On Dec 24, 8:26*pm, AK wrote:
If your software has it how much are you using this feature? Do you tend to use it more than traditional MC/ballast/bugs settings for final glide calculation? I am suspicious of usefulness of this feature in fast changing conditions. What is your experience? AK I don't use Flown L/D very much, but use Required L/D a lot. After awhile, you get a good feel for what your glider can do in various conditions. For example, in my LS6 I'm happy when I have 25/1 to the place I want to land at (and I use L/D to the field elevation to prevent weird numbers showing up at close ranges). 30/1 is good for starting a long final glide. 35/1 is iffy but close. Makes keeping track of landable fields easy at a glance, and makes a nice cross check during climb to final glide and during the glider. Kirk 66 |
SeeYou task settings | Tuno | Soaring | 7 | February 22nd 07 03:51 AM |
New DMSt task: 4 TPs | Klaus T. | Soaring | 0 | January 9th 06 12:03 AM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
1000k comp task | Mel Dawson | Soaring | 0 | July 5th 05 08:22 PM |
New Task | JJ Sinclair | Soaring | 5 | October 23rd 03 01:36 AM |
