Jose wrote:
To define turn using axis reference is not the best way to explain turn since once established in a stable turn there should be no movement on the airplane's axis system. I am not sure I'm getting this. We'll ignore translation (straight line motion). The axis system is (as I have been using it) fixed to the aircraft, and the axis system moves whenever the aircraft rotates (around any point). It has nothing to do with the actual earth's horizon. Then, as I understand it, rotation of the aircraft involves a rotation around one or more of the axes. Yaw involves rotation (=of= the longitudinal axis, and thus the airplane) =about= the (airplane) vertical axis, =in= the plane (roughly described by the wing tips and tail) of the (airplane) horizontal axes. In a turn, slipping, skidding, or coordinated, the nose of the airplane (dragging the longitudinal axis with it) is changing its direction. The airplane is changing heading. If this happens at a constant rate (say, 3 degrees per second), I would say the aircraft is yawing at a steady angular velocity, and undergoing no acceleration in yaw. To =enter= or =leave= this state would require an =acceleration= of yaw in one direction or another. Where do our understandings and vocabulary diverge? Jose Jose; Do some research on the aircraft axis system and what each axis represents, then research forces in turns. It should become clearer then. Thank you -- Dudley Henriques |
Coordinated turns without rudder, and autopilots | Mxsmanic | Piloting | 188 | June 1st 07 07:09 PM |
Coordinated turns and the little ball | Mxsmanic | Piloting | 51 | October 11th 06 10:17 PM |
Is rudder required for coordinated turns? | Mxsmanic | Piloting | 41 | September 24th 06 06:40 PM |
Snap / Flick and spins in flight simulators | [email protected] | Simulators | 1 | September 2nd 06 07:10 AM |
Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 08:46 PM |
