Harley oil cooler for interior heat.
Old December 27th 07, 01:02 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Harley oil cooler for interior heat.
wrote
I don't have heat inside my canard plane. Now am considering piping
hot engine oil to the cabin through a small oil cooler with a blower.
I am looking at a Harley Dyna oil cooler - about the right size. My
question is whether such a cooler will stand the typical aircraft oil
pressure. My engine oil pressure goes up to about 80 psi when cold
then goes down to about 60 psi. I have seen Harleys with oil cooler
pressure gauges 60psi. But shouldn't they have an extra safety stress
factor?
It seems like I recall someone saying that the oil cooler did not put out
enough heat in the winter to be very useful.
It would seem like the bike cooler would be tough enough. I would use it,
but put two in line petcocks in the line to bypass the cooler, and put them
where you can reach it while you are flying. If it did leak, you could turn
it off, but as big of a consideration is the fact that you will not want to
be using it in the summer, anyway!
Jim in NC
Old December 27th 07, 04:31 AM posted to rec.aviation.homebuilt
Bill Daniels
"Morgans" wrote in message
factor?
them where you can reach it while you are flying. If it did leak, you
could turn it off, but as big of a consideration is the fact that you will
not want to be using it in the summer, anyway!
Jim in NC
Not enough heat? Try flying a GLIDER at -50F. Can you say, "electric
socks"?
Old December 27th 07, 05:11 AM posted to rec.aviation.homebuilt
"Bill Daniels" bildan@comcast-dot-net wrote in message
socks"?
Bill,
That is why I do my glider maintenance in the winter. Wave flying is just
to cold for my old bones.
HP-14 "6F"
http://www.soaridaho.com/Schreder
Oil Cooler Al Girdvainis/Penni Abram Home Built 0 November 26th 04 01:28 AM
Metal in the Oil Cooler Justin H Home Built 4 August 18th 04 11:28 AM
Oil cooler? Rick Home Built 1 March 22nd 04 09:41 AM
harley engine Air Methods Corporation Home Built 1 September 21st 03 08:13 PM
