737 Blown Across Ramp
Old December 28th 07, 03:20 AM posted to rec.aviation.piloting
RST Engineering
Default 737 Blown Across Ramp
Anyone who watched the Bears game on Sunday and saw Brent Fabre say that it
was the coldest game he'd ever played it knows that it was an absolute ice
rink at Midway. You could have set those brakes at a thousand psi and that
sucker would have fancydanced across the ice in that wind.
No chocks, only tiedowns could have kept that aircraft from moving.
"If you think you can, or think you can't, you're right."
--Henry Ford
"aluckyguess" wrote in message
On Dec 27, 1:14 pm, Matt Whiting wrote:
Phil wrote:
I know they call it the Windy City, but this is ridiculous...
http://www.aero-news.net/index.cfm?C...642-d205-411d-...
Phil
What do you want to bet that the brakes weren't set?
That would be odd. Why would the brakes be set if no one was on board?
Makes it a bit tough to tow.
-Robert
I hear chalks fix the problem.
Old December 28th 07, 06:33 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
"RST Engineering" wrote in
that it was the coldest game he'd ever played it knows that it was an
absolute ice rink at Midway. You could have set those brakes at a
thousand psi and that sucker would have fancydanced across the ice in
that wind.
Wel, they would have been set at 3,000 PSI in fact,
True.
Bertie
Old December 28th 07, 08:28 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Chocks aren't perfect. At my home field we often get violent downbursts
from thunderstorms in the summer. Peak gusts of 60-70 kts aren't unusual. I
use both chocks and tiedowns, and I've found that after a particularly bad
storm, the chocks were often blown away from wheels and the plane was sitting
slightly sideways with the tiedowns pulled tight.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200712/1
Old December 28th 07, 10:17 PM posted to rec.aviation.piloting
F. Baum
* Chocks aren't perfect. *
They may not be perfect but close. The chocks typicaly used on
airlines could have prevented this. There are no provisions for tying
down a jet. The 737 manual does recommend leaving the parking brake
set in windy conditions.
Message posted via AviationKB.comhttp://www.aviationkb.com/Uwe/Forums.aspx/aviation/200712/1
Old December 28th 07, 11:57 PM posted to rec.aviation.piloting
"F. Baum" wrote in
hmm, I think you may be mistaken about the tie down provisions. I've never
seen anthing except the tug/towbar thng you mentioned, but I think some may
have a spot where a ring can be screwed in , maybe where the hardpoints for
the jacks go. I'll ask the guys next chance I get.
Bertie
Old December 29th 07, 04:57 PM posted to rec.aviation.piloting
Matt Whiting
Parking brake? Who woulda thunk it? :-)
Matt
Matt Whiting
Yes, chocks are temporary restraints and no better on ice than are the
tires and brakes. Tie downs are the only way to go for permanent
restraint (other than a hangar!).
Matt
Old December 31st 07, 06:20 PM posted to rec.aviation.piloting
William Hung[_2_]
* Chocks aren't perfect. * At my home field we often get violent downbursts
from thunderstorms in the summer. *Peak gusts of 60-70 kts aren't unusual. *I
tires and brakes. *Tie downs are the only way to go for permanent
Matt
Do small planes have parking brakes? I don't remember having ever
seen one that I could set the brakes.
Wil
Old December 31st 07, 06:29 PM posted to rec.aviation.piloting
William Hung wrote in
moving.
dow
nbursts
unus
ual. *I
particularly b
ad
was si
tting
the tires and brakes. *Tie downs are the only way to go for permanent
Matt
Most modern ones do. Lots of old ones too.
Bertie
Old December 31st 07, 06:47 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Look closer. G
Proof FAA Managers are full blown certified IDIOTS SOS Instrument Flight Rules 1 December 1st 07 05:05 AM
Proof FAA Managers are full blown certified IDIOTS SOS Piloting 1 November 29th 07 07:44 PM
Ramp riders 5 Paul Aviation Photos 0 November 19th 06 10:09 PM
MMU ramp fee Peter Gottlieb Piloting 25 August 9th 03 12:49 AM
Flight TWA 800 was shot down/blown up by Al Quadea? Tiger Military Aviation 0 July 3rd 03 05:38 PM
