Steven P. McNicoll wrote:
I'm not familiar with that arrival, but you don't have to hear "Cleared to enter Class B airspace" if you're operating under another clearance that meets the requirement above. Like "Cleared to the Las Vegas Airport as filed, climb and maintain 3000 expect 10000 ten minutes after departure, departure frequency 125.05, squawk 0412..." |
![]() "Ron Natalie" wrote in message m... Like "Cleared to the Las Vegas Airport as filed, climb and maintain 3000 expect 10000 ten minutes after departure, departure frequency 125.05, squawk 0412..." There ya go. |
A Clearance from ATC is required to fly the Cortez 1 Arrival should include
the words.. "cleared to enter Class B", if not.. ask Most likely the phraseology will be, "N123VG, Cleared to enter Class B via the Cortez 1 arrival to North Las Vegas Airport. Maintain VFR." Most likely you will be restricted by ATC to maintain 3500MSL until in contact with VGT Tower dependent on their traffic pattern operations. They run parallel traffic patterns to 12L/30R and 12R/30L on split tower frequencies. Pattern altitude is 3000MSL. The Cortez Arrival is the old "Showboat" arrival, until it was imploded. It was easy to see the Showboat.. it is harder to spot the El Cortez. BT VGT based "Ron Lee" wrote in message ... Does being cleared for this arrival automatically give you clearance to enter Class B airspace or do you need to hear "Cleared to enter Class B airspace" as well. Ron Lee |
![]() "BT" wrote in message ... A Clearance from ATC is required to fly the Cortez 1 Arrival should include the words.. "cleared to enter Class B", if not.. ask Most likely the phraseology will be, "N123VG, Cleared to enter Class B via the Cortez 1 arrival to North Las Vegas Airport. Maintain VFR." A clearance to fly the Cortez 1 Arrival need not include the words, "cleared to enter Class B". The clearance requirement for Class B entry is satisfied by the clearance for the arrival. |
On Dec 22, 7:06*am, "Steven P. McNicoll"
wrote: A clearance to fly the Cortez 1 Arrival need not include the words, "cleared to enter Class B". *The clearance requirement for Class B entry is satisfied by the clearance for the arrival. WRONG |
![]() wrote in message ... On Dec 22, 7:06 am, "Steven P. McNicoll" wrote: A clearance to fly the Cortez 1 Arrival need not include the words, "cleared to enter Class B". The clearance requirement for Class B entry is satisfied by the clearance for the arrival. WRONG Please explain why you believe I'm wrong. |
On Dec 22, 9:56*am, "Steven P. McNicoll"
wrote: Please explain why you believe I'm wrong. Because you have not provided a reference that ***clearly states*** an arrival procedure is a clearance into Bravo. Allen Aviation videos at http://www.youtube.com/profile?user=BeechSundowner |
I am happy with this answer now. Another VFR pilot who was cleared on
the Cortez 1 transition route a month ago asked if he was cleared to enter Class B (as I probably would have). He was chided by the controller that he had already been cleared for the Cortez 1 arrival. Thus I am confident that approval by ATC to fly the Cortez 1 transition route also carries with it approval to enter Class B airspace. Ron Lee |
Ron Lee wrote:
I am happy with this answer now. Another VFR pilot who was cleared on the Cortez 1 transition route a month ago asked if he was cleared to enter Class B (as I probably would have). He was chided by the controller that he had already been cleared for the Cortez 1 arrival. Thus I am confident that approval by ATC to fly the Cortez 1 transition route also carries with it approval to enter Class B airspace. Ron Lee Which is -EXACTLY- what one would expect if they were to actually read the damn TAC. -- Jim Pennino Remove .spam.sux to reply. |
Class B airspace notation | BillJ | Piloting | 59 | December 27th 07 12:48 AM |
Transponders Above Class C Airspace | Jim Vincent | Soaring | 20 | May 15th 07 04:36 PM |
Class F Airspace in Germany | Guy Corbett | Soaring | 4 | May 9th 07 09:25 AM |
Class A airspace | flying_monkey | Soaring | 66 | October 22nd 06 03:38 PM |
Tower with only Class G Airspace | Jeff Saylor | Piloting | 8 | May 10th 04 09:53 PM |
