling back harder reduced the airspeed and easing forward increased it. Cheers and Happy Xmas Del C At 18:00 20 December 2007, Dan G wrote: On Dec 20, 1:32 pm, Del C wrote: I tried pulling back harder and then easing forward just to see what would happen, as some people in the winching world seem to believe that the airspeed should be controlled by the pilot changing the pitch angle. I found you could vary the speed by about 5 knots either way Just out of interest - when pulling back was the 5 knot change one of increasing or decreasing speed? Dan |
#77
Pilot controlling speed on Winch Launch:
- Another thing that speaks against pulling to slow down is this that if the winch driver does nothing when you pull, the speed can only be slowed temporarily by pulling. So you may slow down on certain set ups and aircraft, by you have to ease off on the extra pull over normal pretty soon, at which point you'll speed up again. So what's the point? You're just slowing down temporarily only to speed up again, or release prematurely by breaking the weak link or having the back release release earlier. Pushing over when to slow should be done anyway, for safety reasons. So no argument there. But unless the winch driver changes power settings, nothing will change. He's in charge. I also am more inclined to believe that oscillating by the pilot to influence airspeed, the way Bill Daniels advocates, will result in lower release altitudes than using the KISS method. |
#78
On Dec 20, 6:54 pm, Del C
wrote: Dan Can I refer you back to my report on this winch! For the record, pulling back harder reduced the airspeed and easing forward increased it. Cheers and Happy Xmas Del C Sorry, a goldfish brain moment on my part. Your experience with the speed is the same as mine on a V8 LPG winch. I think of the winch launch as a little bit like horse-riding - there are two brains involved in controlling what happens next.... Both pilot and winch driver control the speed to some degree, with the winch driver having the ability to induce bigger speed excursions from the optimum. Dan |
looking for a video | mike regish | Piloting | 20 | May 18th 07 12:27 AM |
ID this video, please | Jay Honeck | Piloting | 9 | January 4th 06 06:37 PM |
Video of RC F-14 | Yeff | Naval Aviation | 3 | April 19th 05 04:30 AM |
VIDEO: Frecce Tricolore collides over Ramstein - a new head on video | Montblack | Piloting | 1 | February 12th 05 04:03 AM |
F-14 and F/A-18 fly-by video | Ditch | Military Aviation | 3 | January 18th 04 03:54 PM |
