"nrp" wrote in message
... ... A lot of this moisture accumulation problem would go away if aircraft engines had a positive crankcase ventilation (PCV) system like car engines now do, but they don't for whatever reason. I suspect part of the reason car engines now last so much longer is due to the PCV system. Talking to one of the "old guys" at work some years ago this came up - his claim was that when PCV was first required, they were worried about re-cycling all the "gunk" and damaging the engines - but testing (and eventually field experience) showed that keeping the crankcase ventilated resulted in a significant boost in engine durability. He referred to PCV as one of the best things to come along... Conventional auto style PCV won't work well on an aircraft engine due to the lack of vacuum in the manifold to generate the air flow. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
LOM engines | buckey | Home Built | 14 | October 30th 03 05:22 PM |
automotive parts on airplane engines | Wallace Berry | Home Built | 15 | September 28th 03 02:55 AM |
Barnyard--- Auto engines | Jerry Springer | Home Built | 10 | August 8th 03 06:38 PM |
