The FAA is marching toward sole dependence on GPS.
Old December 21st 07, 07:25 PM posted to rec.aviation.ifr
Bob Gardner
Default The FAA is marching toward sole dependence on GPS.
No, Sam....LEGACY loran sucks. Enhanced loran (which will require new
receivers/antennas to utilize its GPS-equivalent accuracy) is right around
the corner. A new eLoran station has recently been put on the air in the UK,
and the Coast Guard is well on the way to upgrading its whole system. Go to
www.loran.org and start following links. www.crossrate.com is another useful
site.
Bob Gardner
"Sam Spade" wrote in message
And LORAN sucks and does not work in much of the world.
Old December 22nd 07, 12:42 AM posted to rec.aviation.ifr
Sam Spade
Well, let me put it this way. It isn't in any of the FAA's NexGen
performance-based nav systems plans.
around the corner. A new eLoran station has recently been put on the air
in the UK, and the Coast Guard is well on the way to upgrading its whole
system. Go to www.loran.org and start following links. www.crossrate.com
is another useful site.
Bob Gardner
Old December 22nd 07, 02:02 AM posted to rec.aviation.ifr
Bob Gardner
Can't argue with that...it is a Coast Guard program, not an FAA program.
Still, if you follow the links in www.loran.org you will see a lot of USCG
Headquarters names listed.
It seems as though I have to repeat this over and over, but with eLoran you
don't have to select chains or group repetition rates...you just turn it on,
like a GPS, and it starts displaying RNP 0.3-accuracy positions. Its
all-in-view technology uses all usable signals within range and processes
them simultaneously. The wonders of microtechnology...
Bob Gardner
Bob Gardner
Old December 22nd 07, 02:17 AM posted to rec.aviation.ifr
Ron Lee[_2_]
The FAA does not OWN LORAN. The DOT has done a diservice to the GA
comminity by waffling on LORAN for a decade or more. Make it a viable
system and the GA community can have another viable RNAV-like system
like the big boys do with their expensive FMS, DME, inertial units.
NextGen. Yea right. Force GA pilots to spend TBD thousands of
dollars on the ADS-B Out equipment that provides no benefit to me.
They can't even make what they have now work properly although the
airlines are also culpable in the problems we have today.
Ron Lee
Old December 22nd 07, 03:10 AM posted to rec.aviation.ifr
Steven P. McNicoll
"Ron Lee" wrote in message
Nor does the FAA OWN GPS.
Old December 22nd 07, 09:43 PM posted to rec.aviation.ifr
Ron Lee[_2_]
True Steven but they do own WAAS (a GPS augmentation system) which
they seem to make essential to many programs such as ADS-B Out.
Ron Lee
Old December 23rd 07, 02:37 AM posted to rec.aviation.ifr
Ron Lee[_2_]
huh? What is the relationship/interaction between WAAS and ADS-B?
Bob Noel
Look at the ADS-B Out NPRM, page 56956, third column (right side of
page) for these points which IMO seems that the FAA conveniently
specify ADS-B Out performance requirements that can only be met using
GPS augmented with WAAS.
"This proposal specifies performance standards for aircraft avionics
equipment for operation to enable ADS B Out. These performance
standards would accommodate and facilitate the use of new technology.
Presently, GPS augmented by the Wide Area Augmentation System (WAAS)
is the only navigation position service that provides the level of
accuracy and integrity (NIC, NACp, and NACv) to enable ADS-B Out to be
used for NAS based surveillance operations with sufficient
availability."
Plus near the bottom of that column:
"In order to meet the proposed performance requirements using the
GPS/WAAS system, aircraft would be required to have equipment
installed onboard the aircraft that meets one of the following: (1)
TSO C145b, Airborne Navigation Sensors using the GPS augmented by
WAAS; or (2) TSO-C146b Stand-Alone Airborne Navigation Equipment using
the GPS augmented by WAAS."
Ron Lee
Old December 22nd 07, 01:58 PM posted to rec.aviation.ifr
Sam Spade
Ron Lee
ADS-B is not a performance-based navigation system, thus not in the
context of this thread.
Performance-based navigation is. Have you seen the RNP SAAAR IAP for
Runway 31 at Bishop, CA for example? Look at the minimums on that IAP
compared to the other IAPs for that airport.
So far as the GA community is concered, keep in ming there are light
aircraft then there are business aircraft. A world of difference.
Old December 22nd 07, 05:22 PM posted to rec.aviation.ifr
Bob Gardner
Sorry...it's Mitch Narins...I spelled it wrong. Read this:
http://www.loran.org/library/Road%20to%20eLoran.pdf and note the FAA logo on
the first page.
Bob Gardner
Bob Gardner
The FAA is marching toward sole dependence on GPS- Is that a mistake? BarneyFife Piloting 6 December 3rd 07 12:14 AM
Class 3 Medical question: Substance dependence AJ Piloting 3 June 10th 07 02:51 PM
GPS Sole Source Civil Aviation Navigation? SirRichardCraniumEsq. Instrument Flight Rules 9 October 1st 06 03:55 PM
Canadian dependence on Antonov -124's Xenia Dragon Military Aviation 0 March 18th 04 04:20 PM
"Stand Alone" Boxes (Garmin 430) - Sole means of navigation - legal? Richard Instrument Flight Rules 20 September 30th 03 02:13 PM
