On Dec 22, 6:15 pm, wrote:
Many pilots seem to believe that blow-by in the engine is a normal operating condition. My experience( and opinion) and that of many other race engine mechanics that I have talked to, is that once combustion gases begin to leak past the rings, the end of that engine is imminent and soon. Very soon. Blowby totally destroys the lubrication of the piston in the area of the blowby, and it shouldn't take a rocket scientist to know what that means. regards, Bud My experience is as an aircraft mechanic. Part of the inspection process is the differential compression test on each cylinder, when it's hot after shutdown. All cylinders leak a small amount past the rings, and when the engine cools the leakage is considerably worse. All rings have ring gaps, and unless you have stacked rings (two rings in the same groove) you cannot stop the leakage. Aircraft engines do not have stacked rings. The fact that a frozen-shut breather will cause the front seal to blow out is enough evidence that rings leak. The volume of the crankcase, as noted earlier, is very small. The amount of water in a cubic foot of air, even if it's saturated, is miniscule compared to that which gets past the rings curing combustion, unless the aircraft is parked for a long time and the heating/cooling cycles of day/night pump air in and out repeatedly for a long time. Water, even a small amount, mixes with oil and in the presence of metal, which acts as a catalyst, breaks the oil down and creates acids. The thin film of oil on the parts is the first contributor to this process and is not much protection at all. |
A fun science experiment is to put a small amount of water in the
bottom of a 1 gallon rectangular can. Boil it for a few minutes to displace the air inside, remove it from the heat, and immediately replace the cap and watch. For more excitement, repeat with another can only this time cap it and sprinkle cold water on the outside of the can too. (Hint - don't plan on using the cans again.....!) |
* * * * My experience is as an aircraft mechanic.
Thanks for a great primer, Dan. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
LOM engines | buckey | Home Built | 14 | October 30th 03 05:22 PM |
automotive parts on airplane engines | Wallace Berry | Home Built | 15 | September 28th 03 02:55 AM |
Barnyard--- Auto engines | Jerry Springer | Home Built | 10 | August 8th 03 06:38 PM |
